Out of interest could scrap 0.925 silver be used for copper soldering? For example cutting strips from scrap bought from a pawn broker / jeweller…
If you’re happy to have to heat everything to around 900 degrees Celsius and maybe then use a hot caustic soda solution to clean off the high temperature flux you may have needed, you can use sterling silver as solder.
If you’re soldering copper to copper and it’s not a boiler, you’d be better off with a phosphorus-bearing alloy like Silbralloy. It’s cheap to buy and doesn’t need a flux for copper joining.
No jeweller worth their salt will use 55% silver solders for soldering Sterling, Britannia or Fine silvers, as 55% silver content does not make for a hallmarking grade of solder.
