Pulse Jet Carburator
Home › Forums › General Questions › Pulse Jet Carburator
  • #26597
    Ian Usmar
      @ianusmar79339
      #408285
      Ian Usmar
        @ianusmar79339
        Is there anyone on here who is an expert in Pulse Jet Carbs ?
        #408302
        Roy Vaughn
          @royvaughn26060
          Try the forum on the Barton web site:
          http://controlline.org.uk/phpBB2/portal.php
          #408309
          Andrew Tinsley
            @andrewtinsley63637
            They don't have carbs as such. Just a very narrow aperture for the fuel and usually a compressed air source to start them. The difficulty is getting the diameter correct for the ambient temperature and pressure. Quite an art form in getting this correct.
            Andrew.
            #408321
            Martin Hamilton 1
              @martinhamilton1
              Have a word with Barrie Lever on this forum, i believe Barrie is flying some pulse jet control line planes. If he can't offer advice i'm sure he probably knows someone that can.
              #408337
              Speedy Builder5
                @speedybuilder5
                I have the plans from the Model Aero Engine Encyclopedia 1959 showing the Brauner Pulse jet. PM me if you want a copy. My problem is finding someone who could laser cut the petal valve disc from 0.010" – 015" shim steel.
                BobH
                #408453
                Tim Stevens
                  @timstevens64731
                  Clever things, pulse jets. You start with a working two-stroke single, with a reed valve inlet and tuned resonant exhaust system, and you take away the engine and just join the rest together. Exhaust dimensions limit the frequency, so with a model I guess the sound is not at all reminiscent of a V1?
                  Reed valve petals can be made by spark erosion, electro-etching, and in extremis, nail scissors. But why not a flutter-box as used in the device mentioned above?
                  Cheers, Tim
                  #408458
                  Speedy Builder5
                    @speedybuilder5
                    Yes Tim, I ran mine up on cup final day one year. Our neighbour who had been bombed by a V1 came running outside in sheer terror.
                    #408467
                    Oily Rag
                      @oilyrag
                      You can use the reed valves from 2 stroke motorcycles, depending on what size you want to build you have the choice of either 80cc kiddies motorcrossers reed valve blocks through to 450cc single cylinder Pro Crossers reed blocks. These reeds are either stainless steel, titanium or of a resin based material. The fuel delivery system is best served by a spray bar arrangement with a needle jet trimming device for fuel flow, ignition by a trembler coil feeding a 14mm spark plug, and on the one I built with some work colleagues many years ago (30!) we had a variable 'exhaust tube' which changed the tuned frequency and allowed us to 'pitch' the outlet sound. Basically the exhaust was a slow tapered tube (~8 to10 degree included taper) from about 3" diameter out to 5" diameter with a reverse cone megaphone reducing it to about 1.5" diameter. The variable length was a sliding arrangement on the 1.5" tail pipe.
                      As has been mentioned above you will need some compressed air to start it and a hand squirt fuel bottle to encourage 'first fire'. Have a fire blanket and fire extinguisher to hand! (in case of a back fire – but with the reed valve block it should be pretty safe)
                      #464223
                      Speedy Builder5
                        @speedybuilder5
                        I had been pondering how to make the reed valves and this guy has the answer :-
                        Reed Valves
                        It struck me as a very simple method of doing other "machining" operations in steel
