Turning tool holder
Turning tool holder
Home › Forums › General Questions › Turning tool holder
  • #220882
    Old School
      @oldschool
      I have got some PCD tips ref TPGW080202 and I need a holder for them any ideas where I can get one.
      I want to use them for the turning of the outside diameter of pistons made from aluminium with a high silicon content
      Thanks Oliver
      #24322
      Old School
        @oldschool
        #220896
        David Clark 13
          @davidclark13
          I think Kennametal do them. I think that is where I used to buy the tips.
          #220976
          Old School
            @oldschool
            Had a look at Kennametal no joy can anyone one else help or do I make one its not going to be taking big cuts. Would mild steel do?
            #220983
            Emgee
              @emgee
              Have you considered using a left handed boring tool that takes the TPG inserts, you would of course fit the tool as a normal boring tool but use on the OD and not ID.
              If you make your own you could use silver steel and harden and temper if required.
              Emgee
              #220988
              Muzzer
                @muzzer
                Triangular, 11 degrees clearance, ground, with countersunk clamp screw hole. 8mm inscribed circle, 2.38mm thick, 0.2mm radius. Something like this?
                Bit of a minority sport by the looks of it. If you click under where it says "See pages B109–B112 for inserts", it shows you a pic of the dimensions etc. It has 5 degrees slope on the top mounting face. Combined with the 11 degree insert, that leaves 6 degrees of clearance. M2.5 / Torx T7 screw? You can get the screws from APT.
