Gipsy mk1 engine plans help ,, Jason ?
Home Forums General Questions Gipsy mk1 engine plans help ,, Jason ?
  • #448697
    David K
      @davidk77137
      I am close to building up the engine for a trial fit but something is bothering me.
      The engine has oil feeds drilled through the crankcase into the main bearings supplied by the oil pump but I cannot see any feed to the camshaft bearings.
      What puzzles me is the end cam bearing [cam gear end] , has a grove and hole in it which looks like it should be fed with oil.
      Obviously this question is only aimed at anybody who has the plans.
      #27102
      David K
        @davidk77137
        Camshaft bearing lubrication
        #448755
          Can't see anything obvious on the drawings but as you say the hole must be there for a reason. Ask on MEM forum as there are a couple of members there who have built it.
          #448773
          David K
            @davidk77137
            ok, thanks Jason , I didn't want to find I missed something obvious.
