Welding Mazak
Welding Mazak
  • #332336
    vintagengineer
      @vintagengineer
      What is the best way to weld Mazak?
      #33125
      vintagengineer
        @vintagengineer
        #332337
        Dusty
          @dusty
          Mazak cannot be welded, its melting point is far to low. It can be soft soldered I understand, but have never tried, or needed to myself.
          #332338
          donkey
            @donkey
            A good way to join it with strength is with a product like lumiweld. It can be done on a cooker flame. And uses a stainless rod to rid the weld puddle of oxidation. I have used it on motorcycle parts. And have never rebooked any of them.
            #332340
            not done it yet
              @notdoneityet
              I don't believe you will weld mazak in the way welding works – ie fusing the metal by melting at the joints, often using a filler to build up the joint. Filling with a braze type of filler is possible by careful selection and careful temperature control, but brazing is not welding – just higher temperature than most soldering.
              Mazak is just what it is-a cheap diecasting material, often susceptible to expansion if stored in damp conditions.
              #332343
              Hillclimber
                @hillclimber
                #332360
                  In theory it should be possible to weld it, if you can find a way to create a weld pool without the heat just melting the whole thing. You could cast up some sticks of mazac for filler metal.
                  The trouble is it melts at such a low temperature it will be hard to get the sharp temperature gradient usually involved in welding.
                  Perhaps a micro Oxy-propane set or a small carbon arc would provide a localised enough source of heat.
                  I would go with the Lumiweld suggestion, it's probably more strong and stable than Mazac.
                  vintagengineer
                    @vintagengineer
                    I rebuild SU and they are made from the worst possible shit imaginable! The also suffer from hydrogen embrittlement which doesn't help!
                    But I will try lumiweld with both a flame and my tig welder.
                    #332378
                    J Hancock
                      @jhancock95746
                      Just be prepared to catch the puddle of molten Mazak, it happens quickly !
                      You might try one of the really low temperature 70deg alloys as a filler ?
                      #332379
                      Hillclimber
                        @hillclimber
                        If you are using TIG, I should have thought pulse essential. But take a look at these, although the thread on the Miller site is a little old…
                        http://tinyurl.com/y7rl9u36
                        http://tinyurl.com/y846gung
                        Finally, I'd suggest you pay attention to those zinc vapours if you try welding. They are unpleasant and dangerous.
                        #332395
                        Ady1
                          @ady1
                          I rebuild SU
                          Is that SU carbs?
                          #332403
                          vintagengineer
                            @vintagengineer
                            Posted by Ady1 on 17/12/2017 11:36:38:
                            I rebuild SU
                            Is that SU carbs?
                            Yes, sorry I think faster than i can type!
                            #332415
                            donkey
                              @donkey
                              My post should have said never rebroken any of them. Seems I type too fast also.
                              Bri
