What sort of thread is 1/4- 32UNS -2A?
Home Forums Beginners questions What sort of thread is 1/4- 32UNS -2A?
  • #190376
    Steve Withnell
      @stevewithnell34426
      Is this normally referred to as 1/4 – 32 UNEF?
      2A appears to be the thread tolerance.
      Steve
      #7627
      Steve Withnell
        @stevewithnell34426
        #190378
        Tony Brazier
          @tonybrazier31255
          Hi that the same as glow plug thread for glow engines.
          Tony
          #190380
          Enough!
            @enough
            UN standards are:
            UNC – coarse
            UNF – fine
            UNEF – extra fine
            UNS – special (pitches not covered by the other categories)
            UNR – must have root radius
            1/4 – 32 is specified in the UNEF category. I don't know why it would be described as UNS.
            Thread classes are 1A/2A/3A and 1B/2B/3B the number being the fit (1=loose to 3=close). A is used for external threads; B for internal
            #190511
            Steve Withnell
              @stevewithnell34426
              Posted by Tony Brazier on 17/05/2015 22:36:47:
              Tony
              Thanks for that – I must have one in the box then!
              Steve
              #190716
              Steve Withnell
                @stevewithnell34426
                Hmm the nuts that I have which are specified as 1/4- 32UNS -2A, don't fit the enya glow plugs I have. The pitch is off just enough so the nuts don't run on to the plug thread. Don't worry, I'm not intending to fit nuts to my plugs, it was just an easy way to test Tony's point above.
                Steve
