SPG SP2109-11 bench lathe
Home › Forums › General Questions › SPG SP2109-11 bench lathe
  • #27537
    phil1962
      @phil1962
      #487485
      phil1962
        @phil1962
        Hi fellas any one got any info on the SPG SP2109-11 BENCH LATHE
        dose it use a thread dial indicator as don't see one fitted in pics I have seen of it
        what threads dose it cut is it metric ? cheer for any help ATB Phil
        #487490
          Threading capacity is shown on SPG's website
          #487495
          Bob Stevenson
            @bobstevenson13909
            According to the website it is a metric lathe and, as it comes, can cut threads 0.03mm to 3mm….it also appears to be the same lathe as Warco equivalent with detail differences such as no 4-jaw, no rests, no faceplate etc so probably no thread indicator……
            Check price in relation to what they supply and the spec…..I suspect that once you take into consideration what's misssing and transport costs etc there will not be much in it.
            #487629
            phil1962
              @phil1962
              cheers fellas
