Myford Change gear compartment trays. Ok ?
Home › Forums › Workshop Tools and Tooling › Myford Change gear compartment trays. Ok ?
  • #846051
    sparky mike
      @sparkymike
      I saw these myford change gear compartment trays on Ebay. Are they any good. ? Certainly not expensive.
      Mike.
      #846065
      bernard towers
        @bernardtowers37738
        #846068
        Bazyle
          @bazyle
          Rather expensive for a 3D print. Might as well get your own printer.
          #846075
          sparky mike
            @sparkymike
            Expensive at around £15.00 ? Thought it was cheap !!
            #846078
            John Haine
              @johnhaine32865
              Bit of mdf and 3 or 4 lengths of dowel to fit in the holes. Drill the mdf, glue in the dowels, stack the gears. You can play the towers of Hanoi on them too.
              #846094
              DC31k
                @dc31k
                Please give the eBay reference to the “expensive” one you have located.
                As above, one example is:
                https://www.ebay.co.uk/itm/235961528922
                This is £15. Others to very similar designs also hover around this price. Take off eBay’s fees, postage cost, cost of filament and the seller is not making much.
                In addition, each gear is accessible with no shuffling.
                #846103
                Bazyle
                  @bazyle
                  If you bought a 3D printer to make your own you could also make the changewheels themselves 🙂
                  #846106
                  Andrew Tinsley
                    @andrewtinsley63637
                    A friend had one and he does a lot of screw cutting of various pitches The 3d printed holder has worn quite badly with continued use. He has reverted to the plywood base and dowel solution. The badly worn 3D printed holder has been binned.
                    They are probably OK if there is little in the way of usage. But if this is the case, then the plywood / dowel solution is just as good. Hope this helps.
                    Andrew.
                    #846109
                    Journeyman
                      @journeyman
                      Plenty of choice if you want to print your own:
                      Printables – Gear Tray
                      Thingiverse – Gear Caddy or Another Gear Caddy
                      ‘Happy Printing’
                      DC31k
                        @dc31k
                        Would yo uupload the model to one of the Chinese 3D printing services (including the one whose adverts are in the magazine), choose a long-lasting material and report a cost.
                        That might give Bazyle a cost-comparison and could overcome the limitation that Andrew has identified.
                        We should note that not all 3D printed materials are the same – PLA is the most common. Also, the infill (density) of the print along with shell thickness can affect longevity.
                        #846165
                        Bazyle
                          @bazyle
                          I suppose this is a bit like buying pizza. Gen Z are happy to use an App to have a ready made and cooked meal delivered at huge markup for all the businesses and staff in the food chain and some of us oldies on a pension make one themselves at cost.
                          #846200
                          John Purdy
                            @johnpurdy78347
                            Search for my recent post #837670 for the one I made a couple of months ago. Would this fill your needs?
                            Journeyman
                              @journeyman
                              I fed the .stl file from the Printables version into the slicer and set it to:
                              5 top layers
                              5 bottom layers
                              5 walls
                              15% gyroid infill
                              Using PETG/CF it calculates 12 hours to print using 285 grams of filament that’s roughly 1/4 of a 1kg spool or  £5.50 worth of filament depending on the make ( that price is for Eryone PETG/CF)
                              Not that I need to print one as I no longer have an ML7😄
                              Nigel Graham 2
                                @nigelgraham2
                                Mine live in a “preloved” box that had once held some sort of laboratory apparatus, and is divided by vertical partitions into cells conveniently the right width for the wheels. Easier to use than a “towers-puzzle”.
                                And there they slumber, each in the polythene bag retaining its label from its purchase from the Myford exhibition-stand, as I have fitted a gearbox to the lathe.
                                The one wheel that does hang in its little bag above the lathe, is the 12T tumber output pinion, for cutting threads finer than 28tpi: most of the time I use the stronger 24T pinion and set the gearbox to (cut tpi X 2).
                                One of my fellow club members reverted his Myford lathe from gearbox to change-wheels, actually finding that more flexible and more convenient for his purposes. I have kept all my lathe’s original parts to retain that option.
