Well Speedy you don' say where you got yours, but mine wasn't particularly cheap bought from lathes.co and not from El Cheapo on Fleabay and was supposed to be the dog's doo-dahs, but like you it seems to require regular attention. By the way I believe that there are special pliers for easier working on these belts. This is on my Boxford which has new pulleys, so they aren't causing the slip.
Mark I tend to agree with that sentiment, I fitted my Boxford LOO with T link and the only redeeming feature appears to be the ability to change its length. The primary drive through the variable speed pulleys by flat rubber belt never slips, but when doing some heavy turning these linked belts do not seem to be able to transmit the power unless they are set up inordinately tight, which is not good for the bearings.
Trevor.
