Milling machine spindle speed readout problem
Home › Forums › General Questions › Milling machine spindle speed readout problem
Viewing 2 posts - 1 through 2 (of 2 total)
  • #865771
    Steve Huckins
      @stevehuckins53362
      Can anyone advise about a problem I have with my VM25 milling machine. The spindle speed readout has started to show the wrong RPM and seems to cycle down and eventually only reads zero. Could this be a mechanical fault of some sort. The screen is still backlit whilst running.
      Thanks. Steve.
      #865774
      Clive Brown 1
        @clivebrown1
        Sounds similar to a fault on my (Weiss) WM16B. Warco advised checking alignment and cleaning the optical sender. This is accessed by removing the cover plate, 6 screws, from the front of the machine head. It’s an awkward task and my readout is still not fully reliable although it’s better than it was.
