Test the team
Test the team
Home › Forums › General Questions › Test the team
Viewing 25 posts - 1 through 25 (of 26 total)
  • #230096
    John Fielding
      @johnfielding34086
      In an old engineering text book I came across some names of things I hadn't seen before and I wondered how many readers know what they refer to:
      Half Imperial
      Imperial
      Double Elephant
      Antiquarian
      They all relate to the same type of object – What is it?
      #24439
      John Fielding
        @johnfielding34086
        Todays quiz question
        #230098
        Jeff Dayman
          @jeffdayman43397
          Paper sizes, old ones. JD
          #230099
          Anonymous
            Posted by Jeff Dayman on 15/03/2016 14:39:49:
            Yep, everyone kno that, even Molesworth!
            #230100
            Bubble
              @bubble
              Hello
              In my day on the Railway they referred to drawing board sizes
              Jim
              #230103
              John Fielding
                @johnfielding34086
                Yes, you are correct.
                This book was published in 1908. I had never heard of them, but I wasn't around in 1908surprise
                BTW Who is Molesworth?
                Edited By John Fielding on 15/03/2016 14:56:59
                #230107
                Lambton
                  @lambton
                  Molesworth ah! I have a copy of his pocket book.
                  #230112
                    To late in the day to catch us on that one
                    Anyone know why foolscap is called that – without cheating?
                    John Fielding
                      @johnfielding34086
                      Aaaah Neil,
                      You will be asking us what a "Sagger Makers Bottom Knocker"embarrassed is next!
                      Also found another reference to paper types: Whatman's NHP cheeky
                      #230115
                        Posted by Neil Wyatt on 15/03/2016 15:35:16:
                        Yes … It's proportions are the Golden Section, the same as a Fool's Cap
                        Ajohnw
                          @ajohnw51620
                          I needed to check but as I thought the name probably comes from watermarks that were used.
                          Things have been A4 etc for as long as I had been in work. Even detail drafting – an A0 sheet a day keeps the doctor away – no space wasted. A GA might take a bit longer. Makes me laugh when I see people using cad but that sort of speed does take a while to acquire. Getting black lines too with a pencil.
                          Edited By Ajohnw on 15/03/2016 15:51:13
                          #230123
                          John Fielding
                            @johnfielding34086
                            Hi Ajohnw,
                            Almost,
                            NHP stands for "Not Hot Pressed" there was a Whatman's HP paper as well (Hot Pressed) and apparently in those days all paper had a watermark.
                            The things you learn in book ….Eishsurprise
                            #230125
                            Anonymous
                              Posted by John Fielding on 15/03/2016 14:56:10:
                              The scourge of St Custard's; see this link:
                              #230172
                                Posted by Michael Gilligan on 15/03/2016 15:42:56:
                                I hope that's a jest
                                It was defined as a standard in 1975.
                                charadam
                                  @charadam
                                  Having worn one a time or two, I think foolscap (13.5×8,5 inches) is just the right size to form a Dunces' cap.
                                  Edited By charadam on 15/03/2016 23:07:21
                                  Edited By charadam on 15/03/2016 23:09:04
                                  #230194
                                  Bazyle
                                    @bazyle
                                    Also found in old book. Anyone got an odontograph? An original not a copy. I saw one in a museum but I just can't remember which one.
                                    usual rules – no googling though there is only one dictionary that recognises it and clearly doesn't know what it is.
                                    Edited By Bazyle on 16/03/2016 07:34:23
                                    #230201
                                    Anonymous
                                      Posted by Bazyle on 16/03/2016 07:31:00:
                                      No, only a reprint in a book on gear design.
                                      #230202
                                      pgk pgk
                                        @pgkpgk17461
                                        Posted by John Fielding on 15/03/2016 14:35:12:
                                        Half Imperial
                                        Imperial
                                        Double Elephant
                                        Antiquarian
                                        Some impressive knowledge here. I though these were portions of chips..
                                        2/6d worth
                                        5 Bobs worth
                                        An American portion
                                        A special order for secondhand bookshop owners.
                                        And an odontograph is a tool for calibrating overbite in brace design…
                                        #230217
                                        Ian S C
                                          @iansc
                                          Bazyle, was it Collins English Dictionary? Odontograph: An aid to marking out gear teeth in which a circular curve is substituted for the true involute curve
                                          #230310
                                          Bazyle
                                            @bazyle
                                            Posted by Ian S C on 16/03/2016 10:36:08:
                                            Yes, that really tells you a lot doesn't it laugh
                                            #230328
                                              The dunce's cap is an urban myth, anyone who remembers foolscap will know that it makes a hat suitable only for a toddler!
                                              The real reason is that it used to bear a watermark of a jester's (fool's) cap.
                                              Some excellent examples HERE
                                                Or:
                                                odontograph
                                                (ō-dŏn′tō-grăf) [″ + graphein, to write]
                                                Device for determining the degree of uneven surface of tooth enamel.
                                                #230354
                                                Ajohnw
                                                  @ajohnw51620
                                                  I think it's a bit more complicated than that but not much info about
                                                    Lots of detail here
                                                    star Download is available here [despite what Google says ^^^]
                                                    Edit: More books by Grant are available smiley
                                                    Edited By Michael Gilligan on 17/03/2016 08:16:36
                                                    #230396
                                                    Ian S C
                                                      @iansc
                                                      I just quoted all that was in the Dictionary, which if anyone wanted to research the item gives a start, but only just.
                                                      Ian S C
