Non ABS pipe glue recommendation please
Home › Forums › Beginners questions › Non ABS pipe glue recommendation please
  • #426216
    Andy Carruthers
      @andycarruthers33275
      Outlet pipe for hot tub snapped when moving hot tub, I've tested with Acetone but no joy, plastic is hard white with almost ceramic like texture and brittleness
      Replacing the pipe isn't an option unless I absolutely have no choice so I'm looking for a glue recommendation please
      #9828
      Andy Carruthers
        #426221
        Tim Stevens
          @timstevens64731
          I think the specification 'plastic but not ABS' is too vague – sorry. And whatever you use has got to be heat resistant, too….
          tim
          #426223
            Is it uPVC pressure pipe? if so use a solvent weld adhesive for that. The fittings usually have the type of plastic on them.
            #426230
            HOWARDT
              @howardt
              Could be CPVC, good for 90 C. See here **LINK**
              #426233
              Stuart Bridger
                @stuartbridger82290
                Just don't use a conventional silicone based sealant. I made that mistake
                #426235
                Dick H
                  @dickh
                  A picture might be helpful. I´m not sure what you mean by a "hot tub". I know certain large bits of plastic sanitary ware used to be made of highly filled thermosetting polyurethane moulding compositions.
                  #426242
                  not done it yet
                    @notdoneityet
                    It may even require a welded connection/repair. General solvent glues may not be appropriate in all situations.
                    #426245
                    Martin Hamilton 1
                      @martinhamilton1
                      You want something like Devcon Plastic Welder, this is a 2 part acrylic adhesive . It mixes like 2 part epoxies but is made specifically to bond most plastics including PVC/ABS. I have used it for years on Plastic to plastics also plastic bonded to glass fibre/metal/wood. Its available from model shops or Ebay etc.
                      #426248
                      Jeff Dayman
                        @jeffdayman43397
                        I don't recommend playing "guess the polymer" when doing glued repairs on plastics. I'd recommend a call to the manufacturer or the dealer and ask them what glue to use. (or what type was spec'd originally)
                        #427401
                        Andy Carruthers
                          Thanks for all the advice – Martin's suggestion of Devcon did the trick, I stumbled across a tube at a car boot this weekend, wouldn't have known what I was looking at without this top tip
                          Hot tub holds 4 people therefore lots of water pressure, so far the repair has held up
                          #427403
                          Martin Hamilton 1
                            @martinhamilton1
                            Glad the Plastic Welder worked ok & it holds up, it actually melts into the surface of the plastic giving a strong bond. The good news with Plastic Welder is you can use it also on thin plastic where it only melts or etches into the surface of the plastic so dose not affect or distort the other side of the plastic which a lot of the time is the outer surface that can be seen depending on what you are bonding.
