Magazine article ME and MEW sought-after
Home Forums General Questions Magazine article ME and MEW sought-after
  • #27157
    Werner Habbel
      @wernerhabbel11353
      #452919
      Werner Habbel
        @wernerhabbel11353
        Hello,
        as a new member of the forum, see "New in the forum from Germany" I search older articles of Model Engineer and Model Engineers Workshop which the publisher can not provide with back issuses.
        Neil Wyatt gave me the advice to give it a try here in the forum.
        So I am looking for Model Enginner:
        Alan Hearsum: Rebuilding a Myford ML7 Lathe
        2014, Volume 212. Issues 4473, 4475, 4477, 4479, 4481, 4483
        Model Enginners Workshop
        Alan Hearshum: Roller bearing upgrade to ML7 lathe
        2013 Issues 209 November, 2010 December
        2014 Issue 211 January
        If someone could make copies or scans this would be wonderful. Certainly I will pay for all expenses.
        Many thanks in advance and best regards
        Werner
        #452934
        Paul Lousick
          @paullousick59116
          Hi Werner,
          If you take out a digital subscription you will have access to all of these issues of ME and MEW.
          Paul
          #452986
          Brian Wood
            @brianwood45127
            Hello Werner,
            You said your lathe is an early Super 7. If I remember correctly, the Alan Hearshum article is for modifying the ML7 lathe with roller bearings in place of the white metal plain bearings. It is not a conversion you can apply to your lathe.
            All is not lost however! Ken Willson published a conversion to taper roller bearings for the rear bearings of the Super 7 headstock in MEW 175 published in April 2011.
            I made the change on my own lathe having read the article and it has performed without fault for nearly 9 years now. I fully endorse the upgrade but you do need the use of another lathe to machine recesses in the adjuster rings to be able to contain the greater depth of the bearings since they occupy more space within the housing than the angular contact bearings they will be replacing.
            I can send you a copy of Ken's article but only by email. For some reason I can no longer add to my folders or post pictures on the forum so that is my only route to you. Send me your email address if you would like a copy;
            My address is wood_y(at)btinterner(dot)com. All in lower case, with no spaces and be sure to include the underscore [ _ ] between the d and the y
            Brian
            #453027
              Werner, it look as if you need Issues 209, 210, and 211.
              I have them in my hoard, and if all else fails, will breach copyright laws by photographing them and E mailing to you. But you will need to send me your E mail address in a P M.
              #453043
              Brian Wood
                @brianwood45127
                Howard,
                Sorry to correct you, but If you look under Werner's other post joining the forum from Germany, he says in that his lathe is an early S7.
                That being the case, the Ken Willson modification for roller bearings on the rear end of the spindle is what he needs, not modifications on a ML7 with white metal bearings.
                Brian
                #453047
                  So its the ME issues that he needs not the MEW ones>
                  #453054
                  Werner Habbel
                    @wernerhabbel11353
                    Thank you Brian and Howard for your fast answers. I contated you both.
                    the article MEW no 175 is fine as well.
                    Still looking for the Model Engineer articles.
                    Werner
                    #453065
                      Copies of the articles in 175, MEW 209, 210, and 211 will soon be made and sent to Werner.
                      #453091
                        Hopefully, by now Werner will have the four articles from MEW that he requires.
                        Sorry that I can't help with the ME ones.
                        #453606
                        Werner Habbel
                          @wernerhabbel11353
                          Many thanks for Howard and Thor for their fast help with some articles and very nice contact.
                          Still looking for Model Enginner articles:
                          2014, Volume 212. Issues 4477, 4479, 4481, 4483
                          Werner
