Wire Gauge Drills
Wire Gauge Drills
Home › Forums › Workshop Tools and Tooling › Wire Gauge Drills
  • #537639
    Brian H
      @brianh50089
      Can someone tell me what standard wire gauge drill are made to? I'm sure that it''s not SWG.
      Also, where can I buy straight lengths of wire to the same gauge?
      #20229
      Brian H
        @brianh50089
        #537645
          Why are you sure of that, Brian ?
          So far as I am aware SWG means SWG
          Edit: Not to be confused with AWG or any minority series
          Edited By Michael Gilligan on 02/04/2021 14:57:16
          #537648
          Russell Eberhardt
            @russelleberhardt48058
            I believe they were originally based on Stubs steel wire gauge, not to be confused with Stubs iron wire gauge!
            Russell
            #537649
            Brian H
              @brianh50089
              Thanks Michael, I compared the drill sizes with a SWG chart and it didn't seem to match, mind you, I only checked a few sizes.
              #537650
              Howard Lewis
                @howardlewis46836
                Possibly wrongly, my inclination would be to look up the diameter of the particular SWG and then find a small number drill of that size.
                As an example: 20 SWG is 0.022"diameter, 0.58 mm, which is a No 74 drill, according to my Metric Revision Zeus charts.
                HTH
                #537652
                  Is this any help ?
                  https://marston-sunbeam.org/threads/combined_swg_nodrill_letterdrill.php
                  My usual ‘aide memoire’ for spot-checking any table which includes wire gauges is
                  16 SWG = 0.064” or 1.626mm [as near as matters for the purpose]
                  Edited By Michael Gilligan on 02/04/2021 15:26:08
                  #537692
                  Brian H
                    @brianh50089
                    Many thanks for the link Michael, that's one of the best I've seen.
                    I believe that Russell hit the nail on the head, a little bit of research shows that it is indeed Stubs Steel wire Gauge.
                    The only problem is that I have been unable to find a supplier of straight lengths so have decided to remake the valve guides with an accurate 1/16" bore as I have found 2 pieces of 1/16" silver steel in my silver steel box.
                    I did try to make a pair of valve stems from drills but they are hard all the way up the shanks and don't seem amenable to annealing,
                    Edited By Brian H on 02/04/2021 18:18:19
                    #537703
                      Good ol’ Wikipedia gives us this useful comparison chart: **LINK**
                      https://upload.wikimedia.org/wikipedia/commons/2/28/Gauge_Chart.pdf
                      Brian H
                        @brianh50089
                        Many thanks for that link Michael, it is very comprehensive.
                        #537738
                        Bazyle
                          @bazyle
                          One of the techniques in this stuation is to find the wire you want to use and make a D-bit out of it to ream the hole you drill just below size.
