Hi Gents and thank you for your speedy replies.
I have been unable using non brutal methods to remove the stiffnut at the top of the spindle.
As there is visible corrosion on the V belt grooves, I guess that the pulley is corroded onto the spindle.
I have also been unable to remove the motor pulley.
I am assuming that the shaft removes upwards and therefore the pulley must come off first.
The pulley will have to be sacrificed to gain access to the top bearing assembly. Once there, should the spindle come out of location with a low force or will the headstock need to be presented to a press to remove it?
With respect to the temperature of the headstock, it is just warm after about 5 minutes under no tooling load conditions.
As in my first post, the lower ball race has shiny balls and a sensible amount of grease visible. But what is hidden above? I was originally concerned that there may have been a corroded plain bushing as well.
Thank you for your help and advice so far,
Mike.
