Another use for the “Stevensons Collet Blocks”
Home › Forums › Hints And Tips for model engineers › Another use for the “Stevensons Collet Blocks”
  • #324523
    Andy Pugh
      @andypugh44463
      I have a touch-probe that fits my vertical head, but not the horizontal.
      I have a coaxial indicator that fits both, but that's no good for picking up edges.
      I had a brainwave at the weekend, and used the square "Stevensons Collet Blocks" from arc-eurotrade.
      This turns out to be 40mm square with a nice ground and tapered hole. SO once the dial was running true I knew I was 20mm above the table and 20mm from the edge of the part being machined.
      As a bonus, the fact that the bore is tapered means that the dial shows oval if you are out of square too.
      #30637
      Andy Pugh
        @andypugh44463
        Picking up edges with a coaxial indicator.
        #324562
        Thor 🇳🇴
          @thor
          Hi Andy
          Thanks for sharing.
          Thor
          #324567
          thaiguzzi
            @thaiguzzi
            Smart. Like it.
            #324570
              The 'oval' test is a particularly nice bonus.
              … Good thinking yes
              Brian Wood
                @brianwood45127
                Inspired thinking Andy, especially the rotational alignment indication.
                I think John would have issued his expression 'job's a good un' in recognition.
                Thank you for sharing it
                Regards Brian
                #324726
                John Reese
                  @johnreese12848
                  It is not often I learn something new. Thanks. BTW, this should work with a normal dial test indivator as well as the Blake.
                  #324728
                  Ian Skeldon 2
                    @ianskeldon2
                    Like it.
                    #324729
                    DMB
                      @dmb
                      Well done Andy.
                      Brilliant idea.
                      Will use this in future, since I have the sq. and hex blocks.
                      #325829
                      Russ B
                        @russb
                        +1 Andy, great idea!
                        I've just got my ER40 Sq.+Hex set!
                        I've bought things in the past that I thought was going to be handy….. and it really just didn't fulfil that expectation.
                        The more I do and see people doing with the these blocks, the more I like it!
                        I've added a pair of 20-40-80 + 10-20-40 Stevenson’s blocks to my Xmas list as I've always fancied a set and they'll prove invaluable for a couple of checks I want to make on my lathe next year.
                        Edited By Russ B on 07/11/2017 05:25:14
                        #325839
                        Bazyle
                          @bazyle
                          It must work on 5C blocks too – Just need a coaxial indicator. frown another toy to buy.
