Vehicle reversing sensors
Home Forums General Questions Vehicle reversing sensors
Viewing 25 posts - 1 through 25 (of 33 total)
  • #554504
    Sam Stones
      @samstones42903
      Can U/S reversing sensors fitted to one vehicle respond to the emitted (U/S) signal from another?
      Just curious,
      Sam
      #28260
      Sam Stones
        @samstones42903
        #554514
        Sam Stones
          @samstones42903
          More of the story and the reason for my question.
          While reversing from a parking spot in a very busy supermarket car park, the reversing sensor alarm came on and yet there was nothing close enough to activate it.
          Then I noticed another vehicle with reversing lights lit about to back out towards me into the same lane.
          Still curious,
          Sam
          #554517
          Jon Lawes
            @jonlawes51698
            If its anything like aircraft radar, and the signal being transmitted by both was the same (same make and model of sensor maybe?) then I see no reason why one sensor wouldn't be spoofed by the other.
            That being said it does expose my ignorance on these sensors. Do the different sensors on the same bumper not interact with each other due to a unique Pulse Repeition Frequency or similar? Interesting stuff….
            #554518
            Sam Stones
              @samstones42903
              Thanks for your reply Jon.
              For some reason (mainly my own ignorance) BFO also comes to mind too.
              Were are the specialists when you need one? laugh
              Cheers,
              Sam
              #554520
              Bill Pudney
                @billpudney37759
                There was a time when I was just glad to get the reversing light on my MGBGT working!!
                cheers
                Bill
                #554528
                Martin Cargill
                  @martincargill50290
                  Reversing light, you flash ba****d. I have the mark one eyeball fitted to my series Land-Rover. If that fails I revert to the mark one ear and park by sound, You just pull forward a bit after the crunch noise.
                  Martin
                  #554542
                  Nick Clarke 3
                    @nickclarke3
                    Posted by Martin Cargill on 18/07/2021 07:59:13:
                    Martin
                    That sounds like the blind skydiver who knew it was time to bend his knees for landing when the dog's lead went slack! laugh
                    #554548
                    Clive Foster
                      @clivefoster55965
                      I doubt if there is anything more complicated than a narrowband filter in the signal path to ensure that a suitable signal is picked up.
                      However direct radiation from the source will be at a much higher power level than the normal reflected radiation so I'd have thought it would have saturated the input stage unless conditions were just so.
                      If it is just a simple frequency tuned system I'd expect it to be able to run at several different ones and cycle through the choices if one is obviously wrong.
                      Dunno if these are simple time delay devices or if they get a bit more sophisticated with a modulated pulse position or pulse width scheme. If there is amore complex encoding spoofing by another emitter can be made very near impossible.
                      #554550
                        I guess it could. Dunno if they're what's fitted to cars, but ultrasonic range finders work like sonar by sending a pulse and measuring how long it takes for the echo to return, if any. Normally short range (a few metres) because the echo is much weaker than the pulse. But I think the receiver would pick another car's sender up from several metres away provided there was nothing in the way.
                        The sensors work at between 35kHz and 100kHz, cost a few pounds, and are a popular Arduino project. An interesting variant might be to make an ultrasonic pyrometer for testing fireboxes. In principle, because the speed of sound depends on temperature, it should be possible to measure the temperature inside a firebox. Even more interesting to measure the temperature inside and along each of a boiler's fire tubes to see if their length and diameter is broadly correct. I suspect the innards of a model boiler are too small and inaccessible to get good readings, but it might be worth trying.
                          Lots of good speculation so far … but nothing definitive
                          Wikipedia informs us that:
                          Toyota introduced ultrasonic Back Sonar on the 1982 Toyota Corona, offering it until 1988.[7] December 13, 1984 Massimo Ciccarello and Ruggero Lenci (see List of Italian inventors) entered in Italy the patent request for ultrasonics Parking sensors, and November 16, 1988 the Ministry of Industry granted them the Patent for industrial invention n. 1196650.[8]
                          So perhaps this is the place to start: **LINK**
                          https://worldwide.espacenet.com/patent/search?q=pn%3DIT1196650B
                          Bill Pudney
                            @billpudney37759
                            Martin
                            Yep that's me, reversing lights, latest British technology…don't cha know…………
                            cheers
                            Flash
                            Edited By Bill Pudney on 18/07/2021 10:49:43
                            #554569
                            John Haine
                              @johnhaine32865
                              Quite a long explanation of operating principle of at least one type.
                              This describes one that uses two transducers and how it can be used with an Arduino.
                              I have a vague recollection of reading an article years ago that described an ultrasonic FM-CW sensor rather than pulse type to get better accuracy at short range, though I'm not sure if any of the available sensors work this way.
                              Anyway it's clear that the sensors all use frequencies round 40 kHz and rely on some measure of randomness in the time alignment from other sonars to avoid interference. So it is very possible for the sensor pulses on one car to sometimes be picked up by those on another and interpreted as close-by echos.
                              #554571
                              roy entwistle
                                @royentwistle24699
                                I don't know about reversing sensors but about Christmas I parked in a supermarket car park, locked my Corsa using the remote and the Fiesta at the side unlocked. I unlocked mine and the Fiesta locked. I'm afraid I locked mine and left the Fiesta unlocked. When I left later, the Fiesta had gone but my car was still locked.
                                #554577
                                Robert Butler
                                  @robertbutler92161
                                  Wife's system is infallible, all dependant on hearing. When you either hear the crunch or can't reverse any further she becomes aware of the proximity of solid or unyielding objects. Absolutely foolproof and rarely fails?
                                  Robert Butler
                                  #554582
                                  Calum
                                    @calumgalleitch87969
                                    Posted by roy entwistle on 18/07/2021 11:07:19:
                                    Many years ago, my father, who was by trade a marine engineer, took a job in a motor garage after the collapse of the Clyde shipyards. On his first day, he was given the keys to a car – I forget the make but it was notorious for having only six different keyings – and drop it off, then walk half a mile and pick up another car of the same make at such and such an address. In a fit of absent-mindedness, he dropped the first car off, put the key in his pocket, walked to the new address, saw a car of the right make, put the key in it, and drove it back to the garage, promptly followed by the Old Bill, wanting to know why the garage had branched out into nicking cars.
                                    #554637
                                      If asked to design a cheap as possible detector it would just produce a continuous output and measure the amplitude of the reflected signal. When it goes above a certain level assume it is from something close. So another one of the same make or equally cheap design would also set it off when back to back. lPlenty of ways to make it more sophisticated but all will be rejected by the accountants.
                                      MGBGT reversing switch is notorious for failing and in a fairly awkward place to get to if I remember correctly.
                                      #554639
                                      Jim Smith 8
                                        @jimsmith8
                                        I just designed an electronic schematic to use with a 4 Chinese sensor addon on the front and discovered a bit about these things: My schematic uses wheel speed sensors to blank it out above 3mph and activate it using the stalk switch when required. I tried leaving it on, but it kept beeping at kerbs and road furniture when pulling away from stops or closing in on other cars annoyed me.
                                        They have a range of 1.8M and are dumb outside this range. They use a simple burst of 40kHz transmit and receive the time delayed (Doppler) burst to process it and get the distance. I can imagine a car close in front reversing might confuse it, but whilst it will probably use the same 40kHz, the pulse period frequency is unlikely to be the same? Continuous transmission from all 4 sensors would be a bit power thirsty for small scale electronics and where they use 4 sensors I think there is a timing difference set for each sensor. That's how (on my kit) they can have a bargraph displaying left right proximity. The processing knows which sensor is closest to the obstacle.
                                        Edited By Jim Smith 8 on 18/07/2021 18:37:05
                                        #554853
                                        oldvelo
                                          @oldvelo
                                          Hi
                                          The developement of reversing radar as developed by my brother in law in the early seventies because of his concern for the number of horrendous accidents on open pit coal mines in the country
                                          Reversing Radar
                                          A little aside to the topic of it's early beginings
                                          #554865
                                          Sam Stones
                                            @samstones42903
                                            Although as MichaelG suggests there’s nothing definitive (well not so far), I have found this short exercise an interesting digression.
                                            Thanks to John, Dave (SoD), and oldvelo too for your links. Some of it was too challenging for my brain.
                                            Roy, your experience with the Fiesta made me smile, although Robert, I’m not in favour of your wife’s ‘touch parking’ technique.cheeky
                                            After all that, my guess is … under very rare conditions, there could be a false warning (albeit fail-safe) between cars installed with identical reverse-sensor-signatures, positioned back to back, and in line, but … ???
                                            Samsmile d
                                            From not-so-sunny Melbourne
                                            #554869
                                            Nigel Graham 2
                                              @nigelgraham2
                                              Dave –
                                              Interesting idea, an acoustic pyrometer. Unfortunately:
                                              "The speed of sound depends on temperature…"
                                              To a point. It actually depends on density. Whilst the density of a gas is affected by its temperature, it also depends on pressure, so the confining conditions and gas flow. I think the variability of everything in a miniature boiler would be nighmarishly difficult to analyse to the depth necessary.
                                              I don't presume to deny it would not work but could be far trickier than it seems.
                                              A humbling little digression…….
                                              By comparison with Nature's been up to for some millions of years…
                                              … bats have been using sound in the some-tens of kHz for social calls, and typically around the 100kHz mark for hunting and close-in navigation, no problem. The hunting also needs high repetition-rate chirps to aid discriminating insect prey of low sound reflectivity, from acoustically very difficult backgrounds in constant but random change. It probably uses interference patterns between the call and insect wing-beat.
                                              Except that their upper frequency distance range is necessarily very short by signal absorption in the air and by the animal's very low call power. This is to some compensated for by high voice pressure-levels; in some species, handsomely exceeding 90 or even 100 dB re 20µPa: levels dangerous for us if within our hearing-range and at larger powers.
                                              Think of being a little pipistrelle or horseshoe homing in on a fluttering moth against the constantly moving acoustic clutter of foliage. Just part of a very few grammes of brain working flat-out on very rapid, very complicated signal-processing necessary to control the responding flight, calls and ear-damping, while synchronising breathing with wing-flap and call. That mechanism maximises system efficiency by combining the chest muscles' contribution to exhalation with assisting the wing power-stroke. While it's at it, the brain's other departments are continuing to monitor and control the rest of the animal's physiology generally. All by instinct.
                                              (The horseshoe bats call through their nostrils! Their characteristic facial folds are for call beam-focussing.)
                                              Oh, and some of that compact brain must be holding some form of acoustic map memory back to the roost, especially vital to a nursing mother bat. They do have fairly good sight but that won't work in a cellar, mine or cave with no light whatsoever. Yet these lovely little creatures recall their way through what must be fiendishly complex acoustic "scenery" to where they sometimes reach.
                                              What are we doing with ultrasonic location and ranging? (Actually, light on my car – a camera.) Using steady pulses and a string of 'beeps' to help us ease a big steel box into a shop car-park bay to the nearest foot or so usually in broad daylight, whilst knowing our "prey" is sitting perfectly still in tins and packets on the shelves….
                                              #554872
                                              Sam Stones
                                                @samstones42903
                                                Reversing will never be the same again Nigel. cool
                                                #554876
                                                pgk pgk
                                                  @pgkpgk17461
                                                  Higher frequencies for shorter range?
                                                  Medical ultrasound (when i was still working) used 2-25MHz. The lower range for large abdomens, 5MHz for (say) a labrador's abdomen to 10MHz for (say) a cat's heart. 25MHz would be very specialised for things like ultrasound of the cornea. Acoustic gel was needed to remove any air barrier for consistent processing.
                                                  False colouring could be added to the doppler shift of the returning echo to highlight vascular flow or turbulence. I;d speculate that a bat would have doppler sensitivity too.
                                                  pgk
                                                  #554885
                                                    Back in early 60s, Ford only used a very narrow selection nof locks.
                                                    One chap, notorious for arriving late and dumping his 100E blocking aisles was FURIOUS to discover that someone had used their keys tom unlock mHIS car to move it!
                                                    A friend had his reversing sensors warning him of flowers in the bed beside his drive as he began to reverse into his drive.
                                                    lacking such refinements, my method was to remove the central head restraint from the back seat and stop when the rear wiper blade was about 150 mm from the obstacle. No good with short concrete pillars!
                                                    Whoopee for reversing cameras.
                                                    #554890
                                                    Nick Wheeler
                                                      @nickwheeler
                                                      Posted by Howard Lewis on 20/07/2021 08:35:15:
                                                      It wasn't just Ford, and it lasted well into the 80s!
                                                      Grandad's Wolseley 1500 and his friend's Riley used the same key and were the same colour; apparently they would swap back to the 'correct' car at work in the morning.
                                                      My Capri key would open all 3 doors and start my sister's boyfriends Capri, although his would only open mine.
