LSBC Mollyette
LSBC Mollyette
Home › Forums › Drawing Errors and Corrections › LSBC Mollyette
  • #67552
    Dave Jones 1
      @davejones1
      Just one I have noticed this evening. The myhobbystore plans shows the centre of the cylinder bore being 1/8″ from the top of the cylinder. Its not! it should read 1/4″. The original shop notes are however correct.
      Ill add anymore as I find them (hopefully not the hard way like this one!)
      Dave Jones 1
        @davejones1
        #67553
        Colin Jacobs 1
          @colinjacobs1
          Just like old Meccano plans they used to put mistakes in on purpose to see if the builder could overcome them and send in the corrections.
          #67578
          Dave Jones 1
            @davejones1
            In that case, they can buy me another 5/8″ square block of brass 7/8″ length!! Unfortunately I found this one too late!
            I was hoping for a nice tried and tested design, thinking that over the last approx 70 years the errors would have been corrected. Oh well, I’ve started so Ill finish!
            On the plans, there is no indication on where the steam inlet is on the steam chest, from the construction notes it is “is made on the underside [of the valve chest], in the middle, and is 5/64 in diameter, or No. 48 drill.”
            #67579
            John Olsen
              @johnolsen79199
              The mistakes are probably not actually deliberate, but as you have just learned, they never ever get corrected. Or if there is any correction, it will be in a letter to the editor in a magazine 55 years ago.
              regards
              Sam Stones
                @samstones42903
                To pick up on Colin Jacobs’ point.
                Back in the 70’s, I built my first computer from a kit of some 50 plus IC’s, which were to be soldered onto a large mother board. The retail outlet who sold the kit, had a standing offer of $25 to fix any problem (within reason), should the kit fail to work.
                Perhaps not trusting my own soldering ability or that I preferred a neater solution, I elected to solder IC sockets to the mother board, and then to plug the relevant IC’s into their respective positions. Unless I bent a contact pin during this latter step, I was fairly confident that none of the IC’s would become damaged or were over heated.
                As I progressed through successive stages of the build, it was possible (using a CRO) to check the waveforms being generated. It was only during the final stages of the build that it became clear, something was not right.
                Also, having built most of my brass skeleton clock by the time I started on this computer kit, I was heavily into using a 4″ binocular magnifier. It was through my new-found `hawk-eye’ ability that I noticed a tiny gap in a single copper track. Although almost invisible to the naked eye, to say that the gap was conveniently placed for anyone to bridge it with a dab of solder would be an understatement.
                $25 Hmmmm?
                Or was it just my suspicious nature?
                Sam
                Edited By Sam Stones on 27/04/2011 07:40:00
                #67983
                Dave Jones 1
                  @davejones1
                  One more so far… The plans say the ports on the cylinder should be drilled 3/64″ centres. No my friend, 9/64″ as per the original articles.
                  RichardN
                    @richardn
                    I don’t suppose you have a note of the original articles?  I see Sarik are selling the plans, but not the words…
                    #849481
                    duncan webster 1
                      @duncanwebster1
                      According to Google you need ME  for 1943
                      #849489
                      RichardN
                        @richardn
                        Your Google-Foo clearly beats mine, but that gave me enough – looks like 2207 and 2208 from Vol 89 (1943 indeed).
                        thanks!
                        #849490
                        Nicholas Farr
                          @nicholasfarr14254
                          Hi RichardN, just looked at my mags, and yes you need 2207/08 Vol 89 Aug 26 & Sept 2 1943.
                          Regards Nick.
                          #849493
                          RichardN
                            @richardn
                            Thank you!
