Plug in Solar
Plug in Solar
Home › Forums › The Tea Room › Plug in Solar
Viewing 25 posts - 1 through 25 (of 97 total)
  • #842303
    Vic
      @vic
      #842306
      Robert Atkinson 2
        @robertatkinson2
        Wow, ” 340kW produced per unit”!  Thats 14 times the maximum power from a standard (100A) UK mains supply. And only £450, it’s almost unbelievable……..
        On a serous note, plug in solar power are NOT LEGAL in the UK at this time (March 2026).
        Robert.
        #842307
        duncan webster 1
          @duncanwebster1
          They claim 340kW per unit (presumably panel). That needs to be taken with a shovel full of salt, never mind a pinch.
          Robert beat me to it
          #842308
          Oldiron
            @oldiron
            Read further down. It says ” recharge from the sun 340W Solar unit. So 340kw is probably a typo.
            #842309
              Further down the page they give a more realistic 340W per panel. maybe a (deliberate) typo?
              #842311
              howardb
                @howardb
                #842318
                Vic
                  @vic
                  #842321
                  paul1956
                    @paul1956
                    It is envisaged that the rules concerning the concept of plugging a potentially live 13 amp plug top into a house domestic socket will be modified soon.
                    From what I’ve read; These panels will never offer mains power on an exposed pin. They will only generate power when they are plugged into a live mains supply.
                    Firstly that prevents a ‘dead’ circuit being energised which would be dangerous if being worked on.
                    Secondly the invertor for the panel will need to lock it’s output frequency to that of the mains before sending any power.
                    So they won’t be any use as back ups for power cuts by themselves.
                    #842333
                    Vic
                      @vic
                      #842337
                      Roderick Jenkins
                        @roderickjenkins93242
                        It’s called islanding.  Google explains it succinctly:
                        “Solar islanding occurs when a grid-tied solar system continues to power a local circuit during a utility outage, creating a dangerous “isolated island.” Anti-islanding protection is mandated to immediately shut down inverters during outages to protect workers and equipment, though intentional, safe islanding is possible with specialized battery-backed hybrid systems.
                        Key Aspects of Solar Islanding
                        The Danger (Unintentional Islanding): When the utility grid goes down, solar inverters might fail to detect the loss of power immediately, continuing to push electricity into the grid. This creates a severe risk of electrocution for utility workers who believe the lines are de-energized.
                        The Solution (Anti-Islanding): Solar inverters are legally required to have anti-islanding mechanisms. These monitor voltage, frequency, or impedance to detect grid failure and disconnect the inverter within seconds.
                        Intentional Islanding (Backup Mode): With a hybrid inverter and battery storage, a system can legally break connection with the main grid and operate in “Island Mode” (or EPS mode). This provides power to the home while safely isolating it, preventing energy from feeding back to the grid.
                        System Requirements for Intentional Islanding: To operate in island mode, the system usually requires a manual or automatic transfer switch and a dedicated earthing arrangement.”
                        Rod
                        #842342
                        howardb
                          @howardb
                          A friend over here in France tried one of these “plug in solar” kits a couple of years ago thinking it would reduce his domestic electricity bills. I think it’s output was 100 to 300 watts.
                          I did warn him about the necessity of ensuring that the plug might be live and to keep his fingers away from it while plugging it in.
                          However, his results with it weren’t great and then the inverter failed and would cost more that the whole thing was worth to replace, so he gave up on the idea.
                          He is now going to use the two solar panels to charge a lithium powerbank which accepts 12 volt charging, and includes an inverter, to power up his small caravan.
                          #842344
                            The obvious problem, with plugging in, is that the item is beyond the circuit fuse.
                            Adding huge amount of power beyond the fuse could mean the circuit wiring could be loaded with its full power (through the fuse) plus the extra power injected beyond the fuse!
                            The current requirements are that the solar generation is fed to the consumer panel and then distributed, to wherever needed, through circuit protection fuses.
                            #842351
                            Nealeb
                              @nealeb
                              I’ve been looking at solar panel plus battery systems recently. I live in a rural area with overhead cables feeding this little group of houses so power cuts in bad weather are always a possibility and one of my requirements is the ability to power the house independently. Ok, maybe no high-consumption cooking but running central heating, keep PC and phones live, etc, would be good. I’m told I need a “gateway” box between incoming mains and my own system which I presume does the power-present, grid-disconnect stuff. I’m still not quite sure how the inverter and power control electronics handle frequency sync and pushing power back up the lines. But then, my background is electronic and not electrical engineering and this power stuff and anything over 12V is beyond me…
                              #842355
                                These ‘instant’ solutions are bound to be very bad value for money and expensive if not impossible to repair in two years let alone ten.
                                Do the maths. Excluding fridge and heating and all day TV you perhaps use 2KWh per day, hopefully less. (modem, alarm, laptop, radio, LED lights).
                                Battery only you could charge on cheap rate overnight and use it during the day. The difference between day and night rate might be 20p per KWh, so 40p per day saved. (to simplify ignore that some of the time is direct off night rate) Max saving is £150 per year.
                                If it actually lasts ten years you have to then buy a new one, so need to save at a rate of 10% ready for the new one, plus pay interest on the money for the current one at 5%, ie 15% total. (ignoring the interest on the savings to simplify). This equates to about £700. Can you buy a battery that delivers 2kWh every day for 10 years? NO. They typically quote 1000 cycles.
                                That is all before you get enough solar panels to deliver 2kWh/day in winter.
                                #842357
                                howardb
                                  @howardb
                                  You need to decide whether or not you want to get involved with the cost and complication of what is called a “grid tied” system.
                                  If you just want a simple “off grid” system used as a manually or automatically switched emergency power supply using solar panel + battery + inverter it will be simpler and cheaper.
                                  IE – The solar panel charges the battery through a charge controller,  the inverter 12 volt input is connected across the battery and it’s 230 volt ac output is switched to the house safely via a changeover switch.
                                  https://www.grid-neutral.co.uk/blog/selling-solar-electricity-back-to-the-grid-in-the-uk
                                  #842359
                                  howardb
                                    @howardb
                                    “This equates to about £700. Can you buy a battery that delivers 2kWh every day for 10 years? NO. They typically quote 1000 cycles”
                                    10 year/ 4000 cycles warranty
                                    12V 230Ah LiFePO4 lithium leisure battery
                                    Built in cell balancer
                                    Will run a 2500 watt inverter
                                    €746.90 inc vat (in euros) in sterling ~ £ 649.47
                                    https://www.12voltplanet.co.uk/fogstar-drift-seat-base-12v-230ah-lithium-leisure-battery-with-active-balancer.html
                                    A decent reliable supplier – I’ve dealt with them.
                                    #842385
                                      Interesting link Howard. Thanks.
                                      #842393
                                      Nigel Graham 2
                                        @nigelgraham2
                                        Apart from the purely technical problems, any attempt to use some sort of power-supply merely plugged into the mains could invalidate your home insurance due to the shock and fire hazards.
                                        #842396
                                        vic newey
                                          @vicnewey60017
                                          Would one of those power an immersion heater in my hot water tank which is currently heated by gas, or at least keep add a bit of heat during the day
                                          #842400
                                          paul1956
                                            @paul1956
                                            #842403
                                            Wink Hackman
                                              @winkhackman25989
                                              #842404
                                              Mark Rand
                                                @markrand96270
                                                It would be nice if some folk bothered to read the specs.
                                                340Wp. Estimated 340kWh/per year in the midlands (which is a reasonable and common approximation). 20 year warranty. integrated grid-tied inverter.
                                                The price is unattractive, but is roughly comparable with roof mounted plus inverter plus installation.
                                                Government plans to make the concept legal ‘within months‘.
                                                #842408
                                                howardb
                                                  @howardb
                                                  #842412
                                                  Mark Rand
                                                    @markrand96270
                                                    You think that a country of 1.4 billion people, with the world’s largest GDP (PPP basis), that makes almost all of the consumer electronics that we use, suddenly can’t make a safe grid tied inverter, when they’ve been making ones approved for UK, EU and US installation for a couple of decades?
                                                    #842413
                                                    Robert Atkinson 2
                                                      @robertatkinson2
                                                      I did read the datasheet. It’s pretty useless but does not repeat the kW error on the main page.
                                                      Their example sums are pretty suspect too:
                                                      “Over the course of a year the Solar Unit generated over 300kWh of energy and reduced the electricity bill for the property by nearly £100 for the year”
                                                      That equates to 33p per kWh but the energy cap is 25p per  kWh.
                                                      It also indicates a completly unshaded location.
                                                      Even under the proposed new rules these units would not be approved as they ues an internal inverter and can be daisy-chained.
                                                      They do have a patent but it’s for a floating support and some of the claims are a bit odd. https://www.search-for-intellectual-property.service.gov.uk/GB2617582/documents
                                                      There is no mention anywhere of conformity to any regulation or standard that I can find.
