What did you do today (2015)
Home › Forums › The Tea Room › What did you do today (2015)
Viewing 25 posts - 2,176 through 2,200 (of 3,154 total)
  • #201107
    Circlip
      @circlip
      " I wonder how it copes with trees devil "
      It comes a very poor second. Yippeethumbs up
      Regards Ian.
      #201108
      Cornish Jack
        @cornishjack
        Limited number of spotty kids with that sort of disposable dosh! In some ways similar to the threat from kites – we found out the hard way in Cyprus – flew through a kite string along Lady's Mile. Wrapped itself round the main rotor and tail rotor pitch change rods such that they went banana -shaped!!surprise Quick landing and recovered by low loader … not nice! Some protection from drones in their limited range but idiots abound and the prevalence of lasers is an equal or greater threat.
        rgds
        Bill
        #201110
        JA
          @ja
          Drones – the idiots will soon leave the scene and find something else. It was the same with hang gliders and micro-lights. However until they do so ……….
          JA
          #201127
          John Stevenson 1
            @johnstevenson1
            Not really unusual enough for the Bodgers Lodge post but got this pump shaft in yesterday.
            A bit rusty and the rusty bit is where the seal goes. Have built these up in the past as being quicker but think this one is past it seeing as it's a standard size bar at 50mm.
            So saw the impellor off, bore the slug out and make a new shaft.
            Also make a new threaded collar to hold the bearing, they had to split the old one to get it out the pump.
            All done and dusted, just needs the bearing changing when they fit the pump back together.
            #201134
            KWIL
              @kwil
              CAA rules on drones (UAV) apply equally to commercial as well as "fun" activity.
              Break the rules and they will go for you through the Courtsyes
              #201136
                Basically no different from any small R/C aircraft.
                Looks like Iris would struggle to fulfill all those conditions – how do you 'keep it in view at all times' when it's following you down a skip slope?
                Full regulations (they are few for models) are here
                ‘(1) A person must not cause or permit any article or animal (whether or not attached
                to a parachute) to be dropped from a small unmanned aircraft so as to endanger
                persons or property.
                Edited By Neil Wyatt on 20/08/2015 17:03:54
                #201138
                ega
                  @ega
                  Neil Wyatt:
                  I know it's possible to cut hard steel on a bandsaw but I am curious as to how you did it (or would have done it).
                  My caliper knurling tool uses two 1/4" Clarkson-type broken endmills as pins retained by nuts on the 1/4 thread; my original hardened (?) silver steel items wore rapidly.
                  #201151
                  Chris Bradbury
                    @chrisbradbury76252
                    Hi everyone, this is my first post so please be gentle. First I think I should tell you all a little about myself. I'm at present living on my sailing boat in north Brazil. I will be leaving here soon heading towards the Caribbean. I spent a large part of today looking through my lockers for a small piece of ss bar I thought I had but with no luck. As I get older I find I spend lots of time looking for things. What this now means is that I am going to have to turn down a larger piece to make a pin to fit the tiller for the electronic self steering. Last time I turned some 316ss it took forever as I had to keep stopping to let it cool down. I have a Axminster C1 lathe that I can use in the cockpit this has no coolant so I can only use a cutting fluid applied with a small brush. On top of this it keeps raining here so the lathe is in and out of the cockpit like a fiddlers elbow. I think it is time for a beer!
                    #201177
                      No special secret, it's not super-de-dooper tool steel, just a decent medium-high carbon steel that hasn't picked up nicks or scratched in many years of being on my bits a shelf. I could see it was not mild steel by the bushy sparks and rapid heating when I was linishing it.
                      I used bronze pins on my caliper tool, I haven't checked them but its about 15 years old and still works (although I don't use it a lot).
                      ega
                        @ega
                        Thank you. My hard HSS knurl on hard HSS pin is theoretically wrong I believe and I anoint generously with moly grease. When and if my pins need replacement I will certainly consider bronze – better "tribologically" but presumably less resistant to shear.
                        #201321
                        john carruthers
                          @johncarruthers46255
                          se3 g&g after.jpgReceived a nice prezzy today, an old SE3 G&G (Mamod) 2 cylinder engine in need of TLC.
                          Spent a pleasant afternoon cleaning and fettling, now it runs on air. It is missing its burner so I shall make a temporary meths tray tomorrow and get the buffing wheel going.se3 g&g before.jpg
                          #201336
                            Your 'before' one looks mebetter than my one does 'after'. Great fun to have though, I have three mamods (That stationary, road roller and Mercedes) and a few accessories.
                            Lathejack
                              @lathejack
                              I spent some time restoring the BSA seat with a new cover, thankfully the seat base is the original genuine BSA item which I have blasted and painted. The orange strip is the plastic safe edging from the large bandsaw blades we use at work.image.jpgimage.jpgimage.jpgSeat completed, dog rarely misses a photo opportunity.image.jpg
                              #201378
                              daveb
                                @daveb17630
                                Nice job, looks very much like an A65 seat.
                                #201379
                                Lathejack
                                  @lathejack
                                  I also found time to strip and inspect the notoriously troublesome Mazak bodied BSA gear type oil pump. The drive spindle was binding very badly, although the pump internals are in excellent condition still with minimal clearance around the gears.Oil pump.…………….The spindle body was reamed while clamped to the mill table to ensure the bore remained square to the base.Oil pump spindle housing.……………….These are the original scavenge gears from the bottom of the pump. One of them was found to be faulty, its teeth had been machined eccentrically to its bore, which caused a tight spot as they rotated. Both were replaced with a perfect set from another old used pump.Pump repaired.……………….The oil pump back in place.BSA engine.…………………..An oil pressure gauge was added to keep an eye on things. New genuine Lucas direction indicators have also been fitted. A previous owner had already fitted the later type switch gear which includes an indicator switch, these were fitted to BSA and triumph bikes from 1971 following their total revamp of their whole rolling chassis and all cycle parts.image.jpg………………..Although my model engineering activities have been sidelined for a while, it is my model engineering workshop that is being used to do all the work.image.jpg
                                  #201381
                                  Lathejack
                                    @lathejack
                                    Daveb.
                                    Yes, it is quite similar to the A65 seat with its hump. A new non genuine seat for the Starfire is a whopping £200. The new seat cover was just £25 and its quality is better than the price suggests.
                                    Edited By Lathejack on 21/08/2015 21:39:13
                                    #201393
                                    Anonymous
                                      Posted by NJH on 20/08/2015 09:34:12:
                                      I view these drones with dismay.
                                      Andrew – if you are lurking – what is the view of these in the gliding / light aviation community? As far as I can see there is no control over their use and the prospect of a collision with one doesn't bear thinking about.
                                      Norman
                                      Oddly enough there doesn't seem to have been much discussion. Indeed a search for 'drones' on the BGA website didn't produce any results. However, the CAA is well aware of the issues and is actively involved, so I suspect the BGA/LAA are just keeping an eye on the situation. In theory I think that drones are limited to 400ft, and strictly we're not supposed to be below 500ft except when taking off and landing. In practise of course it doesn't work quite like that, and certainly doesn't take into account hill soaring, when you may be below the level of the hill.
                                      On a personal level I am very nervous about the prospect of Amazon and the like using drones for delivery. I don't like the idea of some pretty heavy drones flying overhead willy-nilly. Apart from the practical difficulties of actually delivering to the front door there are some more important issues. One major question is how will the companies concerned deal with the situation when a drone kills somebody? And that's when not if; could be an engine failure, it looses grip on the package, or flys up to the front door and clobbers somebody standing there.
                                      You can also bet your bottom dollar that the drones will be spying on you, and the data sold on to other companies.
                                      #201396
                                      Bazyle
                                        @bazyle
                                        Amazon deliveries just a pipe dream to sucker in investors maybe. Also cover for military deliveries – eg more ammo for surrounded troops.
                                        By chance looked at the 'wanted' adverst which I normally never do an was able to send someone some info that not many people will have. Same chance happened a couple of years ago the only time I looked at the JS forum and had a rare manual that was just requested that day.
                                        #201408
                                        Tim Chambers
                                          @timchambers76147
                                          May be a little balance to the media hysteria.
                                          Clive Hartland
                                            @clivehartland94829
                                            Supply ammo to troops with a current type drone, no way, as ammo is heavy. Have you ever carried 2 belts of ammo? A box of 500 rounds or so is very heavy and you need to carry 2 to be balanced.
                                            Thats why its dumped from low flying planes.
                                            #201448
                                            Ian S C
                                              @iansc
                                              For info on "Drones" have a look at the civil aviation section of Wings Over New Zealand. There is quite a bit about worries from GA pilots encountering UAVs(?), and now about the recently introduced regulations.
                                              #201453
                                                Posted by Chris Bradbury on 20/08/2015 19:52:21:
                                                Hello Chris,
                                                Apologies for the long time it has taken for your post to appear., I thought I OK'd it a couple of days ago?
                                                Future postings will appear automatically.
                                                Welcome aboard,
                                                capnahab
                                                  @capnahab
                                                  Started making new felt oil reservoirs/ wipers for my lathe bed. The left hand one is a 1956 model, cardboard template and 2015 model. The old one is full if ancient castor oil crud and leaves brown unpleasant looking streaks resembling rust. Felt is from British felt ( usual disclaimer etc),
                                                  needed some help from Sheffield, – one of the finest tools a man could own. No moving parts.
                                                  Edited By capnahab on 22/08/2015 18:50:30
                                                  #201493
                                                    Oh no! I have a small invasion of small parasitic wasps banging around in my spherical paper lampshade and occasionally landing on my desk with a surprisingly loud rap.
                                                    I've closed the window, but i suspect that I must have brought home an 'interesting' bit of plant that has proven to be a gall… again.
                                                    I know a chap who wrote the book on plant galls. I imagine he must get this problem all the time.
                                                    Gah! – There's one crawling right next to my keyboard no – it's landed on my left hand!
                                                    Rainbows
                                                      @rainbows
                                                      Discovered today a 1491w motor running loose on the floor is suprisingly a source of less noise compared to a 90w sewing machine motor mounted to a desk.
