Solar eclipse
Solar eclipse
Home › Forums › The Tea Room › Solar eclipse
  • #860574
    JA
      @ja
      Since I saw the total eclipse of 1999 in France I decided to ignore this partial eclipse. However when the eclipse started I put a small hole in a sheet of card and projected the image across my living room. Nothing surprising about that. When I removed the card I had lots of images on the wall from the sunlight shining through a bush outside the window. The bush was acting as many pinhole cameras. I did take photos but have yet to download the images. As the eclipse waned these images disappeared and were replaced by the usual partial shadow.
      I have little knowledge about light but there must be a light level at which reflection/refraction ceases to dominate the transmission of light.
      JA
      #860578
        Humph … Grrr!!
        I drove up to the hill to a good spot with a clear view of Sun’s location
        Spent more than 2 hours ‘observing’ a patch of very bright cloud.
        Distant memories of the 1961 event … viewed from the schoolyard using glass smoked in a candle-flame, will have to suffice 🙁
        Andrew Crow
          @andrewcrow91475
          Not too bad here in North Warwickshire the clouds managed to drift away in time, but no where near the 90% coverage that some areas had. Much better than 1999 though when we had light cloud cover and barely saw anything.
          Andy
          #860593
          peak4
            @peak4
            This is a screenshot of a quick compilation of images taken with a conventional camera and telephoto lens;
            Olympus E-M1x  50-200mm + MC-2.0 teleconverter & Baader film filter
            image_2026-08-13_141921175
            I did have a play, for the first time, with a Dwarf 3 astro camera.
            I set it to take a photo every 15 seconds, and then compiled them into a short video.
            Unfortunately, the camera kept losing tracking, so the video ended up quite jumpy.
            After playing with various editing/stabilisation software, again for the first time, I eventually came up with this.
            Now I need to have a try with a higher resolution set of originals.
            Bill
            #860630
            Gerard O’Toole
              @gerardotoole60348
              Very nice Bill. I like the way you put the sequence together.
              Below , again with Olympus but Handheld EPL8 with standard telephoto lens and a stack of filters. It was very cloud here so the clouds did most of the filtering I think
              edit025
