Bassett Lowke 2 1/2″ A1 progress report
Home › Forums › Locomotives › Bassett Lowke 2 1/2″ A1 progress report
  • #874475
    AJBAJB
      @ajbajb
      Some of you might recall my posting a few years ago regarding a B-L A1 I had inherited in an unfinished state, and my initial desire to just restore as a static. Part of that was driven by some of the negativity that seems to surround this particular model, but thanks to the encouragement and help from some of the members on here (you know who you are) I decided to see if this venerable old girl could in fact be restored to steam.
      I thought I’d provide an update, partly to try to connect with a couple of other members who were restoring the same model – I’d love to hear how you got on – and partly ‘just because’!
      In short, after some sterling work on the original Smithies boiler, some excellent re-engineering of the chassis, a new tender body and some very necessary fine-tuning all over, I now have a locomotive that will pull up trees! She has run beautifully on a G3 track a couple of times (unfortunately sandwiched by a mechanical failure that resulted in a rather embarassing flare-up during her official steam test) and is ready for some over-winter improvements (she was quite poorly constructed initially, and A1 experts will spot some strange anomalies in the photo below) before painting and lining. She has even hauled a driver around a local track in a never-to-be-repeated experiment.
      My thanks and gratitude to those who have supported and worked on this journey. My engineering skills are limited – but have improved a hundred-fold over the past few months – and the message to anyone else out there who is restoring one, or is reticent about what it might be capable of, is to crack on.
      Meanwhile, if anyone has any of the obvious missing parts to hand, I’m all ears!
      A1 progress
      #874509
      Nigel Bennett
        @nigelbennett69913
        Excellent! It’s great to see an unloved pile of bits do what it’s supposed to do. There must be so many of these things that end up somewhere unpleasant – where do they all go? Bassett-Lowke obviously made these to a price, so you get what get…
        Well done for persevering with it – and if there’s anything that bothers you about the “anomalies” – and it’s not obvious to me – then if it bothers you enough, you can always do something about it. Don’t spoil its originality though, just for the sake of fidelity to the full-sized job unless you need to.
        #874512
        AJBAJB
          @ajbajb
          Totally agree with your point about fidelity – the biggest stumbling block for me was getting over the idea of detailing and refinement to make this a finescale A1 model. Eventually I realised that it’s an inaccurate, but nevertheless still remarkable, feat of model engineering (and a family legacy) and deserved to be given a chance to show what it was intended to do. Not sure how the designer made so many mistakes – the driving wheels are far to small diameter – so putting things like that right would have created a domino effect of modifications.
          I wish I’d understood more about why my Grandfather (a toolroom superintendent at the Austin, hence highly experienced with metal) and my Father (a prolific OO gauge modeller) both shunned it. I guess setting light to meths felt a bit too much like science rather than engineering to them. The only conversations were of the ‘you don’t want to go near that’ ilk.
          I never was one to listen…
        Home › Forums › Locomotives › Topics
