Problem with LED lights
Home › Forums › General Questions › Problem with LED lights
  • #461818
    Brian H
      @brianh50089
      I've found the problem with LED lights in the workshop since fitting some, my lathe looks terrible. The paint is discoloured and the metalwork badly oil stained!
      The paint could be T-Cut but can someone suggest a safe way of restoring the shine to the metalwork?
      #27250
      Brian H
        @brianh50089
        #461828
        Tim Stevens
          @timstevens64731
          I have found that white LED lamps can show up the rusty colouration on steel. I suspect this is because the 'colour balance' of the LEDs is not exactly sunlight. The shine on the metalwork is just the same as it was, of course …
          Tim
          #461865
          Enough!
            @enough
            My experience with "Daylight" LED's in place of fluorescents was poor too and hard on the eyes … to the extent that I switched back to fluorescents for the main ceiling lighting. If I went LED again I'd definitely go for the "Warm Light" type.
            #461866
              The really fussy will want to search out LEDs with ‘High Colour Rendering Index’
              The next best option is usually ‘Warm White’ [ as per Bandersnatch ]
              Enough!
                @enough
                Posted by Michael Gilligan on 02/04/2020 17:01:21:
                Which might not be "over-fussy" at that, in a workshop setting (painting models etc).
                Never seen or heard of them myself actually … might be over-taxing on the pocket?
                #461873
                Bob Stevenson
                  @bobstevenson13909
                  Interesting……..
                  I have been using daylight 6400k LED bulbs for worklights for some time now and like working under them a lot,…far better than any tungsten bulb. However, it pays to use as large a bulb as possible in a pearlescent finish as these give a much superior and even light spread over a larger area of the work…ideal for close detail work and turning in the lathe etc……. When my local 'Hombase' closed a few months back I aquired large daylight bulbs and clamp typ holders with white reflectors and they have made first class worklights which can be positioned easily over bench, lathe or drill and give a continuous field of light which I find excellent.
                  The clamp type lamp holders were all of 2 quid a piece and the big leds (in ES screw) were about one each!
                  Edited By Bob Stevenson on 02/04/2020 17:47:09
                  #461890
                  Enough!
                    @enough
                    Bob, I've come to the conclusion that people either love the daylight LED lights or hate 'em. My wife hates them with a vengeance and i didn't get along well with them.
                    It may also depend on actual lighting levels though. I had rather a lot of lighting in the form of fluorescent strip lights when I changed mine and that may have been too much when I switched to (daylight) LED tube replacements. Under those circumstances, the warmer LEDs might have worked better.
                    Possible it also depends on type of bulb (strip-lights or round bulb).
                    #461896
                      Posted by Bandersnatch on 02/04/2020 17:15:51:
                      Here is a straight quote from one of my posts on another forum:
                      Here's an enthusiastic young man demonstrating the merit of high CRI
                      … and a couple of pages from the yuji site:
                      All rather impressive.
                      Happy to discuss further, but at present I’m O.K.with my various ‘Warm White’ lamps.
                      #461907
                        Sorry, that first YUJI link seems to be dead now
                        … But browsing their site is informative.
                        Brian H
                          @brianh50089
                          I don't think my lathe has a problem with the light colour, it definitely looks very grubby on the paintwork and the metalwork is a definite shade of brown from oil and, I hate to say 'rust ' but there is definitely a brownish tinge to it. I've just found some rust remover called 'Evapo-Rust' and quick rub with a cloth impregnated with it removes at least some of the brown.
                          #461948
                          Enough!
                            @enough
                            Posted by Michael Gilligan on 02/04/2020 19:13:33:
                            Yes … very. Bit expensive for normal workshop use ….. although someone who was heavily into an activity which needed it might go there. Or at least set it up in a corner somewhere.
                            Thanks for the links !
                            #462081
                              Posted by Brian H on 02/04/2020 20:42:59:
                              The new bright white LED lighting did you a favour by revealing a light rust problem before it did any damage! Mind you, there's a lot to said for dim lighting – my work looks best in total darkness!
                              Brian H
                                @brianh50089
                                Several items that should have arrived today……didn't! So I've started cleaning the lathe; only problem is that now I've removed most of the grime on the paint, I can see lots of primer. I don't intend to repaint the lathe just yet but I've started to dismantle the Dickinson style toolpost to clear out years of dirt and swarf. The is a depressed circle in it that I believe should have a Boxford disc in it, I'll have to see if I can get one or else it will be print one and varnish it.
