ajustable vee belt
ajustable vee belt
  • #336439
    geoff adams
      @geoffadams14047
      can anyone tell me what the right name is for the vee belt you can remove links or add links to save having to remove the head stock spindle on a lathe to replace the belt (had some years ago don't know where it went) and where to get it from ebay?
      thanks Geoff
      #33134
      geoff adams
        @geoffadams14047
        #336441
        John C
          @johnc47954
          #336442
          Ian Parkin
            @ianparkin39383
            Sometimes called Brahmer belting i may have spelling wrong though
            #336443
            Ian Parkin
              @ianparkin39383
              Or nutlink belting
              #336444
              Howard Lewis
                @howardlewis46836
                Goes under various trade names, Brammer, T Link etc. Try searching "Link Belting" on Google.
                Just make sure that you are sure of section, (A, B, Z etc) before you order.
                On mainland U K there should be a stockist somewhere near, (Brammer, or a supplier of bearings etc)
                #336448
                John Haine
                  @johnhaine32865
                  Link belt. I have used this on both my S7 and VMB and can highly recommend it.
                  HOWEVER – I have to say that the first lot I bought, from RDG, the black variety, was not very satisfactory being very stretchy and despite being described as suitable for Myford, wasn't! Check carefully what the width of the pulley groove is on your machine – my S7 large-bore needed Z section not A section IIRC.
                  I ended up buying this product from RS, which was 4x the price but works well. They also have A section but costs more. Compared with dismantling the headstock to replace the Vee belts I found the cost OK, but really bought it to get smoother drive.
                  #336453
                  Brian H
                    @brianh50089
                    Good quality link belt is also available from http://www.lathes.co.uk. Usual disclaimer.
                    #336462
                    geoff adams
                      @geoffadams14047
                      thanks everyone for your replies know where to look now
                      Geoff
                      #336467
                      Vic
                        @vic
                        When I first got my Warco VMC mill it was quite noisy but I quickly noticed the belt was very poorly made so I bought a new one for a few quid at Halfords. This solved the noise problem but I often wonder how good the link belts are as they’re supposed to be quite quiet?
                        #336480
                        martin perman 1
                          @martinperman1
                          Fenner make it.
                          Martin P
                          #336481
                          Andrew Moyes 1
                            @andrewmoyes1
                            John (Haine)
                            May I ask, are you able to get your link belt on and off the largest pulley of your big-bore S7 without having to grind a pocket in the headstock casting? Thanks
                            Andrew M
                            #336515
                            Mark Rand
                              @markrand96270
                              I really don't understand why people thing that link belts give a smoother drive thanconvenrional V belts. They don't, in just the same way that a 20W LED tube doesn't give out more light than a 40W Fluorescent tube.
                              Both appear to be an improvement when replacing an old clapped out product, but they are not as smooth/bright as that clapped out product was when it was new.
                              And yes, I have tried brammer Nu-T link belting on an ML7. Most unimpressed.
                              As to not wanting to remove the mandrel of an S7 to change the belt. It's an opportunity to inspect the condition of the bearings, just as it is on my ML7 and Hardinge HLV.
                              Bah Humbug.cheeky
                              #336516
                              Mick Henshall
                                @mickhenshall99321
                                I use link belts on all my machines, yes they do stretch but that is an easy fix, all bought from RDG just a satisfied customer
                                Mick
                                Edited By Mick Henshall on 12/01/2018 22:36:26
                                #336517
                                Muzzer
                                  @muzzer
                                  Bearingboys stock the Nu-T-Link belt. I've no experience of this product but their service for bearings has been good for me.
                                  Murray
                                  #337199
                                  StephenS
                                    @stephens
                                    http://www.lathspares.co.uk have Fenner link belting specifically for Myford lathes if that is what you are looking for it for.
                                    #337200
                                    StephenS
                                      @stephens
                                      Has anyone used this Fenner link belting and have any comments on it ?
                                      Thanks.
                                      #337202
                                      MW
                                        @mw27036
                                        It really isn't that hard to measure up the distances and get a decent rubber belt. It will be made to a much nicer quality than any of the "adjustable" variety.
                                        Michael W
                                        #337204
                                        Roderick Jenkins
                                          @roderickjenkins93242
                                          The old original belt on my S7 started turning itself inside out so I replaced it with the pink Fenner Powertwist. 2 minute job to replace the belt and it works a treat. I've had the belt in stock for a couple of years waiting for the old belt to give up so I can't remember where I purchased it, probably Simply Bearings. I have tried the plastic link belt from RDG on my milling machine and was unimpressed.
                                          Rod
                                          #337205
                                          not done it yet
                                            @notdoneityet
                                            The link belt on my compressor has been on for well over thirty years, so can’t complain on that score. I would have used linked belts for my lathe a couple of years year ago, but the spindle was out, so normal V belts were the cheap option and they would see me out.
                                            I think one can perhaps fare better if running a single solid belt rather than a linked belt but my lathe had twin belts so no worries about fluctuating spindle speeds.
                                            Now I have changed my model, if it were to need new belts, they would be the linked variety – unless the spindle had to be removed at the time.
                                            #337212
                                            Hopper
                                              @hopper
                                              Another good alternative to conventional V belt is the cogged V-belt, see pic. Grips better than a standard V belt but uses the standard pulleys, bends easily around the standard small pulleys used on Myfords etc and does not need as much belt tension to get good grip, so gentle on bearings. Of course, spindle must be removed for installation. My son and I recently fitted these to the ML7, both headstock and motor belts, and they run very smoothly indeed.
                                              #337223
                                              John Haine
                                                @johnhaine32865
                                                Posted by Andrew Moyes 1 on 12/01/2018 18:16:18:
                                                John (Haine)
                                                Andrew M
                                                Yes!
