What Did You Do Today 2026
Home › Forums › The Tea Room › What Did You Do Today 2026
Viewing 25 posts - 226 through 250 (of 257 total)
  • #870922
    Mark Rand
      @markrand96270
      Picky, picky, picky.
      #870977
      jaCK Hobson
        @jackhobson50760
        At first i tried to make stick-on lables look good but I failed and now don’t bother at all. They look better than my handwriting. I added more yesterday but in between I found this square in my discard pile in a very bad state – rust and cracked and chipped wood with big gap between brass and wood. Now I’m retired, I need to fill time so I gave it some attention. Now it is my favorite small square – the 100+ years of wear make it fit the hand so well. I’d say it is not ‘as good as new’ but better than new.856009073_10245136042320239_5743430812779090561_n
        #871147
        Julie Ann
          @julieann
          On Bazyle Said:
          Having got as far as reading the 3D Metal Printing article in the latest ME&W I’d like to thank Julie for the detailed scientific assessment of the properties of printed metal that are otherwise completely unknown and not otherwise readily available.
          I’m a bit slow off the mark and have only just seen this comment. I am glad that the article was interesting and ideally useful. Look out for part 2, even more information!
          Julie
          #871155
          Andy Stopford
            @andystopford50521
            Julie
            Yes, I found it interesting and useful too. Having just had a couple of things 3D metal printed, I’m impressed by the quality and it’s good to have some assessment of the mechanical properties.
            Not metal printing, but this is what I did today:
            20261024_15031320261024_150350
            Annoyingly, I forgot to label the box spanners with their sizes, but I use the spanners and sockets more so I don’t suppose it matters too much.
            #871167
              I did mention your article in the “First for ME&W” thread Julie
              And on the subject of 3D printing I added some machining allowance to a couple of files about 2 weeks ago and sent them to another modeller. He just sent me this. Better finish than most castings, passages all “cored” and even stud holes laid out.
              #871176
              Speedy Builder5
                @speedybuilder5
                Andy, they look rather good, I have sent you a PM.
                Bob
                #871241
                Dalboy
                  @dalboy
                  Very nice Andy wish I could understand CAD programs then it would be worth investing in a 3D printer.
                  Just out of interest does the BA spanner set have a 5 BA size LOL
                  #871275
                  Andy Stopford
                    @andystopford50521
                    Thankyou,  Dalboy,  and well done for spotting my,  ahem,  deliberate mistake
                    #871288
                    Dalboy
                      @dalboy
                      It may have been a slight oversight but still better than I could have even done again well executed
                      #871348
                      Andy Stopford
                        @andystopford50521
                        Oversight? Me?
                        20261025_172254
                        I would have used it anyway, but the design of the hinges and latch wasn’t robust enough, so now it serves as a parts tray, mercifully inverted.
                        #871422
                        Dave S
                          @daves59043
                          Made a hefty parallel adjustable table for the next steps in Guilloche.
                          started as a couple rough blocks:
                          IMG_9863
                          did a bit of machining,
                          IMG_9866
                          surface ground the important bits, left the rest as homage to the Earl of Sudspumpwater.
                          IMG_9872IMG_9871
                          came out ok:
                          IMG_9873
                          Will end up with holes for dial pins. Then I can mount an actual dial and level it to the machine travel for the Guilloche cutting.
                          Sonic Escape
                            @sonicescape38234
                            Today, I cut a slot across the length of this chunk of metal that I use as a tool post. Now I can also attach a boring bar. Next, I cut some shims. I bought these ones, but they are too wide.
                            111Screenshot 2026-11-01 130936
                            #872519
                            Nigel Graham 2
                              @nigelgraham2
                              No workshop duty apart from trying and failing to find the gaskets and gasket-cutters I made for my loco’s superheater header. So that’s still work in too-slow progress.
                              However, after also dredging duck-weed and sludge from the frog-pond, and running shrub trimmings to the tip, I spent a couple of hours or so sort of CAD assembling the engine into the chassis for my steam-wagon.
                              I had necked the physical chassis rails inwards to allow the front wheels to steer, but could not have envisaged starting the bend too far back (and too many years back) would seriously cramp the location for the transmission gears yet to be, and create an awkwardly-angled mounting for the machinery.
                              Unfortunately I can only guess the full-size frame’s shape there, but am now considering a new chassis re-shaped to overcome the problem.
                              How, though?
                              One option:
                              There is a trailer manufacturer not too far from home. I could ask if they can make new channels to that new shape for me. These would likely be folded, so I might need laminate the back of the visible areas with thin sheet-steel and filler to more nearly resemble the prototypical structural channel.  The present frame’s hot-rolled 50 X 25mm channel is near enough scale generally (one-third 6″ X 3-ish”) but over-scale thickness and very heavy. 50 X 25 X 2.5 or 3mm would be about right without being too weak; perhaps 2mm with judicious doubler-plates where necessary.
                              Eeh, one snag after another.
                              Still, I learnt another little aspect of Alibre ‘Atom’. I’d not previously spotted you can re-name the planes and axes to mean things, so spent a little time thus engaged.
                              E,g:  expand “Axis <6>” to “Axis <6> Weighshaft”
                              #872560
                                Can’t you just weld two lengths of 25x25x3 together to form a channel section?
                                20170331_165657
                                DSC01851
                                DSC01859
                                #872597
                                Dalboy
                                  @dalboy
                                  After a 2-week chest infection I managed to get back in the workshop to tidy up after the last machining operation. Hopefully back on the Rob Roy now things have improved.
                                  I still can’t get out full time as need to look after the wife as she has gone down with bad flu, I wouldn’t mind, but we rarely go out and mingle much.
                                  Some new draw lining arrived as well so need to get that in the draws
                                  #872622
                                  Nigel Graham 2
                                    @nigelgraham2
                                    Jason –
                                    Fabricating…
                                    I made the H-section front axle, about 16 inches long, by welding 2 pieces of folded channel back-to-back.
                                    I have thought of that for the frames. They are about five feet long and I am not sure it would be “just”, with my welding, but it’s certainly an option. I have both an open-arc welder (ideal for users with “Essential Tremors”) and a small “gasless” MIG welder.
                                    The latter heavily spatters the surroundings but that can be controlled with anti-spatter spray. The bead would need grinding flat anyway, but it would give a closer appearance to full-size. Most of the frame is hidden anyway by the superstructure.
                                    #872641
                                    duncan webster 1
                                      @duncanwebster1
                                      On duncan webster 1 Said:
                                      On duncan webster 1 .
                                      ……. Then got distracted into putting a curtain rail back up, must tell 3 year old grandson that swinging on curtains is not a good idea
                                      Well that didn’t go as planned. Over the window is a Catnik lintel, which has perforations in the web to allow about 20mm of plaster. I managed to cut down some rawlpugs to mount the curtain rail, which held for years until 3 year old grandson got involved. The latest cunning plan was to glue some 100mm dia wooden pads to the plaster and screw the brackets to those. It held for a couple of hours, but the skim plaster has now parted company with the browning depositing the whole shebang on the floor. Back to the drawing board. I’ve temporarily mounted the brackets higher up above the lintel, but this does not meet with distaff approval. I need some way of securing to the steel lintel. Any good ideas? Knowing my luck if I try drilling through I’ll come halfway into an existing perforation which will drag the hole sideways. Last resort is to chip away the plaster, drill and tap holes where perforations aren’t (or perhaps use those spring out wings plaster board fixings), bolt wooden pads on and plaster round, but it all feels a bitt OTT.
                                      Got dragged back onto this job by SWMBO, decided to use Rivnuts. Didn’t buy the tool as only half a dozen to fit. Wasted a lot of time trying to fit the rivnuts using a long bolt with a nut and spacer. problem is that the friction twixt nut and spacer makes the spacer and the rivnut rotate even tho preventing the long bolt from rotating. Fitting a thrust bearing made the job easy. Used a normal deep groove bearing insted of thrust race because I had one left over from when #2 son was into roller skates. The bolt is M6 turned down to M5 at the end to suit rivnut, again because I had one, and I’ve got 2 off 13mm spanners, one a lot longer than the other which makes life easier. The assortment of spacers is because I’m working down a hole in the plaster
                                      1000017936
                                      #872650
                                        Duncan, rather than cut plugs short when they hit the steel and hope the plaster takes the weight, change to an old but sharp 6mm twist drill and drill into the lintel. Now push a full length plug in and it will expand nicely in the steel. Just done one like that this morning for a client.
                                        Made three circulatr patresses from 12mm MR MDF so I could use some decent size screws and have a bit of flexibility in position and allow for drill wander. Then fixed the circular base of the brackets to the patresses with smaller screws that suited the CSK holes in the bracket. Painted the pre primed pateresses with some of the wall colour emulsion.
                                        #872664
                                        Andrew Crow
                                          @andrewcrow91475
                                          When I had a problem with poor fixing, I used a piece of steel strip 12 x 5 section to which I fixed the actual curtain brackets but long enough to find a firm fixing further down the wall. As it’s behind the curtains it’s can’t be seen. If you need a centre support bracket, do something similar which enables you to screw into the bottom face of the lintel.
                                          If the plaster has been damaged and needs replacing try wedging some wood into back of the lintel prior replastering to which you can then fix into.
                                          Andy.
                                          #872681
                                          duncan webster 1
                                            @duncanwebster1
                                            I thought I’d made it clear, job’s done with rivnuts. I thought of drilling into the lintel through the plaster, but knowing my luck I’d hit one of the existing holes half and half and break the drill or finish up with a skewwhiff hole.
                                            #872775
                                            Andrew Crow
                                              @andrewcrow91475
                                              Duncan, my apologies for giving alternative solutions to your already solved problem. However, as this is a forum for discussion, it automatically invites comments and suggestions from others.
                                              Also, there may be others who have a similar problem and don’t have or wouldn’t want to use rivnuts, so a few alternative ideas should always be welcome.
                                              Best regards,
                                              Andy
                                              #872917
                                              Nigel Graham 2
                                                @nigelgraham2
                                                An expedition to Lyme Regis – early Christmas shopping and to visit the restored water-mill, run by a volunteer trust and producing flour for sale for its funds.
                                                It was indeed milling, producing spelt flour on one of the two pairs of stones, this day.
                                                The mill also produces its own electricity by a separate turbo-alternator set, producing somewhere over 3MW/yr, if I recall the information-board correctly. During droughts that significantly reduce the River Lim, the turbine is closed to avoid starving the mill-wheel.
                                                I learnt the modern, industrial-pattern safety-grab cable running along the fences betwixt visitors and machinery, will cause the hatch on the over-shot launder to close immediately, stopping everything. (The hydroelectric plant will still run as that is totally separate, and though visible is safely caged.)
                                                Spotting a shiny strip of metal on the stone shaft, I asked its purpose. The miller explained it’s used to help trainee millers to judge the speed, about 60rpm. They have a digital tachometer that will detect it, but he said they rarely need use it.
                                                I didn’t suggest they could also tell the speed by the three-four time screech rate of the rather noisy “damsel”. This is a sort of cam that oscillates the chute passing grain from the hopper to the centre of the stone, to give a carefully-set feed-rate. The effect is a bit like tapping a scoop to sprinkle the contents gently.
                                                Free admission; donations and/or purchases invited. Open only 4 hours a day.
                                                The surrounding buildings, once grain-stores etc. now host other businesses: a potter, art-gallery. Oh, and a small brewery; and it’s strange how watching fine old machinery working as it should, induces thirst…
                                                [I should say I had only one pint of the very nice ‘Lyme Cobb’ bitter… I was not driving but was faced with over an hour bus ride then fifteen-minute walk for the journey home!]
                                                #873907
                                                  IMG_2174
                                                    Screenshot 2026-11-10 at 18.43.55
                                                    John Haine
                                                      @johnhaine32865
                                                      Nigel, do you mean 3 MWhr per year? I think that works out to 342 watts or 1/3 of a 1-bar fire.
