Small dc brushed motors
Home › Forums › Help and Assistance! (Offered or Wanted) › Small dc brushed motors
  • #559478
    Bob Mc
      @bobmc91481
      Hi All…
      am in the process of making an r/c boat, I need to find out which motor to use, I have already used a '400' type motor but have no idea what this means … I will require a larger motor for the next build so need to know volts/amps/rpm/mechanical size etc…. is there a chart for all this?
      will be grateful for any information….Bob.
      Edited By Bob Mc on 23/08/2021 08:09:09
      #33886
      Bob Mc
        @bobmc91481
        Manufacturers size designations.
        #559481
        michael howarth 1
          @michaelhowarth1
          A lot of the information that you require can be found on The Component Shop website catalogue.
          Mick
          #559483
          Circlip
            @circlip
            Try this site Bob, :- Model Boat Mayhem – Index
            Regards Ian.
            #559488
            Jouke van der Veen
              @joukevanderveen72935
              Some years ago I completed a 1 meter long tugboat, originally built by my son 25 years ago.
              Searching for a motor I found information on the internet to use a 12V brushed motor from a car interior blower.
              Cheap and with sufficient power to give the boat the speed belonging to its scale.
              #559497
              Ron Laden
                @ronladen17547
                Have a look at MFA COMO DRILLS they have a large selection of motors and motors with gearboxes, they also give the full spec for all their types.
                #559505
                Joseph Noci 1
                  @josephnoci1
                  Posted by Bob Mc on 23/08/2021 08:08:04:
                  Hi All…
                  Hi Bob.
                  The term '400 type motor' ( called Speed 400 back then..) dates back a while, and very loosely referred to a motor around near 38mm long, a 500 motor was near 55 or 56mm long, etc. The old 400 DC motors were around 100watts max or so, 10 to 12 amps typically. If I recall, the Speed 400 was around 30mm in diameter.
                  Are you set on a DC motor? Do you already have the DC PWM RC speed controller? If so that would set some limits on the motor amps/volts choice I guess.
                  If you are not set on DC, the RC brushless DC motors are a good option. Much more efficient and more power in smaller packages compared to the somewhat dated construction of the cheap Speed series DC motors.
                  A visit to your local RC hobby shop will deliver..
                  Eg:
                  Howes Models UK
                  E-Flight Park 400
                  Example E-FLight motor chart
                  Joe
                  #560043
                  Bob Mc
                    @bobmc91481
                    Sorry to reply so late …
                    was away for a few days and didn't see the responses….thanks to all who replied to my question, these have been most helpful…
                    rgds..Bob.
