Removing a grub screw
Home › Forums › Hints And Tips for model engineers › Removing a grub screw
Viewing 25 posts - 1 through 25 (of 33 total)
  • #405146
    Harry Wilkes
      @harrywilkes58467
      I'm just thinking ahead statrted to put my 3" Burrell gearing back togather only to find one of the sprockets as a grub screw stuck in it and the allen hex is rounded ! It looks as if it's 2BA with a 5/64 allen key at this point I have given it a good dose of penetrating oil hoping come tomorrow it will screw out if not would welcome suggestions as to how to remove it my first thought is some heat,
      H
      #30702
      Harry Wilkes
        @harrywilkes58467
        #405149
        J Hancock
          @jhancock95746
          You may be lucky but my guess is, it will be easier to drill right through it and use an ' Easyout '.
          #405155
          Brian Oldford
            @brianoldford70365
            "Easyouts". . . . . .Invention of Satan.
            #405156
            Swarf, Mostly!
              @swarfmostly
              Hi there, Harry,
              I agree with Brian about 'EasyOuts' – they can expand the bolt and make things worse.
              My preferred method is to use a left-hand drill. It will centre well enough in your socket grub screw and, eventually, bite and wind out the screw.
              I believe there are a few videos on YouTube.
              As well as the simple left-hand twist drill, you can get a screw remover that has the same shaped tip.
              Best regards,
              Swarf, Mostly!
              #405162
              Nigel Bennett
                @nigelbennett69913
                One method I've sometimes used with success is to batter in a Torx bit – it needs to be a tiny bit bigger than the hex socket, but not so much it swells the screw and binds it more tightly. The action of battering it in helps to loosen the grub screw, and then hopefully there's enough grip to unscrew it.
                #405164
                Former Member
                  @formermember19781
                  #405169
                  Harry Wilkes
                    @harrywilkes58467
                    Agreed Brian
                    Swarf would have to fit it in the 4 jaw chuck to drill left hand
                    Nigel that thought have crossed my mind
                    34046 again that thought have crossed my mind
                    Thanks to all for replies
                    H
                    #405170
                    Mikelkie
                      @mikelkie
                      Posted by Brian Oldford on 15/04/2019 16:07:33:
                      I agree
                      #405174
                      michael howarth 1
                        @michaelhowarth1
                        The last time I was stuck like this I drilled out the centre of the grub with a carbide drill and the resulting "cylinder" with the threads came out easily with a tight fitting screwdriver.
                        Mick
                        #405175
                        Martin Connelly
                          @martinconnelly55370
                          If it is in a through hole then a right hand drill may catch and drive it out of the hub.
                          Martin C
                          #405181
                          Clive Foster
                            @clivefoster55965
                            There are Easi-Outs and proper extractors!
                            The conical left hand thread, uber hard, screw in until it (usually) breaks breed are indeed a monument to the creativity of Beezlbub and his minions in devising ways to frustrate humanity.
                            The drive in splined shaft variety on the other hand do generally work as the hole is sized so that the splines displace material from the seized bolt around the main shaft to give the tool something to grip on rather than expanding the remains of the broken bolt more tightly into the threaded hole. Basically the professional, sorted, version of batter in a Torx bit, cut off allen key, file tang or whatever is this weeks favourite thing with sharp edges.
                            I got Numbers 1 to 5 of the original breed made by Ridgid tools from the Snap On man longer ago than I care to admit. Very much not cheap then but effective. See **LINK** for the current UK source. The basic extractor sets sans drills, guides and snazzy box are, I think, quite affordable. Its nice that you can buy them individually should you break one. I'm on my third No 1 (the teeny one) and second No 2.
                            These days Snap-On sell their own BluePoint brand sets, even more not cheap, and there are various less expensive knock-offs. Some no-name imports, probably of "are you feeling lucky" quality judging by the price, others from respected brands such as Sykes Pickavant. I'm periodically tempted to get the cheapest set I can find for the box, drills and guides but having managed just fine without box, guides or dedicated drills for "mumble-mumble" years splashing out on extractor numbers 6, 7 and (maybe) 8 is more likely. No 8 is serious money but it is a big brute needing a 16 mm Ø hole. If you need the No 8 you are likely snorkel deep in the kitty litter!
                            #405185
                            bill ellis
                              @billellis45274
                              I've had luck in the past using a sliver of very thin feeler gauge down the side of the allen key. Put the sliver in first against one of the flats (or nearly flat if it is really rounded out) then tap the key in along side. It takes up enough room to allow the key some purchase. Good luck.
                              #405190
                                Posted by Mikelkie on 15/04/2019 18:07:23:
                                I agree
                                Not all, but likely about 90% of them! Only the very best quality are reliable!
                                I use left handed drills if possible.
                                #405209
                                I.M. OUTAHERE
                                  @i-m-outahere
                                  Before drilling or doing anything drastic you could try inserting a suitable pin punch into the hex hole and give it wrap with a hammer – don’t belt it to death just a sharp wrap , this can relieve the pressure on the grub screw.. I have also drilled most of the way through and used a piece of steel rod that has been turned down to fit into the hole and held it in place with high strength retaining fluid ( loctite) , let it dry for a day and give the rod a twist with a pair of vise grips .
                                  #405223
                                  Nicholas Farr
                                    @nicholasfarr14254
                                    Hi, the danger of drilling a hole through a hex grub screws and then basing something in, is that they are prone to split. A split grub screw is just about impossible to unscrew because whatever you use in the hole will just open it out and wedge it into the hole. XD 351 idea of drilling and Loctite (or equivalent) a rod or a sacrificial hex key is a good approach, providing you don't get any of it in the threads.
                                    Regards Nick.
                                    #405239
                                      Sometimes a dab of coarse valve grinding paste on allen key is enough to make it grip. Grinding off the worn end of the key helps too.
                                      Otherwise a left hand drill bit is my go-to solution. Drill close to the thread root diameter and the shell usually spins out before drilling  is complete.
                                      Edited By Hopper on 16/04/2019 04:04:43
                                      #405294
                                      Ian S C
                                        @iansc
                                        There is a compound available, come in tiny bottle and I think it is diamond grit. Trouble with grub screws, they are hard. The pin punch idea is what I would use, give it a tap, then rock the screw back and forth, the repeat, take the easiest way, either in or out, just take your time it should come out.
                                        Ian S C
                                        #405304
                                        I.M. OUTAHERE
                                          @i-m-outahere
                                          Hope like hell it isn’t an unbrako – that usually means using carbide tooling !
                                          #405309
                                          norman royds 2
                                            @normanroyds2
                                            method I used in the past is to find a small threaded bolt about the same size as allen key and tap into the hole not to hard and gently tune it out used to work on old motor bikes allen screws regards norm
                                            #405318
                                            Mick Henshall
                                              @mickhenshall99321
                                              So spend money on lefthand drills in case you need to get broken something out of a hole, what else are LH drills good for?
                                              Mick 🇬🇧
                                              #405320
                                              Harry Wilkes
                                                @harrywilkes58467
                                                Turned down torx bit plus a bit of heat smiley
                                                H
                                                #405333
                                                Georgineer
                                                  @georgineer
                                                  Thanks for letting us know, Harry
                                                  George
                                                  #405338
                                                  roy entwistle
                                                    @royentwistle24699
                                                    Mick wrote :-
                                                    Left handed holes ?
                                                    Roy
                                                    Edited By roy entwistle on 16/04/2019 16:32:12
                                                    #405347
                                                    Former Member
                                                      @formermember19781
