Wobbly Kitchenaid Mixer
Home › Forums › The Tea Room › Wobbly Kitchenaid Mixer
Viewing 25 posts - 1 through 25 (of 28 total)
  • #35690
    andrew lyner
      @andrewlyner71257
      #441878
      andrew lyner
        @andrewlyner71257
        I hope this is a suitable place to post this question.
        I have a Kitchenaid Artisan food mixer and it is almost perfect. It does have one stupid problem and that is the hinge pin that the top pivots round when it's lifted. Anyone who has had anything to do with this mixer will know what I mean about the construction of the mixer.
        The pin is about 9mm and s/s. It goes through a meaty 'foot' which is part of the top casting and a pair of holes each side in the casting of the base. It is held in place by a grub screw, half way along and the screw shakes loose after a few months' use in bread making, things start to rattle and the pin starts to come out. Breadmaking is quite a heavy duty operation compared with cakes. (I don't dare starting on a weekly cake bake – get thee behind me Satan!!!`) but the motor seems to cope well enough with a 600g (flour) mix.
        The problem is all over Google and only solution I can come by is to screw the grub screw in again – as tight as you can.
        If only I could find a link where someone has fixed the problem 'properly', then I would do what they've done. I can't imagine a seasoned ME member who has heard 'that' noise and not wanted to do something about it.
        Do I really have to put bushes in the castings, to sort it all out? What's the general opinion / experience?
        #441880
          Thread lock on the screw?
          #441883
          andrew lyner
            @andrewlyner71257
            That's an idea but I get so cross at spending loads on one squirt from a tube which is out of date by the time I need another squirt. It would certainly be a quick solution.
            Thanks for the reply, btw
            #441885
            Brian Wood
              @brianwood45127
              Put a flat on the pin for the grub screw to bite into, then thread lock as JasonB suggests
              Alternatives are to fit end screws and a thick washer behind each to contain the pin and prevent it 'walking' out
              #441886
              Dave Halford
                @davehalford22513
                Posted by andrew lyner on 16/12/2019 16:47:41:
                Doesn't really go out of date, old stuff still works the same.
                #441887
                Brian G
                  @briang
                  Is there room to fit a longer pin with a head one end and a groove for an E clip at the other (or even a washer and split pin)? Crude but pretty much vibration proof.
                  Brian G
                  #441889
                  Oldiron
                    @oldiron
                    If there is room put another grub screw in after the original.
                    edit spelling
                    Edited By Oldiron on 16/12/2019 16:59:46
                    #441894
                    Jeff Dayman
                      @jeffdayman43397
                      If you don't like the price of Loctite you could try tiny tube of super glue (CA glue) from the pound shop / dollar store. Epoxy from same source might also hold the pin in.
                      Does the setscrew sit on the round OD of the pin? It might hold better if you grind a flat on the pin with a disk in a dremel type tool to receive the end of the screw.
                      #441898
                      Nick Clarke 3
                        @nickclarke3
                        What about Link or Link at a bit over four quid a go?
                        #441899
                        Cornish Jack
                          @cornishjack
                          Loctite certainly does go on and on – mine bought part used over 20 years ago, still working. Keep Super glue in the refrigerator.
                          rgds
                          Bill
                          #441929
                            twist of teflon tape or even nylon thread around the grubscrew before tightening it.
                              Dab of paint or even nail varnish if you wear it will do as a weak thread lock and be easier than superglue should you need to get the screw out at any time.
                              #441933
                              Howard Lewis
                                @howardlewis46836
                                How about making a poor mans version of the grubscrew with a Nylon insert?.
                                Hold a short piece of fishing line in the tapping, as you screw in the grub screw. Hopefully, this will, generate enough friction to prevent the grubscew backing out.
                                #441952
                                andrew lyner
                                  @andrewlyner71257
                                  This is a great little Engineering Problem and it needs experience to solve it. The right choice of materials in the first place would have avoided this being such a frequently reported fault in all the Kitchenaid models .It's not a difficult thing to get right – it's hardly like an engine camshaft, operating at 20,000 revs!. In the whole lifetime of the unit, used a few times every day, the hinge would hardly have to operate more than 20,00 times in a ten year lifetime.
                                  "enough friction to prevent the grubscew backing out." The pin seems to be very hard and the grub screw doesn't manage to mark it al all -so there is virtually no movement and the grub screw can't (by the nature of the geometry) work up any compression or stretch, which is what most properly tightened bolts work on.
                                  When the screw goes slack, there is some slop in the inner hole (the one on the top half of the machine) so merely replacing the pin with one with 'ends' on it, to stop it moving out. That slop means the top of the machine rattles about and I need to stop that – just for quietness.
                                  I like the idea of grinding a small flat on the pin and then using thread lock. I was even wondering about putting a bit of a slot / hole and grinding a point on the set screw for it to bite into. Probably a slightly softer pin would do the job and allow the grub screw to hold it better. It's a very quick job to make changes so I can experiment. I may buy some silver steel and even harden it (?) or would it be too brittle in that application?
                                  #441955
                                  not done it yet
                                    @notdoneityet
                                    An ‘O’ ring behind a washer or end cap is often sufficient to prevent movement and provide some friction. Otherwise fit shims to reduce any lateral movement?
                                    #441958
                                    andrew lyner
                                      @andrewlyner71257
                                      Posted by not done it yet on 16/12/2019 23:18:32:
                                      I see where you're going but the slop is radial and I don't think shims are needed. The pin needs to be pushed radially; It's strange but any wear should be pin against the outside four holes but they are tight enough. the central hole seems to be where the slop movement is.
                                      #441961
                                        Posted by andrew lyner on 16/12/2019 23:06:57:
                                        This is a great little Engineering Problem and it needs experience to solve it. […]
                                        Grubscrews with nylon inserts or patches are readily available.
                                        Mike Poole
                                          @mikepoole82104
                                          a Couple of R clips seems to be one mod being sold, it should be possible to drill the existing pin to fit the clips
                                          #441976
                                          Ron Laden
                                            @ronladen17547
                                            Just dimple or flat the pin at the screw contact point and threadlock the grub, simple, easy and cheap you can get a small bottle of threadlock for £3-£4 hardly breaks the bank and sorts the problem.
                                            Or have you got a headed screw of the same thread with a nut to fit, tighten the screw against the flat and lock in place with the nut, even cheaper than buying threadlock.
                                            Edited By Ron Laden on 17/12/2019 05:29:00
                                            #441983
                                            Clive Hartland
                                              @clivehartland94829
                                              Nail varnish, degrease parts first.
                                              #441991
                                              Robert Atkinson 2
                                                @robertatkinson2
                                                line bore the holes and fit bearings (I'd use Iglidur like this **LINK** and a ground rod shaft with a flat for the grub screw.
                                                You will only have to do it once.
                                                Robert G8RPI.
                                                #442000
                                                  https://producthelp.kitchenaid.com/Troubleshooting_Guides/Troubleshooting_for_Stand_Mixers/Tilt_Head_Mixer_Issues/Silver_pin_on_head_of_tilt_head_mixer_is_loose_or_fell_out
                                                  Now I’ve seen video of the problem area … most of the aforementioned fixes/improvements should work, but I would first try the grubscrew with nylon insert [which is surely what the manufacturer should have used]
                                                  What size is the original screw ?
                                                  Edited By Michael Gilligan on 17/12/2019 08:15:57
                                                  #453127
                                                  andrew lyner
                                                    @andrewlyner71257
                                                    I replaced the s/s pin with a grooved mild steel pin. The set screw dug in and has not moved for about ten loaves of bread. I think that's a result.
                                                    #453128
                                                    Steviegtr
                                                      @steviegtr
                                                      Centre punch each side of the grub screw when tightened in.
                                                      Steve.
