What have I done wrong??
Home › Forums › Locomotives › What have I done wrong??
Viewing 25 posts - 1 through 25 (of 25 total)
  • #324003
    David Fox 3
      @davidfox3
      The six wheel on the Simplex shouldn't be too difficult surely? I am fairly new to model engineering but thought this should not throw up any great problems. I mounted each of the castings on a 4 jaw independent chuck and faced the back of each. Then whilst still in the chuck centre drilled then drilled through with a 1/2inch drill. Then bored it out to just under 11/16" and finished off each with a 11/16" hand reamer.
      I had bought a 3mt soft end 40mm x 40mm arbour which I turned down 15mm of which to be a tight fit on the newly bored and reamed wheels leaving a shoulder to support the back of each wheel. I then tapped an M8 thread in the end of the arbor so a bolt could then hold each wheel firmly in place.
      On trying the wheels on the arbor they fitted perfectly sliding on tightly with a little friction but on running the lathe the rim of each wheel moves from side to side by about 2mm when firmly against the shoulder! WHY? What have I done wrong?
      2
      The lathe is a Seig SC4 about 8 years old but not at all heavily used. The wheels cast iron and the 3 mt stub bought recently from the midlands model engineering exhibition.
      Any help gratefully received!
      Dave F
      Edited By JasonB on 28/10/2017 08:19:03
      #1650
      David Fox 3
        @davidfox3
        5inch Simplex wheels
        #324005
          How did you do the reaming? hand held or using the tailstock for support?
          #324009
          David Fox 3
            @davidfox3
            Hand held. But all the wheels are exactly the same.
            #324011
              Posted by David Fox 3 on 28/10/2017 08:31:32:
              In that case; logic suggests that the 4-jaw is mis-aligned
              Have you checked that the faces of the jaws are actually level ?
              [quote] I mounted each of the castings on a 4 jaw independent chuck and faced the back of each. Then whilst still in the chuck …  [/quote]
              Edited By Michael Gilligan on 28/10/2017 08:45:12
              #324012
              David Fox 3
                @davidfox3
                That's what I would have thought but surely if that were the case the rear face of the wheel would be slightly off or am I making assumptions here?
                #324013
                David George 1
                  @davidgeorge1
                  Hi when you machine castings you release stresses and when you undo the four jaw chuck the casting springs slightly. I would have skimmed both sides before finishing the bore.
                  David
                  #324015
                  Chris Evans 6
                    @chrisevans6
                    All is not lost. There should be enough metal in the bores to true up to 18mm after all you are making both parts so can use whatever size you want.
                    #324016
                    David Fox 3
                      @davidfox3
                      Thanks it certainly seems to have released some stresses. But mine have gone through the roof. Bizarre!
                      #324017
                      David Fox 3
                        @davidfox3
                        Posted by Chris Evans 6 on 28/10/2017 08:52:34:
                        Thanks. I think this will have to be the way forward!
                        #324018
                          Has the mandrel that you made been removed and refitted to the lathe between making it and mounting the wheels. If it was not seated right when machined or ha snot gone back in the same then that would give a constant error on the wheels.
                          Is there a slight radius on your mandrel where the spigot meets the flat face, often left by an insert tip, if you the edge of the holes needs to be chamfered/CSK to clear that and allow the wheel to sit down flat
                          I would have thought movement in the castings would not be the same for all wheels. Easily checked by placing the machined face on a flat surface and see if it is shaped like a Pringle.
                          Also not sure chuck jaws would cause the issue as the surface and bore would be true to each other as machined at one setting no matter how wonky the wheel was mounted.
                          You could check the bore is true to the machined face by turning the end of a bar to a good push fit in the 11/16" hole and then without removing from the lathe push on a wheel and see if it runs true.
                          Edited By JasonB on 28/10/2017 09:01:02
                          #324019
                          Chris Evans 6
                            @chrisevans6
                            Good thoughts Jason, I tend to undercut this type of mandrel out of habit to get a good seating from the mating part.
                            #324021
                            David Fox 3
                              @davidfox3
                              Posted by JasonB on 28/10/2017 08:58:13:
                              Great thoughts. Will report back in a couple of hours when I've been in the workshop. I did use an insert tip but. Cut slightly further and use its side face to give a slight inner taper on the mandrels side thus avoiding that small radius if you get my thoughts!!
                              #324028
                              MichaelR
                                @michaelr
                                It's good to see how others go about doing the same job, Simplex wheels on this forum Here Mike.
                                #324044
                                duncan webster 1
                                  @duncanwebster1
                                  I've never been over impressed with this method of machining wheels. I have 2 alternatives
                                  1. wheels in 4 jaw skim across what will be the inner face and bore a slight recesss at the outer end of the spokes. Then turn round and grip by this recess. Adjust to get the rim running true radially, face, turn outside diameter and bore for axles. It must be concentric, it's all been done at one setting
                                  2. wheels in 4 jaw, skim across what will be the inner face. Bolt some packing to faceplate slightly smaller than wheel OD using csunk screws, face off. Bolt wheels to faceplate, proceed as above. You need to put some suitable holes in the packing first to clear the bolts holding the wheels down
                                  The second way is easier. For smaller wheels I make a faceplate by drilling and tapping 2 holes in a suitable bit of bar, then mount in chuck, face off in situ. This means you can have the wheels securing bolts anywhere you want not dictated by faceplate. I don't use a reamer (too mean to buy one) just bore to size and make axles to suit. David can recover his wheels by using method 2 and clocking the OD to run true before reboring axle holes by as little is needed to true them up.
                                  Edited By duncan webster on 28/10/2017 10:43:26
                                  Edited By duncan webster on 28/10/2017 10:50:07
                                  #324046
                                  OuBallie
                                    @ouballie
                                    Did you clean the spindle bore before inserting the mandrel?
                                    Geoff – Put the Marlow to good use yesterday.
                                    #324069
                                    Anonymous
                                      I'd put my money on the reaming being the cause. Using a hand reamer without guidance isn't going to create an accurately aligned hole. I'm with Duncan I'd have bored to size against a home made gauge. If I had an 11/16" machine reamer I might have used it, but I haven't got one.
                                      #324082
                                      Bob Rodgerson
                                        @bobrodgerson97362
                                        I tend to agree with Andrew, hand reaming without a guide is prone to problems. I always try to use a centre held in the tailstock to hold it true while holding the reamer with an adjustable spanner or tap wrench if it will fit on the flats on the end of the reamer while advancing the tailstock. It's a bit od a juggling act but it gets results.
                                        However for really Concentrically accurate work nothing beats working with a go nogo gauge or a pre-prepared mandrel of the desired size and boring to suit.
                                        #324093
                                          Note: For my 'analysis', I was relying relying upon this statement ^^^ being true [at least to within the capability of David's instruments and technique] … Presumably, any of the other explanations offered would result in measurable differences between the individual wheels.
                                          MichaelG. dont know
                                          #324099
                                          Mick B1
                                            @mickb1
                                            Maybe it's how I'm reading it, but I can't see how this would occur except by eccentricity of the initial 4-jaw setting.
                                            Why wouldn't you use the reverse jaws on your 3-jaw to face the rear, and bore for the axle? It's only going to be a couple of thou out, and you can clean that up when you mount on the mandrel. Or is the periphery of the casting too rough?
                                            #324109
                                            Ian S C
                                              @iansc
                                              A hand reamer generally has a centre hole each end, when reaming a hole in a piece machined in the lathe, leave the piece in the lathe take the reamer and back it up with the tail stock centre, and as you turn the reamer/ or the chuck (I don't use power for this), wind the tail stock in, keeping pressure on the reamer. Cast Iron, no lubricant, steel lubricate, I just use engine oil.
                                              Ian S C
                                              #324110
                                              David Fox 3
                                                @davidfox3
                                                Well I've been busy in the workshop and I think – surprisingly – that it WAS the reamer as it seems that if I re bore the wheel it is again all ok. I mounted the wheel on the faceplate (thanks Duncan) centred as accurately as possible then skimmed the bore until a continual cutting noise was heard from the boring tool then one more fine cut passed through twice. I then used the old mandrel. There was sufficient mandrel stock left to remachine to the new diameter thankfully. Now all I have to do is machine the other wheels to the same size as the mandrel. So I'm using Bobs suggestion here.
                                                I still think it is a bit of a mystery, as each wheel was so similar, but why a four jaw rather than a self centring three jaw? Well the simplex wheels are just over the maximum capacity for that while the four jaw was ok – just.
                                                I was conscious of the dirty taper potential but did clean with cloth and finger!?!
                                                Thank you one and all for all your suggestions and I hope I can finish these wheels without any more fuss.
                                                #324151
                                                duncan webster 1
                                                  @duncanwebster1
                                                  There are 2 reasons for not boring the hole whilst facing the back
                                                  1. sometimes the front detail of the casting isn't concentric with the back, so when you turn it round and set it on you mandrel it looks poor with the boss and rim of varying thickness
                                                  2. You have to make a jig to get the bore on centre, or spend time with a clock.
                                                  The original post suggests that David was going to bolt the wheel to his mandrel and then machine the outside profile. It would probably ring like a bell. The Martin Evans method uses a mandrel, but just to centralise the bore, the wheel is still bolted to the faceplate for machining
                                                  Edited By duncan webster on 28/10/2017 18:46:06
                                                  #324240
                                                  Jon Cameron
                                                    @joncameron26580
                                                    I may be wrong here, but I think the sequence of machining is wrong. The backs of the wheels should be faced off, each in turn to gain a reference point, then rotated in the chuck and tapped against the jaws to seat it, the rim of the wheel can then be clocked in, so it runs concentric, then face the front of the wheel centre, and drill and ream the wheels bore. This means that the rear and the front centre and bore can all be trued up to one another, the wheels can then be mounted onto a mandrill and the rest of each wheels tread machined. Along with crank webs balance weights.
                                                    You say that you've been using a MT3 arbour turned to fit the wheels bore. This should mean that the wheels are constant with their alignment. All I would say is to add support to the mandrill by using tailstock support. That way when machining the rear of the wheels tread the mandrill is not likely to move out of the spindle.
                                                    I hope this is of some help
                                                    Sorry just read the post above
                                                    Edited By Jon Cameron on 29/10/2017 11:31:42
                                                    #324243
                                                    David Fox 3
                                                      @davidfox3
                                                      Thanks. It's too late to change the order of machining, and next time I will do as suggested, but the suggestion of tailstock support though is certainly worth doing. Thanks.
                                                    Home › Forums › Locomotives › Topics
