Painting
Painting
Home › Forums › General Questions › Painting
  • #448779
    Garry Coles
      @garrycoles69390
      Hi, I'm going to be priming some of the parts of my 2 in scale D & NY Traction Engine that i'm building. Some of the sheet steel plate has a grey finish to it, and is very hard to get off. I was wondering if this has to be removed before I prime. (The primer I am using is Phoenix Precision 2 pack etch primer.) It seems to be part of the protection for the steel plate when it comes out of the foundry. Can anyone advise me please.
      Garry
      #27104
      Garry Coles
        @garrycoles69390
        #448785
        vintage engineer
          @vintageengineer
          Sounds like zinctec steel.
          #448788
          Garry Coles
            @garrycoles69390
            No, it's just ordinary sheet steel that EKP supplies. No zinc involved.
            #448813
            Jeff Dayman
              @jeffdayman43397
              Might be wise to ask EKP what it is, to make sure the paint you use is compatible. Just food for thought.
              #448818
                Posted by Garry Coles on 25/01/2020 10:36:49:
                Garry
                If it is standard rolled steel plate it is just an oxide film that can be left, or you can get it off with brick cleaner.
                  Yes as Neil says just a thin mill scale, probably a bit of S275 steel. If I'm doing a lot of work on a part I will strip it off with brick cleaner(acid) first if not just leave it on as it adds a bit of texture which often siuts teh fabricated "castings" that I make.
                  #448942
                  Garry Coles
                    @garrycoles69390
                    Thanks everyone.
                    #448954
                    Dell
                      @dell
                      Hi
                      you don’t have to etch steel as today’s primers have very good bonding to steel .
                      Dell
                      #462250
                      Speedy Builder5
                        @speedybuilder5
                        What paint do you use for your Steam Locomotive and who supplies it?
                        #462676
                        Garry Coles
                          @garrycoles69390
                          Hi there Speedy. Here is the paints I've been using.
                          Phoenix Precision Paints.
                          2 part etch primer PQ31 & PQ32.
                          Pre paint metal cleaner PQ17
                          This gives a lovely smooth hard surface.
                          Yourspraypaints.com
                          Loads of colours and finishes to choose from, and then they fill the spray cans for you.
                          Hope this is of some help for you.
                          Garry
                          #463374
                          bernard towers
                            @bernardtowers37738
                            If the parts to be primed are steel why are you using etch primer. Etch primer has been specifically designed for hard to bond materials and steel is not one of them. Much better to use a zinc chromate.
