Ball end cutters
Ball end cutters
Home › Forums › Workshop Tools and Tooling › Ball end cutters
  • #860601
    Speedy Builder5
      @speedybuilder5
      I need a 5/16″ or 8mm diameter ball end mill just to make a round recess at the bottom of a 5/16″ dia hole.  Would a sort of “D” drill do this. I only have two components to make in brass or Al-bronze.
      Ps:-  These are the for the cavities behind the valve heads on Farm Boy hit and miss engine and the bottom of the recess has a 1/8″ hole for the valve stem.
      Bob
      #860607
        Yes a D bit will do and should cut fairly easily if you drill and ream the valve stem hole first
        #860727
        Speedy Builder5
          @speedybuilder5
          thanks Jason
