Restoration of bench drill
Home › Forums › General Questions › Restoration of bench drill
  • #178420
    andrew winks
      @andrewwinks64215
      Hi all
      I have started cleaning up an old Waldown bench drill of an era when Australia had a machine tool industry. Its in good condition, not bad for $50 at an auction and a solid machine at that, but the apprentice(s) must have had a hatred for the table as you can see.
      I've thought of filling in the holes with JB weld or similar as a cosmetic fix but wondering whether its worth it. There's probably enough undamaged surface to just use a vice. Has anyone had experience with the repair of these? Certainly don't want to put heat anywhere near it. (nor will the rest of the machine get any new paint!) Cheers
      #23702
      andrew winks
        @andrewwinks64215
        #178424
        Gordon W
          @gordonw
          I am not one for tarting things up, esp. tools, but I would have a go at that table. JB weld or similar, just to fill the hollows and stop a build up of coolant sludge.
          #178426
          Gordon A
            @gordona
            Hi Andrew,
            You could get a piece of gauge plate cut to size and bolt it onto the surface of the table with countersunk screws.
            Gordon.
            #178438
            “Bill Hancox”
              @billhancox
              Andrew.
              I am not sure how much coin of the realm that you want to put into your project. Having said that, the series of holes appears to occur in a uniform arc radial to the pillar. An option would be to have the arc of holes slot milled and a piece of matching material machined to fit the slot. Might even be accomplished by bending a piece if bar to fit the slot. All followed by a milling of the table to bring everything to plane; grinding if you are really fussy.
              Bill
              #178465
              Johnboy25
                @johnboy25
                Hi Andrew.
                I have an old Viceroy floor standing pillar drill that has been abused by means of numerous artistic drillings on the adjustable table. I don't have the facilities to preheat and fill in the dimples with weld but what I had thought about and I'm sure I'm going to hung out to dry on this 😉 ! – was to fill the drillings up with a hard epoxy then skim off to flatten it down to the original metal surface. I don't know if there is a suitable ITW Devcon product available which has metal  filler that would do the job. Just a thought😀
                Edited By Johnboy25 on 04/02/2015 20:45:47
                #178471
                  Posted by Johnboy25 on 04/02/2015 20:43:19:
                  … what I had thought about and I'm sure I'm going to hung out to dry on this 😉 ! – was to fill the drillings up with a hard epoxy then skim off to flatten it down to the original metal surface. I don't know if there is a suitable ITW Devcon product available which has metal filler that would do the job. Just a thought😀
                  John,
                  I presume that's exactly what Andrew had in mind when he mentioned JB-Weld.
                  P.S. … I think Bill's suggestion is excellent.
                  Edited By Michael Gilligan on 04/02/2015 21:11:39
                  #178472
                    That's just the sort of thing JB Weld is, you can use it to mend cracks in cylinder blocks.
                    andrew winks
                      @andrewwinks64215
                      Good advice all. I'll chew it over some more.
                      #178474
                        Posted by andrew winks on 04/02/2015 21:17:50:
                        … I'll chew it over some more.
                        That table has been chewed-over enough already !!
                        andrew winks
                          @andrewwinks64215
                          True that!
                          #178479
                          Robbo
                            @robbo
                            Andrew,
                            Had a similar problem with a pillar drill, and just cleaned out the holes and filled them with "plastic metal" so as to present a smooth surface and stop them getting filled with gunge.
                            There was no loss of structural integrity, so that was all that was needed.
                            Phil
                            #178483
                            andrew winks
                              @andrewwinks64215
                              Yes, I agree, probably the easiest way.
                              I haven't used JB Weld since late 70's and unsure as to the quality these days or better alternatives.
                              Any suggestions?
                              #178486
                              Anonymous
                                JB Weld doesn't seem to have had it's recipe changed like a lot of other "gone green" products, I'm still using it and can't see a difference from years ago.
                                #178489
                                Jesse Hancock 1
                                  @jessehancock1
                                  Are you sure that what you have isn't the phases of the moon and summer solstices?
                                  School was the last tiime I saw anything like that.
                                  Oh joy I can still see the metal work teacher as he convulsed red in the face and his fists clenched white at the knuckles.
                                  Jesse.
                                  Edited By Jesse Hancock 1 on 04/02/2015 23:14:07
                                  #178497
                                  Roger Provins 2
                                    @rogerprovins2
                                    Posted by Jesse Hancock 1 on 04/02/2015 23:11:25:…………
                                    Oh joy I can still see the metal work teacher as he convulsed red in the face and his fists clenched white at the knuckles……….
                                    I worked in a school for many years and we used to send a bill to a child's parents for damage to school equipment.
                                    We couldn't enforce it but many paid up, hopefully with a few strong words to their offspring.
                                    Roger
                                    #178516
                                    Ian S C
                                      @iansc
                                      You can make quite a good filler for Cast Iron. Araldite or similar, and fine Cast Iron chips from the lathe(fine as you can get, mix the two together, clean out the holes, and fill them, the deep ones might be best if filled in two or three goes. The finished patch should be almost as hard as the table it's self.
                                      Ian S C
                                      #178518
                                      martin perman 1
                                        @martinperman1
                                        Ian,
                                        When I repair the bakelite/plastic caps for magneto's I mix carbon dust with Araldite to match the black of the cap.
                                        Martin P
                                        #178521
                                          Posted by martin perman on 05/02/2015 10:17:14:
                                          That's interesting, Martin
                                          Doesn't that risk problems with H.T. 'tracking' ?
                                          martin perman 1
                                            @martinperman1
                                            Michael,
                                            Never had a problem, I use it for cosmetic purposes on the outside, cracks and breakage.
                                            Martin P
                                            #178526
                                              Posted by martin perman on 05/02/2015 10:42:13:
                                              Michael,
                                              Never had a problem
                                              Good to know … Thanks
                                              Bazyle
                                                @bazyle
                                                When you think about what the table does in a drilling machine filling it with chewing gum will be adequate. Chew a bit of liquorice too to get a colour match. cheeky
                                                #178564
                                                Jesse Hancock 1
                                                  @jessehancock1
                                                  Roger, I went to school in Australia… My parents bought everything I used down to the last paper clip and pencil. In metal work you had to pay for any materials used and a percentage towards wear and tare on tools benches. Indeed I remember not only giving my parents a bill for two glass covers used in science class but I also received two strokes of the cane across the backside for breaking the first one. Happy days.
                                                  Jesse.
                                                  Edited By Jesse Hancock 1 on 05/02/2015 15:02:52
                                                  #178663
                                                  Ian S C
                                                    @iansc
                                                    If you were worried about insulation you could crush up some old Bakelite to powder/fine chips.
                                                    Ian S C
                                                    #178671
                                                    Russell Eberhardt
                                                      @russelleberhardt48058
                                                      Carbon black pigment is available both in conducting and non-conducting forms – don't know how it's made non-conducting though.
                                                      Russell.
