rolling aluminium sheet
Home › Forums › General Questions › rolling aluminium sheet
  • This topic has 13 replies, 9 voices, and was last updated 5 May 2015 at 21:35 by Martin Botting 2.
  • #188504
    Martin Botting 2
      @martinbotting2
      Evening all.
      could some wise person help me? can 3mm ali sheet be rolled easily without it cracking or distorting the outside diameter needs to be about 100mm and the hight of the cylinder when finished about an 25mm.
      I have never done any rolling so not sure what it would turn out like and how easy it would be
      many thanks in advance
      Martin
      #23852
      Martin Botting 2
        @martinbotting2
        #188506
        Michael Topping
          @michaeltopping17870
          Martin
          Depends on what grade of aluminium you are using. 1050A H14 is a good bendable/weldable grade of alloy which will roll easily in a set of bending rolls.
          Michael
          #188513
          Capstan Speaking
            @capstanspeaking95294
            It will take a few passes as 100mm dia in 3mm on hand rolls is going some.
            Also the sheet or strip material used will have a grain from the manufacturing process so it will be better in one direction than the other.
            Edited By Capstan Speaking on 03/05/2015 22:48:11
            #188514
              Martin,
              How critical are your dimensions ?
              … "about" is a rather subjective concept.
              You may find it easier to just get a slice of tube.
                The fact its only a 25mm wide strip will make it a lot easier, I've bent 1" x 1/8 flat bar around soil pipe as a former in the past though rolling would do a better job.
                #188533
                Martin Botting 2
                  @martinbotting2
                  Posted by Michael Gilligan on 03/05/2015 23:07:29:
                  Martin,
                  I have found a company online called metal bits that do 4"X 10swg I will contact them and asking if they will do less than the meter. I will alter the other dimensions of the flanges to fit. Thanks for the tip.
                  Has anyone dealt with metal bits?
                  #188534
                  Martin Botting 2
                    @martinbotting2
                    I will give the bending rolls a bash next week at the club and see what happens with some ali sheet..
                    #188544
                    Circlip
                      @circlip
                      Bit like saying "Can I bend Steel in a rolling machine".
                      "Soft" Aluminininium tends to clunk when ring tested, "Hard" tends to ring. Whichever, annealing helps. How are you going to glue the ends together?
                      Regards Ian.
                      #188553
                      Ian S C
                        @iansc
                        If you do have to anneal it, rub it over with soap, and heat until brown.
                        Ian S C
                        #188566
                        Martin Botting 2
                          @martinbotting2
                          Posted by Circlip on 04/05/2015 10:49:05:
                          Regards Ian.
                          I have some of that wonder solder. I got it after I was wooed by the sales person on one of the trade stands. to my surprise it works well and even I managed to get a good result.
                          #188604
                          Tim Stevens
                            @timstevens64731
                            If your solder works well, it is likely that your aluminium is fairly pure (unalloyed) Al. So, it should be fairly easy to bend.
                            Don't worry about the 'spare' left over from your metre. The left over stock will be dead handy for spacers when clamping stuff to your milling table, and to wrap round precious parts when gripping them in a chuck.
                            Regards, Tim
                            #188706
                            V8Eng
                              @v8eng
                              You could try M-machine for ally tube, they list a whole range of sizes.
                              #188801
                              Martin Botting 2
                                @martinbotting2
                                Thanks for all the hints and tips.
