Woodruff key – sideways location
Home › Forums › General Questions › Woodruff key – sideways location
  • #93632
    Sub Mandrel
      @submandrel
      I found a nice cast iron pulley of wheel that made an excellent pulley for my ex-recycling centre Suffolk engine. I had to sleeve the bore, but there is plenty of meat in the boss.
      I made a woodruff key from a slice of alloy steel, which makes the pulley a nice firm push fit, but after 20 minutes running it crept approaching 1/8" (that's 3mm, youngsters) along the shaft.
      Obviously if left unwatched for a lengthy period it could creep off the end with unfortuante consequences. So… what is the normal way of securing a pulley to an overhung shaft when a woodruff (or other key) provide positive location.
      Sub Mandrel
        @submandrel
        #93633
        Steve Garnett
          @stevegarnett62550
          Dunno about 'normal', but last time something similar happened to me, I loctited the key to the shaft. It's still there…
          #93636
            The key provides no hold along teh shaft, it onlt stops the pully rotating on the shaft.
            Drill & tap the end of the shaft and fit a turned washer retained with a screw or cross drill the shaft for a pin
            Edited By JasonB on 03/07/2012 20:47:42
            #93642
            Sub Mandrel
              @submandrel
              Not enough room for a pin, but that's an ideal solution.
              Sound advice Jason, thanks.
              RICHARD GREEN 2
                @richardgreen2
                Neil,
                As Jason says, a woodruff key provides no retaining of the pulley, it only provides a "drive" between the shaft and the pulley.
                You're going to need some other method of fixing the pulley in place, that all depends on the set up that you've got.
                I've got a Suffolk engine,probably 1960's, we used to rebuild them years ago, they made a 75cc and a 98cc, same block bored out bigger,
                Richard
                #93660
                Gordon W
                  @gordonw
                  Woodruff keys should be for location only, as in timing gears, not for driving. But it is an imperfect world. Just had a look at my old motors, those that aren't held by rust seem to have a grub screw fixing.
                  #93671
                  KWIL
                    @kwil
                    How about a grub screw that is threaded in boss of pulley and bears upon the key, pushing it into its seat..
                    Strictly speaking a Woodruff Key is semi circular and sits in a matching recess, a parallel key is the one that can slide out.devil
                    #93691
                    Sub Mandrel
                      @submandrel
                      Richard – as far as I can tell it's a 75cc with a cast iron head, as I understand the 98 was an alloy head bored out for a CI liner. I haven't fully dimantled it, I just fixed a broken flywheel and various bits, cleaned the outside and did a major restoration of a paint-encrusted carb.
                      Gordon – it's an ex-lawnmower engine, so it must have been able to transmit all the power of the engine in the original application.
                      Output side of restored engine
                      Kwil – It is a woodruff key, so the key isn't going anywhere, it's the pulley with its parallel grove that's moving.
                      Steve Garnett
                        @stevegarnett62550
                        Posted by Stub Mandrel on 04/07/2012 21:12:26:
                        Ah, I see now where I was thinking about this wrongly. How about two screws threaded through the boss either side of the key? That would stop it sliding in either direction.
                        #93794
                        Ian S C
                          @iansc
                          Neil, Steves got the idea, but I would fit the grub screws so that looking at the end of the shaft, the key is top, and screws at 120* either side, pushing the key up into the keyway. Tighten the screws, to mark the shaft, them loosen, andtake the pully off and drill dimples for the screw tips, they will be more positive, and the shaft won't get burred. Ian S C
