What Did You Do Today (2017)
Home › Forums › The Tea Room › What Did You Do Today (2017)
Viewing 25 posts - 801 through 825 (of 2,518 total)
  • #294968
    ChrisH
      @chrish
      Yep, with you guys with Led Zepp, Pink Floyd, Stones, Cream, Moody Blues, Joe Cocker, Hendrix, Dylan, Travelling Wilburys, whatever, 60's mix, a bit of classical thrown in, but envy you being able to belt it out as it should be – I try it and get complaints from Senior Management worrying about noise for our neighbours – they might like it as well but they aren't allowed to sample it. Mind you, they are hitting their 90's, so I suppose it's fair doo's.
      Chris
      #294970
      John Stevenson 1
        @johnstevenson1
        Why isn't it obvious that engineer's like heavy metal ? ?
        #295010
        Richard Marks
          @richardmarks80868
          Posted by ChrisH on 25/04/2017 23:07:57:
          Chris
          First thing I did when I moved into our house was wind up the stereo and pop round the neighbours to see how loud it was in their house, luckily we have 2 ft thick stone walls between us so there was no problem , my workshop is 50m down in the garden so I can wind up the music when I want.yes
          #295062
          JA
            @ja
            Retightened the gib strips on the milling machine. A bit of a palaver working blind under the table with ones hand in swarf.
            The machine was beginning not to hold a position and a give a poor finish. The adjusting screws for the compound slide rest (that is the bit between the base and the table) certainly needed tightening. Any movement would not have been seen on the DRO which reads between the table and compound slide.
            JA
            #295110
            Anthony Knights
              @anthonyknights16741
              In the workshop today I replaced an ailing 5 foot fluorescent light fitting with 3 batten lamp holders fitted with 9 watt LED lamps (60 watt equivalent). Switched on and WOW, bright or what. If I do the same to the other fitting, I will probably need sunglasses.
              #295121
              Emgee
                @emgee
                Hi Anthony
                What make, model and colour were the 9watt LED lamps please ?
                Emgee
                #295123
                matt merchant
                  @mattmerchant42413
                  In the man cave today making soft fluffy swarf, started cutting up timber for a bench to park a mini lathe on.
                  had to do the hand saw routine as my trusty 14.4v dewalt circular saw has finally given up the ghost after 15 years of service/abuse (10 of them on building sites).
                  so a trip to screwfix tomorrow for a cheap corded replacement and a short memorial service will be held for the dewalt.
                  on the music was in brum a couple of weeks ago watching The Who still ripping it up, Daltrys still got one hell of a voice
                  Matt
                  #295147
                  Anthony Knights
                    Hi Emgee,
                    Lamps are "e-luminate" 6500K daylight from Home Bargains. The model number on the packaging is
                    GLS B22. These are BC ends but they sell the screw ended ones as well.
                    #295151
                    Anthony Knights
                      I've just done a rough mental calculation. The old fluorescent was 80 watts. I'm now getting over twice the light for about one third of the electricity.
                      #295156
                      Martin Kyte
                        @martinkyte99762
                        Which in relation to the Coal thread demonstrates the other part of the power generation question. If you don't use it, you don't need to generate it.
                        regards Martin
                        #295158
                          @mike89748
                          Anthony: The same rough calculation works in my home in the rooms which are totally LED lit, which is most of them. Better light from one third the electricity. I have not calculated the overall financial advantage properly, but our electricity bills after the usual dark winter here in north Scotland are noticeably lower – and that's despite the regular use of washing machine and new A-rated dish washer. I've also just bought LED lights for my "tadpole" tricycle, and cannot believe how much light I get from a couple of AAA batteries front and rear.
                          #295188
                          Ian S C
                            @iansc
                            The only thing with LED lighting is that you loose about 70 Watts of room heating per bulb, but I think you gain on the lighting side.
                            Ian S C
                            #295190
                            Martin Kyte
                              @martinkyte99762
                              To be far you get to choose if you want to turn any heating on rather than it being a side effect.
                              At least we are on the right side of the curve now The actual lighting is better incandescent to LED, rather than worse, incandescent to compact florescent.
                              #295191
                              Martin Kyte
                                @martinkyte99762
                                I of course mean fair.
                                #295199
                                Roderick Jenkins
                                  @roderickjenkins93242
                                  Just finished the rivet squeezers, castings from Atelier.
                                  Shows the sets for 1/16" and 3/32" rivets and the D bits I made for cutting the domed recess Seems to work OK on 1/16", not totally convinced about 3/32" – I haven't yet managed a good domed head on well annealed copper but I may need to grind the set back a little.
                                  Making them was a catalogue of disasters. Amongst which cutting the first thread in silver steel was fine – single point to 3/4 depth in the lathe and then chased with a die. The second one needed 4 attempts because the die was just tearing up the threads. Eventually changed to a new die and the result was OK but certainly not perfect. Possibly the silver steel was not annealed properly over the full length. You'll also notice the bush in the largest casting, the result of picking up the wrong drill…
                                  I'm off to Specsavers.
                                  Rod
                                  #295239
                                    Today … I had my second Cataract operation: The surgery went very smoothly this time.
                                    Looking forward to using a 'matched pair' of eyes !!
                                    Brian H
                                      @brianh50089
                                      I'm sure that we all wish you well Michael and hope for a speedy recovery.
                                      #295278
                                      roy entwistle
                                        @royentwistle24699
                                        MichaelG Best thing that happened to me, but I do find sunlight can be a bit bright.
                                        Best wishes
                                        Roy
                                        #295284
                                        bricky
                                          @bricky
                                          Started to make an E32 collet chuck for my large bore Myford.I used an 80mm bar and have bored through at the collets smallest dimension and have bored to thread size for the spindle nose .First thing in the morning I will bore out the register dimension and set up the metric gears to cut the spindle thread..
                                          Frank
                                          #295286
                                          NJH
                                            @njh
                                            Good luck Michael
                                            I have an increasingly troublesome cataract and I guess I had better bite the bullet pretty soon to get it fixed. I must confess that I find the prospect daunting!
                                            Norman
                                            #295303
                                              Brian / Roy / Norman
                                              Thanks for your good thoughts.
                                              I had the left eye done in January … There was a 'complication' in the surgery, which meant 30mins on the table instead of the usual 10mins [if anyone needs to know the details, please feel free to send me a P.M.], but the outcome was astonishingly good.
                                              Yesterday's work on the right eye went like clockwork, and things are looking very good this morning.
                                              [Norman] Like you; I have many interests that involve optics, and, to be frank I was terrified of committing to invasive surgery … but I'm very glad that I did.
                                              #295309
                                                …. For the not-too-squeamish here are a couple of short videos about Cataract Surgery:
                                                http://www.nhs.uk/Video/Pages/Cataractanimation.aspx
                                                  I'll pass….
                                                  But glad it all went well.
                                                  nigel jones 5
                                                    @nigeljones5
                                                    Today is my birthday, and I hate birthdays. If I had my way id be in the workshop boiler making but no, we have to 'go out' somewhere GRRRRRRRR
                                                    #295317
                                                    Martin Kyte
                                                      @martinkyte99762
                                                      Posted by Michael Gilligan on 28/04/2017 07:54:16:
                                                      Does that mean you are left with a tic in one eye.
                                                      ;0)
                                                      Martin
