I recently inherited a warco VMC MILLING MACHINE manufactured 2011. In an effort to move the mill I removed the head from the mill and disconnected the motor. I thought it would be a good idea to take a picture on my phone so it could be easily re connected. Unfortunately I lost my phone. Warco aren’t able to give me a wiring diagram with the wiring connections on for the motor which seams hard to believe and is a bit disopointing.
There are 4 wires and an earth wire which are labelled L11, N11, Z1 AND Z2
The connector block inside the motor has six terminals
Top left Z2/W2 , U2, V2
Bottom left U1, V1, Z1/W1
The motor is a dual capacitor induction motor model YL90L-4 /240 V/ 1400 RPM/ 1.5 HP
If anyone has a warco with the same motor and would not mind taking a look under the motor cover I would be most grateful
Kevin
