Advice from the photographers.
Home Forums The Tea Room Advice from the photographers.
Viewing 25 posts - 1 through 25 (of 38 total)
  • #567788
    Nathan Sharpe
      @nathansharpe19746
      I have been set the task of digitising several hundred 35mm slides. These are my partners parents slides of wildlife/flowers etc so are of significant value to her. I have an old but good Canon D40,numerous lenses and a Panagor slide duplicator.
      My problems.
      1) the Panagor is OK but seems to crop too much and has limited adjustment. It fits direct to the camera body via a T2/ EOS adapter.
      2) I have a loan Plustec Opticfilm 7500i but without the Silverlight software, OK with some slides using the Plustec download but not with the majority.
      My questions.
      1) Could I fit one of my lenses to the camera and then an EOS to T2 adaptor on the filter thread to then take the Panagor? I could make a support to relieve the weight on the filter thread.
      2) Can anyone suggest affordable software for the Plustec?
      I'm no great photographer so am hoping some of you Really Good photographers/optics experts can help!
      Nathan.
      #36602
      Nathan Sharpe
        @nathansharpe19746
        Copying 35mm slides with a DSLR.
        #567790
          Assuming [always risky] that you mean 40D … The basic problem that you have with the Panagor duplicator is that it’s designed for full-frame, and your sensor is smaller, by a factor of 1.6
          Convenient as the duplicators are … that makes 1:1 copying impossible with your camera sensor.
          I think you need to be looking at the ‘close-up’ possibilities of your various lenses.
          Ref. __ https://en.wikipedia.org/wiki/Canon_EOS_40D
          Edited By Michael Gilligan on 22/10/2021 19:30:41
          #567791
          John Haine
            @johnhaine32865
            Considering the hassle and potential difficulty you might consider just applying money to the problem and sending the slides off to a company that does this.
            HOWARDT
              @howardt
              There are lots of options, such as macro lens or extension tubes etc. I have a flat bed scanner and software that allows me to copy multiple slides at once, but it all takes a tremendous amount of time and every capture has to be edited to get the best out of them. If you have a projector you can use that and photograph the projected image. I have been copying my family negatives and photos for some time and am nowhere near finished, probably a project for my kids to finish when I am gone. If you really value the images then get them copied professionally using a continuous feed and copy system.
              #567796
              pgk pgk
                @pgkpgk17461
                I went through dad’s slide boxes when he'd passed. Many of the slides were showing signs of deterioration after 50+years. I did digitize them using a cheapo 'silvercrest digistiser' thingy – essentially just a cheap digital camera under a housing through which a slide carrier is pushed so it's a question of what quality you’re aiming for and how much you are prepared to accept for the sake of speed and simplicity. I think I've still got it somewhere – wasn't expensive enough to bother with postage aggro and listing on eBay etc.
                I’m near Llanfyllin if it's worth your bother to drop by and pick it up FOC. If so PM for full address.
                Example pic below (original was the same sepia bias on original Ilford slide film):
                #567797
                  If the intent is to store the slide image as an electronic image, you could use a slide / negative scanner., rather than the camera
                  The cheapest is about £15 and is likely to produce a file of about 4 – 5 Mb.
                  This should be adequate for many purposes, but possibly not if projected onto a 6' screen.
                  #567798
                  Martin Kyte
                    @martinkyte99762
                    Do not destroy the slides. Thay are far more permanent than digital copies.
                    regards Martin
                    #567803
                    Frances IoM
                      @francesiom58905
                      I have an old PF3600 scanner that produces a 12MB jpeg image with autofocus and tho better than needed for use on a laptop etc is still nowhere as good resolution as the original slides (admittedly taken on a good camera with good lenses) – I bought a couple of cheap scanners but these produce poor quality as well as being poor to focus – you will definitely be disappointed with these.
                      Tho the slides had been kept in special folders they still needed air brushing before scanning – a relatively slow business as each slide needed to be handle individually – I did 3000 over a period of many evenings (+ two bottled air dusters) but still have probably another 5000 to go.
                      The other key point is to create a data base as you scan – luckily many of my slides had some title written on the slide frame – otherwise you won’t be able to find them again.
                      If you have access to a good quality scanner these often had an adapter to allow scanning of slides – slower process than a special slide scanner but in past I’ve had reasonable results from such a scanner.
                      Edited By Frances IoM on 22/10/2021 20:41:28
                      Edited By Frances IoM on 22/10/2021 20:43:57
                      #567805
                      duncan webster 1
                        @duncanwebster1
                        Posted by Martin Kyte on 22/10/2021 20:20:58:
                        regards Martin
                        I'm not convinced, when I set out to digitise my 50+ year old slides I found they had deteriorated badly. Finished up throwing them.
                        #567806
                        Robert Atkinson 2
                          @robertatkinson2
                          You can get new copiers designed for DSLRs with APS-C sized sensors. Quality can vary.
                          Another option is a used 35mm SLR one with zoom. The Ohnar ones were OK. You might need a new T mount depending what the one you bought came with. Lots on ebay.
                          Robert G8RPI.
                          #567808
                          Nicholas Farr
                            @nicholasfarr14254
                            Hi Nathan, this Thread maybe of interest. Although the second page is of more relevance.
                            Regards Nick.
                            Edited By Nicholas Farr on 22/10/2021 21:08:11
                            #567811
                            Peter G. Shaw
                              @peterg-shaw75338
                              When I digitised my 35mm slides, I created a lightbox using 1/8inch white faced MDF board and containing 2 x 25w candle lamps. The viewing window was a translucent screen salvaged from an old 35mm battery operated viewer. This was used to backlight the slides. My camera is not the best, it is a Canon A640 so I experimented until I found an optimum distance at which the photgraphed slide almost filled the A640 screen. I then made a chipboard adaptor to hold the camera at a set distance, and using macro mode, once focussed, I found that I could whip through about 15 or so slides very quickly. Anymore than 15 or so and the light box started to get hot.
                              Once loaded into the computer from the camera, I used a software programme named The Gimp. First, I used a mode to correct the barrel & pincussion distortion introduced by the camera. Then I used a crop command to remove the black borders. Next I used a colour correction mode, to overcome the obvious deficiencies in the slides. Usually I used an "auto" mode. Finally, I used a paintbrush clone mode to overwrite those areas where there was dust, hairs, or in some instances, litter on the ground!
                              Occasionally, I found a photograph which was too far gone to be able to be retrieved. These had to be scrapped.
                              I did buy one of those fancy devices which allowed you to download onto the computer, but found it very poor in that the back lighting appeared to be a single source in the centre of the photographing area. This produced too much light in the centre of the downloaded copy which was not acceptable. The method outlined above, although not without deficencies caused by the camera, was overall much better.
                              Peter G. Shaw
                              Edited By Peter G. Shaw on 22/10/2021 21:18:40
                              2nd edit.
                              Guess what, I've more or less repeated what I sadi in the thread Nick has referred to. Sorry about that.
                              Edited By Peter G. Shaw on 22/10/2021 21:26:09
                              #567813
                              Macolm
                                @macolm
                                One problem that is rarely mentioned, but which I have found troublesome, is vignetting. This is the fall off in brightness towards the corners, which is an intrinsic feature of lenses, even an "anti-vignetting" lens. It is due to some of the ray bundle being increasingly obscured off axis within the lens itself.
                                In practice, better cameras do not suffer much from the effect, it is not immediately noticed in a photo. However, when a slide or print is copied using a camera, there is now two lots of vignetting, and the effect does become more noticeable. Correction using software may be a possibility.
                                On the other hand, a scanner should provide constant sensitivity across the entire field, and certainly I have has good results scanning my slide and negative collection. It does need a high resolution scanner to cope with the small image size. I have an older Epson scanner which can be loaded with eight slides, each individually adjusted, then all of them (slowly) scanned.
                                Incidentally, for a pretty dire result, try projecting slides and photographing the screen – three lots of vignetting.
                                #567817
                                  Posted by Robert Atkinson 2 on 22/10/2021 20:55:35:
                                  Another option is a used 35mm SLR one with zoom. The Ohnar ones were OK. […]
                                  But don’t those only zoom in ?
                                  [ which would exacerbate the problem that prompted Nathan’s question ]
                                  … or do you know of a 35mm one which handles larger-format originals ?
                                  Breva
                                    @breva
                                    Nathan,
                                    Depending on how precious your time is and also how many slides you have to copy, a good flatbed scanner like a CanoScan 9000 or later model could be your cheapest option for best quality copies. The Canon one comes with frames to hold slides, negatives etc and the software to process them. Mine came with a Photoshop Lite version which proved adequate for most tidying up jobs. The end results are very good.
                                    It is a slow job but images can be edited and enhanced later when you have captured them before further deterioration can occur.
                                    Thor 🇳🇴
                                      @thor
                                      Like John, I used a flatbed scanner and the results were good, takes time, of course. I have kept the slides, they still look OK after over 40 years. I haven't viewed them often and stored them cool and dark.
                                      Thor
                                      #567945
                                      Robert Atkinson 2
                                        @robertatkinson2
                                        Posted by Michael Gilligan on 22/10/2021 21:36:56:
                                        The do only zoom in, but they were designed for a full format so 1:1 = 0.6:1
                                        See http://www.eos-magazine.com/articles/viewfinder/slidecopying.html
                                        Robert G8RPI.
                                        #567950
                                          [quote]
                                          Now the zoom range runs from 0.6x to 1.6x so that the 35mm slide can be reduced to fit the APS-C sensor using a 0.6x zoom.
                                          [/quote]
                                          Yes … That would explain it ,Robert [the important word being Now]
                                          Forgive me if I mis-understood what you wrote.
                                            Just to clarify: 0.6x would normally be described as zooming out
                                            Sam Stones
                                              @samstones42903
                                              These days I would do what John Haine recommends.
                                              However, here's another approach.
                                              Back-lit with flash through a (plastic film) diffusion screen.
                                              A cut-down cardboard postal tube set the distance, with a Speedlite transmitter for camera to flash sync.
                                              Conveniently, I used the slide carrier from an ancient slide projector.
                                              Many of the slides taken in the late 50's and sandwiched in glass were badly in need of cleaning. Very laborious, but overall a pleasing result.
                                              I'll post a sample now that I've remembered, i.e. load picture files first!
                                              Cheers
                                              Sam smile d
                                              #567975
                                              Sam Stones
                                                @samstones42903
                                                This was a Kodachrome slide taken through my first 35mm camera; a Baldessa 1a or 1b, I can't remember. The slide hadn't been stored between glass, and other than cropping required no extra editing.
                                                This next one (before and after) was one in a bad condition, yet stored between glass. It shows what's possible in Photoshop. The original slide (c1960), was Kodachrome taken in Holland via a Leica M4 (not mine).
                                                Good luck Nathan!
                                                Samsmile d
                                                Edited By Sam Stones on 23/10/2021 23:51:08
                                                #567984
                                                Martin Connelly
                                                  @martinconnelly55370
                                                  I have a Canon scanner with a slide and negative carrier. It has a backlight set into the lid for this. Trying that I found it was too grainy (and slow). What I ended up doing was using the slide scanner backlight and a digital camera supported on a bean bag set to macro. It gave much better results and muck quicker. As above just some cropping required. Some of the slides I copied were 110 not 35mm.
                                                  Martin C
                                                  #568103
                                                  Nathan Sharpe
                                                    @nathansharpe19746
                                                    Many thanks to all who responded, it always amazes me that so much help is available here.
                                                    As Michael Gilligan points out it(the Panagor) would always crop. I do not know how I missed that so thank you Michael.
                                                    My very grateful thanks to Martin K/Howard T/ Peter G Shaw/ and Sam Stones for their input.
                                                    With regard to Sams post, I've seen a Youtube video using a projector to automate that style of copying and did buy a projector to try it, but have yet to try it.
                                                    PGK's offer is typical of this forums membership but I will only take up his offer if I can offer something in exchange.
                                                    Again my thanks to all.
                                                    Nathan.
                                                    #568106
                                                    pgk pgk
                                                      @pgkpgk17461
                                                      Posted by Nathan Sharpe on 24/10/2021 22:28:03:
                                                      It's in a box gathering dust in a wardrobe for 4/5 years – might as well get used. Perhaps you'll pass it on to someone else.
                                                      pgk
