hi all
i been trying to pratice turning for when my new flywheel is delivered but i having trouble tracking down a few problems i got with my lathe its a 1947 ml7 with white metal bearings.
problems are
1: if i turn bit of stock then undo the chuck and rotate the stock then clamp up i find the stock is no longer centred. is this normal ???
2: i get very poor finish on all work ,brass is ok not mirror finish but smooth everything else is very rough feels more like a file !!!!
i placed a dial on the chuck and used wood to lever it up and i got 0.18mm movement is this too much ?????
ive checked bearing blocks are clamped down and checked the clamp nut on end of the spidle. i checked all slides etc,spent all day griding tools even tryed carbine tipped tools basicly im at a lost other than thinking the 0.18mm movement is too much ????????????????????
thanks
Gavin
