Oops – Made something too short, how to attach corrective shim ?
Home Forums Help and Assistance! (Offered or Wanted) Oops – Made something too short, how to attach corrective shim ?
  • #607667
    Bob Unitt 1
      @bobunitt1
      I made a pair of gunmetal bearing standards 4 thou too short vertically. I have some 4 thou brass shim, what's the best way to attach the brass to the gunmetal ?
      #34058
      Bob Unitt 1
        @bobunitt1
        #607670
        old mart
          @oldmart
          You could soft solder them or use epoxy resin after abrading the mating surfaces with fine wet and dry paper.
          #607676
          bernard towers
            @bernardtowers37738
            plus one for soft soldering.
            #607682
            duncan webster 1
              @duncanwebster1
              If there are bolts through the pedestal base to hold it down you don't need to attach the shim
              #607817
              Bob Unitt 1
                @bobunitt1
                Posted by duncan webster on 28/07/2022 19:02:47:
                Doh ! blush Thanks, I can't imagine why I didn't think of that at the time.
                And thanks for all the other suggested solutions folks, much appreciated.
                #607868
                roy entwistle
                  @royentwistle24699
                  4 Thou short, does it matter ?
                  Roy cheeky
                  #607872
                  Bob Unitt 1
                    @bobunitt1
                    Posted by roy entwistle on 30/07/2022 09:08:31:
                    Roy cheeky
                    Probably not, but I don't know enough about it to be sure of that,
                    #607892
                    Neil Lickfold
                      @neillickfold44316
                      You can also use super glue to hold in place while assembling, or use Loctite adhesives like the 648 or 620, but 620 is very slow to properly set. Deburr your shim and try to keep it flat as possible. It will only need glue on the outer perimeter, and try to keep it away from  the screw holes. A small amount of Oring grease around a hole on the part and around the hole of the shim, is usually enough to stop the glue from wicking to the threads.
                      Edited By Neil Lickfold on 30/07/2022 14:26:56
                      #607894
                      Bob Unitt 1
                        @bobunitt1
                        Thanks Neil. Does anyone happen to know how thick a layer of superglue is ? (or solder ?)
                        #607898
                          As Roy says it won't make much difference if it's a horizontal engine, if vertical there is usually a bit of adjustment on the piston rod length.
                          If unsure of thicknesses then solder on something a bit thicker and machine back to what's required
                          #607934
                          Neil Lickfold
                            @neillickfold44316
                            Posted by Bob Unitt 1 on 30/07/2022 14:56:42:
                            Super glue and 620 can be as thin as 0.01mm, and if the surfaces are flat enough, then down to 0.005mm
                            #607998
                            Bob Unitt 1
                              @bobunitt1
                              Posted by Neil Lickfold on 30/07/2022 21:20:21:
                              Thanks.
