what thread is this?
Home › Forums › Beginners questions › what thread is this?
Viewing 25 posts - 1 through 25 (of 26 total)
  • #65837
    Ian Parkin
      @ianparkin39383
      Hi there
      I have a motorcyle front wheel spindle that I’m making some nuts for ..
      Its a french 1930 terrot
      the thread measures 12.15 mm and pitch is 1mm and left hand for good measure. Its in fine condition considering its age.
      I bought a LH 12 x 1.0 tap and made a sample nut and no way will it go on.
      What do I do? machine the spindle down to 12mm and buy a die (£ 58 eek) or any other ideas? Is it a special thread? or another I’d not considered
      Ian
      #5454
      Ian Parkin
        @ianparkin39383
        #65840
        elanman
          @elanman
          Ian,
          IMHO if it’s 12.15mm o/d then the nominal diameter of the thread is larger than that. I would guess at 1/2 inch. Also 1mm pitch is very near 24 tpi. Tracy tools list cycle thread of 1/2″ * 24tpi. It’s in the taps and die/ cycle threads section on their web site.
          Just a suggestion.
          Or re-make the spindle and use what thread size you want.
          Cheers
          chris stephens
            @chrisstephens63393
            Hi Ian,
            John might be right about it being 1/2 but not about 24 it is nearer to 26 which is a cycle thread. (26-25.4 not 24). Cycle threads as the name suggests were common on, er, cycles.
            Do you have a lathe and can you cut threads?
            Cleaning up your spindle to fit the newly made nut might be an option, although the old vehicle owners I know prefer to keep everything as original as they can despite the easier alternatives. Making a new nut is easy enough if you have enough experience or are willing to gain that experience.
            Some manufactures, in those days, didn’t use standard threads but made them all in-house. Very frustrating trying to work out what it is meant to be, only to find it an oddity. Is it worn or is it special? Turning bits yourself might be the best option, as you can keep machining till it fits.
            christephens
            #65846
            Ian Parkin
              @ianparkin39383
              Thanks for your replies guys
              the thread is definately 1mm with my pitch gauges 24,25 and 26 tpi dont fit at all
              Its just the odd diameter
              I do have a lathe and have cut quite some threads but never left hand and so small internal..
              Is anyone near sheffield who would be prepared to do the job?
              I have ordered a 12mm die from china but delivery is 2 weeks or so
              Ian
              #65847
              ady
                @ady
                I wouldn’t experiment with steel nuts.
                Use something like delrin or aluminium, you can bore and cut a thread in minutes with softer materials on a lathe until you get it hunky dory, then do it in steel.
                edit:
                Maybe it’s a multi start thread…lol…I keep reading about them guys but I haven’t met one yet.
                Apparently they are very strong.
                Edited By ady on 22/03/2011 15:03:53
                #65849
                Keith Long
                  @keithlong89920
                  Hi Ian
                  You can mount the tap in your tool post and use it like a chaser to cut the internal thread. Machine the nut id to a suitable size (male thread od minus twice thread depth). That way you can cut the odd size with the equipment you’ve already got. You’ll need to set the lead-screw to give you the 1mm pitch and you might have to keep the half nuts engaged if you’ve got an imperial lathe. It might be better to use a hand crank rather than cutting with power.
                  Keith
                  #65850
                  mgj
                    @mgj
                    Or make your own tap out of SS. For a one off it can be pretty crude. A lot less than £58 and some weeks delivery.
                    Don’t be frightened about a LH thread. Its just an RH one with the feedscrew reverse engaged.  Nothing special.
                    A few quid and one evenings work.
                    Edited By mgj on 22/03/2011 15:23:10
                    #65854
                    chris stephens
                      @chrisstephens63393
                      Hi Ian,
                      LH threads should be easier to cut than RH, in a nut, because you start at full depth, hole not thread, and come out into free air. On Sunday I cut a RH 8.5mm by 20TPI nut for an auto- jumble purchase thread form tool holder, yes mixed units to match original, it just needs a small cutting tool. If I can do an 8.5, doing a 12 should be a doddle.
                      chriStephens
                      #65859
                      Speedy Builder5
                        @speedybuilder5
                        Just another thought – What is the thread angle ? 55 deg would suggest a British thread (Of Whitworth form) and 60 degree would suggest a metric one. 5 Deg doesn’t sound like much, but would be enough to foul things up. There is another dodge, make your nuts half thickness and use two of them. It would allow for a bit of ‘slop’
                        #65861
                        Ian Parkin
                          @ianparkin39383
                          How do you accuratly check the thread angle on such a fine form?
                          I have lots of pitch gauges and only the 1mm fits perfectly.
                          what other thread form would correspond to 12.15mm and 25.4 tpi?
                          #65863
                            A VG 12 thread (Valve thread) has a major dia specd as max 12.243 and min 12.091 but its a 26tpi
                            J
                            Edited By JasonB on 22/03/2011 20:18:24
                            #65865
                            mgj
                              @mgj
                              The thread angle – bear in mind that this is pre a lot of standardisation.
                              If your 1mm pitch gauge fits well- hold it up to the light is what I do – go for it on that. Use the formula for depth unless you are intot wire depthing. Just cut an internal thread, and pull the x-slide back and forth a bit if its a bit tight. (See Grays remarks about commercial slop)
                              The trouble with these old non standard threads is that sometimes you have to invest a bit of time getting it right.
                              Go for it – aint that difficult, and doesn’t matter if you do get it wrong. You just have to do it again! We’ve all been there – more than once.
                              Edited By mgj on 22/03/2011 20:30:52
                              #65869
                              John Stevenson 1
                                @johnstevenson1
                                Ian,
                                Is Nottingham J25 / M1 any good ?
                                Got drawers full of cycle and specials and can cut virtually any thread.
                                John S.
                                #65870
                                Terryd
                                  @terryd72465
                                  Posted by Ian Parkin on 22/03/2011 19:25:08:
                                  Hi Ian,
                                  You could scan the thread with a computer scanner and then enlarge it. You can then use any technique you prefer to measure the angle. Even a schoolboy protractor is accurate enough to measure 55 vs 60 degrees.
                                  We used to use a similar technique in industry called a ‘Shadow Graph’ and I think the name is self explanatory It is quite accurate and simple.
                                  Terry.
                                  #65879
                                  Ian S C
                                    @iansc
                                    Graham, Germany dropped the Whitworth threads about 1934 from what I remember, I,v done some work on Lanz bulldog tractors, making new parts, and was suprised when I found the threads were whitworth, after that they changed to a metric thread.
                                    1/2″ should not be too small, the first internal thread I cut was 3/8″ bsf, at that stage I had’nt cut many external threads, so fingers crossed and away , a few miniuts later a perfect nut. It was for a compressor at a local engineering shop, they could’nt do it and were worried that the might not be able to get a castelated bsf nut from the supplers in Christchurch. Some engineers that lot. Ian S C
                                    #65964
                                    Ian S C
                                      @iansc
                                      Hi gray, have replied, there may be a delay with some information, things have been moved about a bit over the last few months, some thing to do with earth quakes, but it will be there, some where. Ian S C
                                      #65972
                                      John Stevenson 1
                                        @johnstevenson1
                                        A lot of cycle stuff was special.
                                        Cotters are still 17/64″ x 26 to this day.
                                        Triumph speedo cables are 0.715 x 26
                                        Threads on Amal carb bodies are 15 thou undersize so if you use standard threads they suck air .
                                        The list is endless and not many are in tables.
                                        John S.
                                        #65977
                                          Problem is a lot of French cycle threads differed from the normal british threads, such as bottom brackets, pedals,freewheels, headsets and cotters. Mostly they were a close metric equivalent but not the usual ISO as that was not about then.
                                          As a lot of these early motorcycle builders were originally bicycle makers its very likely that their odd threads carried over.
                                          Jason
                                          Edited By JasonB on 24/03/2011 13:20:00
                                          #65985
                                          Gordon W
                                            @gordonw
                                            You probably know this, Terot, along with most makers in those days, bought in a lot of stuff, probably including wheels, certainly they used Jap engines. So could be any thread! Not much help. If you intend running the thing ,I would make a new spindle, then use any fine thread. Quite important the old front spindle.
                                            #66021
                                            JohnF
                                              @johnf59703
                                              Hi Ian,
                                              The simple answer is screwcut a LH nut to suit the wheel spindle–a simple operation providing you have a 127 or 63 tooth change wheel [only if your lathe is imperial]. If metric you can do the job even easier.
                                              To check the thread angle use a powerfull magnifier and offer up a threading tool of known angle and you will see which fits correctly.
                                              I do many “funny” threads but I use a toolmakers microscope to assertain the specification regarding angle,pitch, etc.
                                              Quite often old products–mostly older than yours–interchangability was not a criteria so “funny” threads that were close to standard sizes appeared and the man who made them made his own taps and dies–so long as they fitted together that was fine!!
                                              Good luck John F.
                                              #66025
                                              Richard Parsons
                                                @richardparsons61721
                                                Ian Checking the thread angle is quite easy if you have a good quality set of thread gauges (not those made by the yellow peril). I use the Whitworth set. If I cannot find a match its metric, so I try the metric gauges, if it don’t fit the metric it’s a BA (47.5&#176. or God knows what. If it fits the Whitworth gauge I hold it up to the light. A good fit it is Whitworth/BSF (55&#176. If it is not a good fit it is a ‘Unified’ (60&#176.
                                                Over here in Hungary much of the old Russian army gear is ‘Unified’ not metric. This seems to drive the locals ‘round the twiddle’. There was heaps of the stuff about, but the Orientals turned up with suitcases of forint and everything disappeared including some new pylons they were putting up.
                                                Dick
                                                #66026
                                                Richard Parsons
                                                  Confounded auto insert “smilies”.
                                                  Edited By Richard Parsons on 25/03/2011 06:03:56
                                                  Edited By Richard Parsons on 25/03/2011 06:04:33
                                                  #66033
                                                  Ian S C
                                                    @iansc
                                                    Dick was it Hungary where some one nicked a bridge afew years back? Ian S C
                                                    #66043
                                                    Ian Parkin
                                                      @ianparkin39383
                                                      Well after all you guys fine advice, I decided to buy a chinese die to match my tap so it will be 12mmx1.0 LH and hopefully just run the die down the spindle so it will be reasonably standard then …just the delivery time from china…it was only £8 in total though.
                                                      Problem with making a new spindle is thats theres a bearing cup threaded onto the middle of the spindle so making a new one of those starts getting complicated …so if i just leave the bearing cup on the oversize thread and cut down the exposed thread on each end.
