Mystery tool, What is it for,??
Home › Forums › Beginners questions › Mystery tool, What is it for,??
  • #76616
    Charlie,
      @charlie18171
      Right Chaps
      Here we go, I have an item that i bought from a car boot for a
      fiver,I asked the bloke what it was and he said he didnt know
      and said if he did he would have asked more for it,I liked the
      look of it and bought it thinking that i would soon work out
      what it was for,But it didnt happen, I still dont have a clue,
      It has a number stamped on it and a weakly stamped symbol
      which i cant make out,Its been with me bout five years and i
      have shown it to many engineers, Some qualified and some
      not quite so qualified, Not one of them came up with a plausible
      answer,Its a nice looking thing but right now it just a usless
      onerment, And i may dismantle it and use the bits for other
      things,A die stock looks like a contender for some of the bits,
      Can anyone out there save it from a fate worse than death,
      I  have pics of it in my album,
      Edited By charlie on 21/10/2011 23:09:12
      #5712
      Charlie,
        @charlie18171
        #76618
        Jeff Dayman
          @jeffdayman43397
          It might be an orbital riveter or stud header of some kind. Is the hole in the working end dome shaped? If so that is probably what it is. Could be very handy if you’ve got a bit of riveting to do.
          Might be something the guys at the airport maintenance hanger might recognize.
          JD
          #76620
          David Colwill
            @davidcolwill19261
            Some kind of device for tapping small holes?
            #76621
            NEIL SMITH 1
              @neilsmith1
              A floating tap holder.?
              #76622
              AndyB
                @andyb47186
                Is the nose piece split? It looks as if it is in the photo; in which case it could be a tailstock collet chuck.
                Someone took a lot of effort to make it. It would be shame to break it for parts if you have already kept it so long.
                And, of course, 10 minutes after irretrievably having done so, someone would recognise it, and it would turn out to be the most useful thing you have ever possessed…how do I know…???
                Andy
                ps. I wanted to add a glum emoticon and it says the area I am trying to access is forbidden!
                Edited By Andy Belcher on 22/10/2011 07:52:38
                #76624
                Speedy Builder5
                  @speedybuilder5
                  Looks like a tool to bell the end of a soft metal (Brass ?) tube to form a rivet head. The nose piece would start the belling out, and the sprung loaded cap would finish the head off ??? Looks like a super test piece for a toolmaking apprentice !!
                  #76678
                  Charlie,
                    @charlie18171
                    Hi Andy
                    Yes the nose peice has what look like equaly space punchings,Which
                    leaves a small space under the main mandrell,In the past it has been
                    sugested that a cutting tool should ocupy this space and protrude through
                    the punchings to cut metal,But i cant see that it would do anything that a
                    large ball nosed cutter wouldnt do,Yes Robert it would make a good test
                    peice,If i could machine that to exact spec most of what i do would be a
                    lot nicer,Well now it seems that no definitive answer is forth comming,
                    What i was hoping for was for somone to Post saying OOH I know what
                    that is, Used to use one every day at my place of work, But its not hapening
                    So as Andy says the only way to find out what it is is to cut it up for stock
                    And the next day somone will tell me what its for,
                    Charlie,
                    #76683
                    Charlie,
                      @charlie18171
                      Hi Malk
                      Thanks for your input,Button making, At least thats a new thought,
                      As good as any i have had so far, My knowledge of the item is sutch
                      that i cant agree or disagree with any of the sugestions made so far
                      but i do feel that no one has won the coconut yet,
                      Charlie,
                      #76690
                      KWIL
                        @kwil
                        Could you take a better photo of the numbers and symbol, prefereably as near to full frame as you can get?
                        #76719
                        Sub Mandrel
                          @submandrel
                          I wonder it it is for making one half of the large eyelets used in tarpaulins etc., forming them from discs of sheet brass.
                          Bear in mind it may be designed to operate vertically in a mill, rather than in a lathe.
                          Les Jones 1
                            @lesjones1
                            Hi Charlie,
                            Could it be that ball beadings should be fitted under the pear shaped holes in the end cover ? As the end cover is screwed in the balls would move up the taper and could grip the inside of a tube to support it at the tailstock end. Sort of a rotating expanding mandrel.
                            Les.
                            #76734
                            Charlie,
                              @charlie18171
                              Hi chaps
                              KWIL, Yes i will attemt to take a better pic of the serial numbur and the
                              motive although the motive is only faintly stamped,What i can see of it
                              looks vuagly familiar, I have an idea that i have seen that motive before
                              Posibly on an east German greasgun that i used to own,But i will do my
                              very best with the pic,But i havent found out how to use the flash on my
                              new camera,Its one of them with all the bells and whistles, Its got buttons
                              everywhare and i got big hands, I have a job picking it up without pressing
                              a button or changing a setting,Come back the Box brownie, All is forgiven,
                              Neil and Les, Have taken you sugestions onboard, You chaps have
                              realy been thinkin outside the box
                              Charlie,
                              #76811
                              Charlie,
                                @charlie18171
                                Hi KWIL,
                                Have taken one more pic of the mystery item showing information stamped
                                on it, I am sorry there is not to mutch to see, I cant photograph what is not
                                there,It is plainly roll stamped and to go to the trouble of setting up a roll
                                stamping process would indicate that there would have been several of
                                t items about, maybe even a hundred or so, So whare are they and who
                                is using them?,
                                Charlie,
                                              The new pic is in my what is this album,
                                Edited By charlie on 24/10/2011 20:33:23
                                #76972
                                John McNamara
                                  @johnmcnamara74883
                                  Hi All
                                  My Guess is it is not quite complete. I suspect there are small rollers that fit in the slots. There appears to be a track marking where the rollers ran on the apparently ground inner part.
                                  That explains the taper on the inner part also as the tool was fed in the rollers would be forced out.
                                  Could It have been used to flare the ends of heat exchanger tubes after they are installed?
                                  Cheers
                                  John McNamara
                                  #76978
                                  Charlie,
                                    @charlie18171
                                    Hi John
                                    You are not the first person to sugest that the item is incompleat,And you
                                    have looked at it realy closly to notice the wear marks on the front end of
                                    the mandrell, Most people miss that small clue,So i have to say that your
                                    sugestion on what the purpose of the item is is probably the most
                                    plausable i have had,So you win the coconut,I thank all of you chaps for
                                    your contributions,I have to add that i have over several years of going
                                    to car boot sale and auctions etc, aquired a number of unidentified
                                    engineering related items, So from time to time i will submit one or two
                                    to this very usefull forum for your valued opinions,
                                    Thanks Charlie,
