I know a little of what is common practice in process piping, though there are many types of flanges the basic hierarchy is as follows; gasket materials vary widely according to industry, fluid and temperature….
Flat faced: the lowest pressure, cheapest and most common (150 – 300 psi), uses common gaskets
Raised Face: the flat area is reduced to within the bolt P.C.D to increase the pressure on a smaller area of flange most common to 600psi, uses common gaskets
Ring Jointed:there is a groove in both flanges to take a metal ring as a gasket pressures beyond 600 psi to mega
Tongue and groove: often used to ensure piping is assembled the right way around (and lots of other reasons)
Quite a nice description here http://www.wermac.org/flanges/flanges_raised-face_flat-face_ring-type-joint.html
There are lot's of variation, especially from industry to industry, but I think the above is a fair simplification: we shall see
