Annoying Adverts
Annoying Adverts
Home › Forums › Beginners questions › Annoying Adverts
Viewing 20 posts - 26 through 45 (of 45 total)
  • #94660
      There is something rather Spooky going on here.
      I have just looked back at the forum link that I posted earlier … it now displays correctly.
      MichaelG. I see what has changed … David has removed the long hyperlink that was causing the problem. I don't have relief on my saw and the blades seem to last forever!
      There is a stop that you can set (carefully) so that the drop at the end of a cut is minimal. I also built a retractable pin to hold the saw in the position. There were some articles by Duplex many years ago – I think these went with the Duplex machine. There was also an article in MEW about some sort of damping device for a hacksaw. If you download the ME and MEW indexes Indexes you should be able to search for the articles that you want. They are Excel spreadsheets.
      Edited By David Clark 1 on 18/07/2012 19:33:01
      #94661
      David Clark 13
        @davidclark13
        Hi Michael
        I shortened the links.
        regards david
        #94662
          Sorry David … our posts crossed in the æther !
          If it's any help THIS thread is now displaying the problem [on iPad]
          Flying Fifer
            @flyingfifer
            O dear strange how on page 2 of THIS post I can read DC1`s first post but the next 4 posts go under the adverts & you cant read all of them. I wonder why???? The next post DC1`s is then OK wonder if this post will be OK.
            Looks like you`ll have to do your unpaid job agan David.
            Fifer
            #94665
              Fifer,
              You can read David's first post because the lines of text are short !!
              The "message box" still goes under the adverts.
                O.K. folks … I think I may have located the problem.
                In editing my post of 23:03:00, I copied and pasted from the other thread.
                If you look at the Source Code for THIS page, you will find that there is now one occurrence of
                ….. width: 590px;
                That's what is now setting the width of the "table" that holds the messages.
                "They" have changed the coding for the pages, but I have effectively overwritten the new design by pasting in a copy taken from the earlier page design.
                Hope that makes sense … it's bedtime.
                Tomfilery
                  @tomfilery
                  David (Clark),
                  In the main, I don't experience the problem with posts running under adverts and have seen over the past year, or so, the efforts you put into correcting the causes of this phenomena. What I personally find more annoying than the problem is the people who apparently make no attempt to discover what might be causing the problem, nor how to correct it (by searching previous posts – of which there are loads!), before posting their whingeing comments on the forum attacking both you and the website.
                  It might be a good idea for you to post a link, or notice, on the Homepage advising people what to do to correct the problem if they do experience it, thereby avoiding those of us who seldom see the issue (and who clearly visit the site often enough to have seen both problem and recommeded solutions) from being subjected to the infantile comments of those throwing their teddies out of their prams.
                  Might save you some grief in the long run.
                  Regards Tom
                  #94696
                  Ian P
                    @ianp
                    My reply to Tomfilery
                    Your post confuses me, firstly you say that in the main you dont experience the problem although you obviously have seen it as you say its annoying, OK not as annoying to you as the people on this forum that in your opinion have done nothing to find the cause!
                    Quite a few people on this forum have proactively made efforts to solve the problem, even those who make a posting just reporting the problem are in reality trying to find the cause so your opinion about whingeing comments is quite rude really. You then later mention infantile comments and teddies/prams which I find insulting. Just look at the post immediately prior to yours (from M Gilligan) to see an example of what lengths some people go to to try and help.
                    Lastly you state that by searching previous posts the problem can be corrected, I wish!
                    I have probably read most if not all of the posts on this topic, if I followed the advice given in those posts I would by now have changed browsers three times, tried alternative operating systems and bought several computers and undoubtably would still see the adverts overwriting the texts!
                    By the editors own admission the problem exists, I for one do not believe its caused by the forum users and I doubt I am alone in that opinion.
                    If you do know how to stop the adverts overlapping the texts, please, please share it with us all.
                    Ian
                    #94699
                    martin perman 1
                      @martinperman1
                      Gentlemen,
                      I have just read through this thread for the first time, I've also set up " compatability view settings" but I am still getting adverts covering quite a bit of the threads including this one.
                      Martin P
                      #94709
                      DerryUK
                        @derryuk
                        I hate the British at the moment, all they want to do is whinge and moan.
                        That's my whinging and moaning done for tonight.
                        But to those that are having problems, if someone here is using the same broswer as you and not having problems what do you think that suggests? Rhetorical question.
                        I am running Firefox with no problems currently. The only problem I had in the past was the login box too large for it's own box.
                        #94710
                        David Clark 13
                          @davidclark13
                          Hi There
                          Has this cured the advert problem?
                          Michael, how are you posting?
                          I think you are pasting in from something rather than typing it in.
                          The source code for your post was full of unecessary characters.
                          regards David
                          #94717
                          martin perman 1
                            @martinperman1
                            Derryuk,
                            since when is reporting a problem whinging, how else does it get sorted.
                            Mr Clarke,
                            Thank you what ever you did has sorted it for me.
                            Martin P
                            #94719
                            David Clark 13
                              @davidclark13
                              Hi Michael
                              Editing your post has cured the problem.
                              It must be the way you are posting.
                              regards David
                              #94720
                                David,
                                First; apologies for messing-up the shape of this page … it wasn't intentional.
                                What I did [on that occasion only!] was to: Select and Copy the text from the other thread, then Paste it into this thread.
                                It evidently came across as html; and any spurious characters will have been carried over from the earlier post.
                                … As I mentioned last night that includes the width: 590px; that caused the problem.
                                Edited By Michael Gilligan on 18/07/2012 21:12:11
                                #94722
                                David Clark 13
                                  @davidclark13
                                  Hi Michael
                                  590PX is the correct width for the middle of the page. I don't think that caused the problem.
                                  It was all pasted into a table.
                                  That appears to be what caused the problem.
                                  regards David
                                  #94724
                                    Tomfilery,
                                    If the behaviour of these pages was consistent across all browsers, then the solution would be as simple as you suggest.
                                    Unfortunately; as you will see from reading previous threads, it is not.
                                    Somewhere [I know not where] there is a "browser compatibility" problem within the Source Code.
                                      Thanks for your continuing patience, David.
                                      If 590px is the correct width, then I concede; that cannot be be problem.
                                      BUT it was obviously something within that snippet of html, copied from the other thread, that upset this page.
                                      DerryUK
                                        @derryuk
                                        <since when is reporting a problem whinging>
                                        Apologies, I was being dramatic.
                                        I see too much of it's a bad website, why can't Dave sort it out, why don't I get a free gift, not more CAD/CAM surely or if I see another Myford article I'll scream. Rhetorical questions.
                                        When after all it's one of the most interesting and enjoyable sites to visit.
                                        #94748
                                        Terryd
                                          @terryd72465
                                          Posted by Michael Gilligan on 17/07/2012 14:23:59:
                                          There is a good example here … Scroll down the thread to see the problem.
                                          Hi Michael,
                                          Is fine for me – XP (32) with FF14 Beta,
                                          Terry
                                          #94751
                                            Terry,
                                            Thanks for the note; but please be aware that David fixed that particular problem.
                                            Obviously the right thing to do … but it does mean that we are "chasing a moving target".
                                            David's post of 23:08:18 on 17-July, refers.
                                            Edited By Michael Gilligan on 19/07/2012 07:40:10
