Hello peoples, I wonder if you can help me help a friend.
A long standing friend of mine has a small jobbing workshop and has a problem with an old mill. Most of his mills are Bridgeports but this one is of Polish origin.
Basically there is a problem with the control circuit.! The machine and it's motors are 3 phase but as is quite common the control circuit voltage is lower.
There is a resistor on the control PSU (seems to be a wire wound one) that has burnt out rendering the machine inoperative. (motors spin up fine if the contactors are manually 'pushed in' ) The machine plate says the control voltage is 220 volts, but I am not sure if this is AC or DC as there are diodes on the PSU that may be configured into a bridge to render the supply into DC
So what I am after is a circuit diagram that will hopefully tell me what value the burnt out resistor was and give me an overview of how the machine is configured electrically. – Does anybody know where I could get such.???
I am attaching photos that I took with my phone to help with its ID and for the general interest of others. (spot the Myford dumped at it's base in one of the pics)
Denis tells me that although old the machine is a good solid and accurate piece of kit. He is obviously reluctant to trade it in for scrap value for what seems to be a minor issue.
Thanks, NIck
