Odd size allthread availability?
Home Forums General Questions Odd size allthread availability?
  • #524381
    Martin King 2
      @martinking2
      Hi All,
      would anyone know if it is possible to buy allthread rod in 7/32” x 28 tpi BSF?
      cheers, Martin
      #27935
      Martin King 2
        @martinking2
        #524393
        Keith Long
          @keithlong89920
          I think you'll struggle. In Kempes Engineers Year Book for 1965 7/32 BSF is marked up as "to be dispensed with whenever possible". So if it was out of favour 55 years ago it's not likely to be stocked very much. The common sizes of 3/16, 1/4 and 5/16 are readily available according to a quick internet search.
          #524405
          Mike Poole
            @mikepoole82104
            That may be hard to find, I don’t know whether 1BA would of any help but it’s fairly close. No use of course if it has to fit other parts.
            #524408
            Robert Butler
              @robertbutler92161
              Or if you have a lathe with a hollow headstock mandrel purchase a 7/32 BSF die from Tracy Tools and cannibalise a die holder to enable it to fit in a three jaw chuck, support in a suitable bush drilled in situ in the tool post. Lock in tailstock chuck to prevent rotation with tailstock unlocked and free to slide. The die plus cannibalised die holder is of little cost and subject to between centres distance enables you to produce whatever length and quantity you require. Go steady if you drive the mandrel other than by hand!!
              Robert Butler
              #524445
              Georgineer
                @georgineer
                Can one ask why? It seems such an unusual thing to need.
                George B.
                #524449
                  Posted by Georgineer on 03/02/2021 09:35:36:
                  George B.
                  English plane makers like it.
                  As you are likely to just need short lengths why not get some 7/32" rod and a tailstock die holder and thread it under power a couple of inches at a time. Or find a man with a repetition lathe and coventry diehead.
                  Edited By JasonB on 03/02/2021 10:04:17
                  #524452
                  Anonymous
                    Posted by JasonB on 03/02/2021 09:58:41:
                    Funny you should mention that. Appropriate Coventry diehead chasers seem to be available secondhand.
                    #524453
                    Tim Stevens
                      @timstevens64731
                      You might find it helpful to start with a length of 1/4" x 28 UNF studding (=allthread). Especially as UNF is current in the USA, and still around in GB. Running a tap down it should be easier than starting with 7/32" rod.
                      Cheers, Tim
                      #524455
                      Robert Butler
                        @robertbutler92161
                        Or a die
                        Robert Butler
                        #524456
                        Tim Stevens
                          @timstevens64731
                          Robert – you got me bang to rights. Whatever that might mean …
                          Tim
                          #524460
                          Robert Butler
                            @robertbutler92161
                            Tim – no problem – anything to include a bit of humour
                            Robert
                            #524472
                            Howard Lewis
                              @howardlewis46836
                              Tim,
                              You screwed up there!
                              If only a short length is needed, if it not available, as already suggested, make it.
                              A friend wanted a LH 1/2 UNC nut. Either not available or at RIDICULOUS prices, (£50+ each).
                              Having some hexagon bar, a set of Taps worked out much cheaper!
                              #524475
                              Martin King 2
                                @martinking2
                                Hi All,
                                Jason has it right. It is common on many STANLEY planes and others. i need some length to remake knackered adjuster columns on some spokeshave adjusters etc.
                                i will try a hexagon die from Tracy tools then try to power thread some at low rpm in back gear. Another first for me!
                                Cheers, Martin
                                #524478
                                Howard Lewis
                                  @howardlewis46836
                                  use plenty of a suitable lubricant and you sgould be OK.
                                  Go for it
                                  #524479
                                  Anonymous
                                    Posted by Martin King 2 on 03/02/2021 11:24:58:
                                    i will try a hexagon die from Tracy tools then try to power thread some at low rpm……..
                                    Solid hexagon dienuts are intended to clean up existing threads, not cut new ones. Personally I no longer buy from Tracy Tools. Instead I'd look a for a quality make NOS die on Ebay.
                                    #524616
                                    Martin King 2
                                      @martinking2
                                      Andrew, Thanks for that info, will do.
                                      Martin
                                      #525359
                                      John Reese
                                        @johnreese12848
                                        I am surprised no one suggested single pointing the thread using a follow rest for support.
