I hope one of you very knowledgeable chaps can help. The tailstock barrel on my Mk.1 Super 7 has started to rotate. When I took a look on mine the key lock is a two piece affair which appears to be inserted from the outside and wedges together and looks like it has worked its way out a bit. It does not look particularly worn. Would I be right in just tapping it back into the hole (aligned with the barrel of course)?
I also remember buying a replacement bit to make an order up once but this looks like it is inserted from inside the barrel. Is this a later modification in how this works?
The Mytholmroyd Myford web-site shows that the tailstock keys for the Super 7 and the ML7 are different. In fact, they give two separate part numbers for the ML7 key.
Thanks for the replies. Very helpful. Interestingly the spare that I have (which I managed to find) is one piece and has the 'ears' as described. The one that is in there though was clearly designed as two pieces and is not a broken version of the spare I have. It is similar to the replacement without the ears but the whole thing cut diagonally so as it is tapped in it would tighten in the hole. I wish I had taken a picture now but I tapped it back in and the barrel won't rotate now. If it works loose again I will see if my spare fits.
Matt
Author
Please log in to reply to this topic. Registering is free and easy using the links on the menu at the top of this page.
