Taps with plus sizes?
Home › Forums › Workshop Tools and Tooling › Taps with plus sizes?
  • #537273
    Ian Parkin
      @ianparkin39383
      I was browsing eBay looking for a new tap and noticed a few 18mm x 1.5 taps with + 004” and + 0.24 after the size
      i must confess i had not seen such before
      why have an oversize tap?…only seemed to be for 18mm that I’ve seen
      #20226
      Ian Parkin
        @ianparkin39383
        #537274
        Pete.
          @pete-2
          I think it's for galvanised bolts etc?
          #537279
          Ian Parkin
            @ianparkin39383
            And are galvanised bolts common in m18?
            #537282
            colin hawes
              @colinhawes85982
              They are used on steel that has to be case hardened to allow for hole shrinkage/distortion. Colin
              #537291
              Tony Pratt 1
                @tonypratt1
                Posted by colin hawes on 31/03/2021 17:28:44:
                Good engineering practice is to plug tapped holes so the threads remain soft during the case hardening process or you can carburise the part then drill & tap the required holes then finally harden.
                Tony
                #537307
                Pete.
                  @pete-2
                  Oversized taps do not only come in m18.
                  #537314
                  colin hawes
                    @colinhawes85982
                    Posted by Tony Pratt 1 on 31/03/2021 17:59:10:
                    Tony
                    I have cyanide case hardened threads to about .005 deep on tooling that requires a wear resistant tapped hole. It gives long life and greater strength. The taps used were known as "B" taps. Colin
                    #537326
                    old mart
                      @oldmart
                      Pre plating and anodising taps will be different oversizes depending on the exact conditions. At the museum we have a large number of taps, mostly given to us and I get rid of the oversize ones before they cause problems.
                      #537337
                      alan ord 2
                        @alanord2
                        Old Mart you are correct. I used to source pre plating taps, which are slightly oversize for the tapped hole in a component. After plating the tapped hole is to the correct size.
                        This is common in industry.
                        Alan.
                        Edited By alan ord 2 on 31/03/2021 20:33:34
                        Edited By alan ord 2 on 31/03/2021 20:34:18
                        #537340
                        Tim Stevens
                          @timstevens64731
                          M18 x 1.5 = sparking plug size before WWII* – just in case it helps.
                          * except model T Fords, of course.
                          Tim
                          #537344
                          bernard towers
                            @bernardtowers37738
                            Didn’t know anodising changed dimension, mine doesn’t,!!
                            #537353
                            Stueeee
                              @stueeee
                              Posted by Tim Stevens on 31/03/2021 21:18:32:
                              Tim
                              Model T was/is 14 TPI 1/2" American Pipe thread IIRC…
                              Model "A" Ford and early Chevrolet used 7/8" x 18 UNS spark plugs, took a while for the world to arrive at "standard" spark plug threads.
                              #537419
                              Tim Stevens
                                @timstevens64731
                                Not wishing to swerve away from the original thread, but there are currently 4 'standard' plug threads, as well as the piddly little things used in ic engine models.
                                Tim
