Yesterdays Car Boot Haul! Odd items
Home Forums Help and Assistance! (Offered or Wanted) Yesterdays Car Boot Haul! Odd items
  • #370152
    Martin King 2
      @martinking2
      Hi All,
      Good day yesterday at our local large boot sale, got these items, one of which I am not sure of its exact purpose so any help would be great.
      Pretty sure that the Ackworthie is a tapping accessory but have never seen the BOXFORD item before and have no idea of hat the MATRIX item was used for..
      Cheers, Martin
      #33261
      Martin King 2
        @martinking2
        #370155
        Rik Shaw
          @rikshaw
          Ackworthie is tapping head, Matrix is a bench inspection micrometer and Boxford looks like a bore sizing gauge.
          Rik
          #370157
          Clive Brown 1
            @clivebrown1
            Isn't the Boxford item their take on a dial indicator?
            #370162
            michael potts
              @michaelpotts88182
              `Hello Martin.
              The Boxford item is a dial indicator as Clive says. It is for checking variations from a zero position ( In the centre of the dial ) such as centring in a lathe chuck, or on a rotary table.
              Mike Potts.
              #370170
              Brian H
                @brianh50089
                Lucky you Martin, all I got was a small greenhouse (something I actually did want).
                I did see a nice set of 3 M&W scrapers with tubular handles in a box but I've already got some. There was also a nice M&W small tap wrench which I would have had but the owner had stamped his (her?) initials in such a way as to distort the screw thread so that it couldn't be adjusted!
                BDH
                #370177
                Mike Crossfield
                  @mikecrossfield92481
                  Martin (and BDH)
                  I'm envious. I don't know where you're located, but in my part of England (South Hampshire) the only stuff at local car boot sales seems to be clothes, old toys, DVDs/CDs, and household/garden junk. Never anything of use in the workshop.
                  #370182
                  Andrew Tinsley
                    @andrewtinsley63637
                    Hello Martyn,
                    Where on earth is this car boot sale? It must be worth a trip to if there is such good stuff to be had.
                    Andrew.
                    #370184
                    John MC
                      @johnmc39344
                      The Matrix device is, as has been said a bench (inspection) type micrometer with a fiducial indicator on the left hand end of it. This ensures that the micrometer is always used consistently, that is to say it is not over over or under tightened onto the work being inspected.
                      Martin King 2
                        @martinking2
                        John MC. is that the small dial with the discoloured cover?
                        Andrew Tinsley, You could try 15.9650° S, 5.7089° W wink, no guarantees of course……
                        Thanks folks for the info, the Boxford item seems very well made indeed and in great condition.
                        Regards, Martin
                        #370242
                        martin107
                          @martin107
                          Near Napoleon's Tomb interesting !!!!
                          #370248
                          John MC
                            @johnmc39344
                            Posted by Martin King 2 on 03/09/2018 14:37:42:
                            Yes it is.
                            Mike Poole
                              @mikepoole82104
                              Regards, Martin
                              You must get up early on Sunday morning to get down there.
                              Mike.
                              #370252
                              Andrew Tinsley
                                @andrewtinsley63637
                                Hello Martin
                                Thanks for the precise location! Getting up early may be more of a problem!
                                Thanks,
                                Andrew.
                                #370253
                                Andrew Tinsley
                                  @andrewtinsley63637
                                  Hello Martin
                                  Thanks,
                                  Andrew.
                                  #370255
                                  Martin King 2
                                    @martinking2
                                    Posted by Mike Poole on 03/09/2018 16:28:21:
                                    Regards, Martin
                                    Mike.
                                    Mike, as it is quite a long swim I start the week before! The main problem is the swim back with all that metal so I have a very, very long snorkel…smiley
                                    Seriously though we do work hard at getting all over to these car boots and find that the effort is rewarded.
                                    We do think however that it is a fallacy that you have to be at these car boots at crack of dawn as often when we are leaving after a pretty bad look round we see someone just taking a box out of their vehicle and Bingo!, it turns out to be right up our street.
                                    You get to be good at spotting the stalls that are never any good, lots of 'pink' usually means don't bother but you really can never tell.
                                    Cheers, Martin
                                    #370256
                                    Andrew Tinsley
                                      @andrewtinsley63637
                                      When I was a lad it used to be Northings and Eastings, !
                                      Andrew.
                                      #370275
                                      Jeff Dayman
                                        @jeffdayman43397
                                        If the fiducial indicator and the micrometer itself are in good shape in a temp controlled 20 deg C room you can easily measure to +/-.0001" with the Matrix unit. The fiducial indicator part (big drum at left) is designed to accurately and repeatably control measuring pressure to achieve the higher accuracy than normal micrometers.
                                        If bashed or left in the rain for months or years it may not be OK. If in good nick it is a valuable tool for close tol work.
                                        #415722
                                        Martin King 2
                                          @martinking2
                                          Hi All,
                                          Here are todays 2 car boot mystery item finds! The first is very strange and I have no idea what it is for, only 6 1/2" long overall, beautifully made from castings as shown:
                                          Not sure if there is a square shaft part missing? The lever locks into position and closes the clamp section as it locks?
                                          The second item is , I think, some sort of dividing head or indexing unit but no idea what for or from?
                                          Should clean up OK by the looks of it. The really odd thing was that 1/2 an hour later at a different stall a clearance guy unloaded a really nice boxed MYFORD dividing head with plates just as I was walking by;
                                          When asked how much he said "a tenner if I don't have to lift it back on the van"! Xmas is early!
                                          Cheers, Martin
                                          #415724
                                            Martin
                                            1. looks interesting [and, I guess, might be using forgings rather than castings]
                                            2. could well be an equatorial telescope mount
                                            3. crying 2
                                            Edit: http://collection.sciencemuseum.org.uk/objects/co8413014/larger-smallman-patent-haula-hook
                                            Edit: http://www.healeyhero.co.uk/rescue/individual/Bob_Bradley/Bk-3/B3-1928-D.html
                                            Edited By Michael Gilligan on 23/06/2019 13:27:03
                                            #415725
                                            Martin King 2
                                              @martinking2
                                              Hi Michael,
                                              I thought forgings NOT castings just as I hit the "post" button, blush, castings would of course break easily.
                                              Does the X Patent mark mean it is USA in origin? If so, probably quite old?
                                              I had not thought of a telescope mount! Sounds about right, perhaps Neil will bne along with some input?
                                              3 Love the emoji! Dividing head now gone!
                                              Cheers, Martin
                                              #415726
                                              Martin King 2
                                                @martinking2
                                                Michael, just checked out your very kindly supplied link, all is now clear! Many thanks.
                                                Martin
                                                #415728
                                                Maurice Taylor
                                                  @mauricetaylor82093
                                                  The smallman clip was used to fasten a small rail truck on to a haulage rope which ran between the tracks .A larger version was used on the 2foot gauge tracks in coal mines.
                                                  #415736
                                                  larry phelan 1
                                                    @larryphelan1
                                                    Lucky guys !! Nothing like that around here nothing except clapped out hedge cutters ,lawnmowers ,chainsaws and boxes of rusty bolts/nuts.
                                                    #415754
                                                    old mart
                                                      @oldmart
                                                      The telescope is fixed to the far left end opposite that balance weight.
