For my Myford 254+ which is 5″ centre height I used a Hemingway kits large capacity fixed steady kit, as the correct steadies are hard to get and hugely expensive if they are ( one went for £300 plus on ebay a few years ago). For my size lathe they supply a mounting block to raise the centre height, it was fairly quick to make and does work extremely well. If you could get a slice of the capstan base mentioned by Alan above it would be a fairly easy project to fit the Hemingway steady to your Bantam. I did have a couple of moans about the rusty studding supplied with the kit and brass supplied instead of the bronze specified on the drawings for the ends of the fingers. I never got a response from the old Hemingway, but was told by a friend who bought one later they changed the spec on the drawings to brass!
I just looked on the new Hemingway website and they are still supplying the kit, but was a bit shocked at the price increase since I bought mine about five years or so ago, not far off doubled. Good luck with whatever you decide to do.
