On Thuresday I was cutting some blanks for my dividing head plates and the saw just stoped whilst the motor was still running. I was aware that one of the drive gears were brass and could wear so suspected the worst. I pulled the plug and removed the cover to the drive gearbox and the oil looked like aa brass colored sparkly fluid and after I had removed enough to see what was going on it was obvious that the brass gear was worn away. and the screw gear was not driving the gear.
I worked out that the pullies and cover needed removing to get to the flange and two screws that held the shaft to the drive screw in place. With a small crow bar I was able to push the gear clear of the brass round gear. II made aa call to Chester machine tools and they had a spare and they posted it the same day to me and it arrived 11. 00 next morning.
The replacment gear.
The Worn gear was held by a key and a grub screw which when loose was levered off with a 90 degree lever and packing pieces. It took quite aa time to clean out all the bits of broken gear teeth and brass powder mixed with thick gear oil but after it was clean time to start assembling. I put the brass gear on first leaving the grub screw loose for the time being and tapped the drive shaft in slowly spinning the brass gear as it went in till gear bearing was flush with outside of case and all spinned free. I tightened the grub screw the cover and the pullies were replaced in line. When the belt was fitted adgusted and bolted I tested the motor and it went great. All I had to do now was sill the gearbox with 80 gear oil replace the cover and it cutts steel plate as good as before.
David
